I've been recently developing and making quite a few 4U panels/modules for myself and others, based on a 'single-function' approach. As someone who can never decide what I want to build, nor how many, nor what to take out for gigs and events, it made sense to me to reconsider what may be seen as a 'standard' - the Serge whole 17†panel thing...
I love the 17†panels I have, and think they're great, but always I'm thinking “ahh, could do with two of them... another of them... don't like that... be good if that had XXX extra featureâ€Â
So I decided to come up with this 'single-function' format... (not that I came up with much, as you will see, just a few panel spacing/mounting ideas)...
My idea is that this way you can have whatever you want in your budbox/rack and not have to adhere to the predetermined choices taken in a single 17†panel, you could have a SWAMP without the Pulse Divider and an LPG instead, or a dual VCA, or a TH Control LFO etc... Another way of looking at it is to see it as a useful way to expand your Zthee or Dmitri panels with some specifically chosen modules without having to build a whole panel at once - this is what I'll be doing at any rate... Other pluses for me are the possibilities of density vs functionality - I can leave the modules I won't use at home, or swap, mix n'match, sell what I don't need, make things for less expense and commitment than a whole panel, experiment without fear of overheads, things like that - you know a 'modular synth'!
The idea is very simple:
I split the 17†into 16HP, which gives an HP multiple of 1.0625†(this made sense with eg CGS designs as it allows for the inevitable wiring mess - though probably that's just me - to be squeezed in behind the panel around the PCB). I've rounded these up/down to mm increments.
The panels are 175mm, one can re-fit a budbox with vector rails and mount modules in it (I have more info about this which shall hopefully soon appear on my 'website'.)
Obviously this is all leading up to the other point, the [IC] in the topic!
I'm wondering if anyone else is interested in panels such as this? I'm hoping that a) maybe they are, and b) that might make the panels cheaper all round!
I suppose the actual panel design itself becomes rather important at this stage, even beyond the technical 'standard' of a 'format', so I also have some questions for anyone who might be interested :
• Are you stuck on the Serge aesthetics/grid? I'm not particularly bothered in a rigorous adherence to 0.75†x 1†etc, if something calls for otherwise, works better in space, so be it - what do you think?
• Are you actually interested at all?
• Do you like swooshes, Eras, Blue? Again, I'm not bothered (I'm not super-into 'cloning' as such, and I'm no fan of Eras, swooshes, tini-jax etc!) Having said that some aspects of the Serge grid and the Buchla aesthetics are very appealing! (as you will see that I see below!)
I appreciate this is a rather vague and general post, but my intention is to ask what everyone thinks, and if anyone else other than me is interested in this idea, in getting some panel group buys together?
Here is some eye candy so you can get an idea of what I'm talking about, as you can see mainly and generally 'on-the-grid' but sometimes not... Also, the panels wouldn't say 'loudestwarning' on the bottom, probably 'CGS' or 'Haible' etc, I have rather a lot of designs I've been working on and interested in getting made up, so again, if you have anything you would like to see, let me know...
This is a budbox with vector rails and some modules in it...
A dual VCS...
Quad LPG...
Single LPG, all bells n whistles, proto...
Res EQ...
etc etc, I have more, but maybe it would be more interesting (for me certainly) to hear some other thoughts other than those on my bubble!
(also apologies if I babbled somewhat, I've the flu so maybe not sensible, also to the mods - not sure if this is a suitable [IC] thread, didn't there used to be some guidelines about IC and group buy threads as a sticky?)
