HELP PLEASE needed with video wall!
alexwhite
intrinsically linked
Post by alexwhite »
I've gone out on a limb in the hope of setting up a 4x4 16 screen video wall to present television / video art on.
I boiught 5 Imtech Ultra Decoder racks on Ebay from the US like these:
They have a range of inputs (composite, svideo, RGBS, component) and each then (in theory) outputs four qaudrants of the input image (I hope). The outputs are a bit trickier - they are 9 pin serial outputs label with RGBSHV
After a bit of research I think the outputs are the multisync standard used for monitors:
http://www.pcmag.com/encyclopedia/term/ ... nc-monitor
My plan was to feed one rack with the signal and then divide that signal out to each of the four remaining to achieve a 16 screen wall.
I've source 13 20" Sony BVM-2016P that all function adequately and I'm hoping to find another 3. These have SDI, composite and RGB inputs. I'm wondering if there is a simple way to connect these to the Imtech racks?
My initial thought was to connect the imtech outputs to VGA connectors - i still haven't been able to test this theory yet but from everything I've read these outputs should be compatible with VGA. I was then going to use some extremely cheap VGA to composite converters to get into the TVs.
But I'm wondering a couple things:
Has anyone worked with imtech gear in the past? Or with a 9 pin serialesque standard?
And is there any way of easily converting RGBSHV to RGB with a custom cable? Or is sync on green already there? and all I need to do is connect the RGB?
Any help much appreciated - you can borrow it if we get it functioning! (and you live in Sydney)
cheers Alex
daverj
Vintage Video Wiggler
Post by daverj »
Do you have a scope?
CGA, EGA, and NEC VGA all used DB-9 connectors, but had different pinouts. And all were RGBHV. I don't know if this uses the same pinouts as one of those or their own format. Plus I don't know where the "S" is coming from. Maybe there is a switch inside to change between RGBS and RGBHV?
waveglider
Post by waveglider »
Here's the DB9 pinouts from info I found:
1-Ground
3-Red
4-Green
5-Blue
6-Select
7-Composite Sync
The Select line is a DC voltage output used to tell older SCART gear what type of aspect ratio is present.
I'm not sure why the silkscreen on the outputs says RGBSHV when there is no H/V sync on the inputs :hmm:
daverj
Post by daverj »
These are from this specific product? They are different from the multi-sync or earlier (CGA/EGA) connectors.
Plus there's still 2 more pins. Maybe the H & V are on those?
wcfields
Post by wcfields »
Are you sure you don't also need a controller? I think the decoders are to take an existing signal and convert it to RGBSHV for use in the controller system.
http://www.ebay.com/itm/IMTECH-HIGH-DEF ... 338365a546
ImageExperimental Half Hour - LA's own television show of experimental music and performance art.
bitSmasher
Post by bitSmasher »
This would be pretty epic, relatively cheap too... If I had a spare grand I'd buy it!
http://www.ebay.com.au/itm/Video-Wall-1 ... cbc&_uhb=1
giorgio
NITE MIND
Post by giorgio »
i'm working on a wall as well but building the whole thing out of raspberry pi computers, 1 for each TV all slaved to a master computer.
johnnywoods
Post by johnnywoods »
giorgio wrote:i'm working on a wall as well but building the whole thing out of raspberry pi computers, 1 for each TV all slaved to a master computer.
this seems to be a popular new solution! wcfields had a great piece up here in LA recently that made use of the same technique. this got me thinking about possibly using multiple pi's into a video mixer/lzx setup. Could be a cool way to do live edits of synchronized material (like for a music video). How big of a PITA is the setup?
wcfields
Post by wcfields »
Yeah I followed the piwall.co.uk instructions.
Things that rule:
* Cheap
Things that suck:
* It's super finicky to "start-up"
* A master PI doesn't do a good job of transcoding (I've only been getting ~10fps)
giorgio
NITE MIND
Post by giorgio »
wcfields wrote: * A master PI doesn't do a good job of transcoding (I've only been getting ~10fps)
why not use a laptop as the master?
wcfields
Post by wcfields »
That's what I've been doing, using VLC to do a multicast stream. Trouble is that the installation is usually further away than I'm using my laptop. I've been experimenting with direct connection with a Wifi adapter, but haven't had enough time to configure it 100%.
I also installed parallel linux tools (http://code.google.com/p/parallel-ssh/) which allow you to run SSH commands simultaneously, so I can do a kill-all of the pwomxplayer and starting it back up too on all the Pi's at once.
Return to “Video Synthesis”
