There's something I'm not understanding about Stackcables...
Sorry if this is really obvious or something but I find the TipTop Stackcables don't behave quite like I expect them to. I expect whatever I send through a Stackcable will be ADDED to whatever I send after. So just like using a mixer.
But say, for instance, that I'm sending two oscillators (through a VCA) to the input of a reverb. The first one through a Stackcable, the second one through a normal cable plugged into the Stackcable. As long as both signals have volume then they both get trough as expected, they're added together. BUT, if I then turn down the first signals volume (with the VCA) then they both disappear. This confuses me!
Should I not liken these to addition? Maybe some kind of "OR"?
Thanks. Sorry if this is stupid.
- spunkytoofers
- Ultra Wiggler
Just to add my bit... it needs spelling out~:~
Use to distribute a trigger, gate, cv or audio but not to mix (join together).
Typical use is where you have a clock or reset that you want to distribute to many places... or a cv that you wish to point at numerous modules (prob a buffered mult is best here).
Perhaps you want to send a ADSR output to several filters or vca's...then thats good.
But do not (no-no-no-no) mix anything together. CV's get added for example, so you could inadvertently send 20v to your module if you add 4 5 volt signals
I think it even gets more complicated than that... you end up with all sorts of voltages going 'against the tide', if you get my drift.
Most modules should have over volt or input protection.... but would you want to risk it with the average price of a module at £200-£300.
If you want to add triggers or gates then Doepfer do a specific module for that. Obviously ditto with something like the polarizing mixer (138c) NS MIXERS 138a and 138b
Asking a related question myself... I have just got a Mutamix (cheers Richyho) - how is this adding CV's? I presume it wont let you go over the 12v standard? I used it to great effect yesterday. No problems, but obviously concerned to be mixing 6 CV's together
A good design will never output anything in excess of the +/- 12V supply rails. In general it's actually impossible for a module to do so as the buffer / amplifier stage on outputs can't generate higher voltage than what it's powered at. Even if the module was doing passive unbuffered mixing through a resistor network or something, this would average the inputs, not sum them to anything higher than the largest input voltage. A module would have to specifically use a boost regulator to generate anything larger than 12V... which would be a very stupid thing to do.maudibe wrote:Just to add my bit... it needs spelling out~:~
But do not (no-no-no-no) mix anything together. CV's get added for example, so you could inadvertently send 20v to your module if you add 4 5 volt signalsI think it even gets more complicated than that... you end up with all sorts of voltages going 'against the tide', if you get my drift.
Also, just a minor point: mixing CV with stackcables won't actually sum the voltages either. The reason it's a Very Bad Ideaâ„¢ has to do with current and impedance problems that arise when two voltage sources are directly connected in parallel like that (against the tide, like you said, is a pretty accurate description of what's going on). Again, good designs should have at least a series resistor on outputs so should be able to cope, at least for a little while and in most circumstances. But you never know- insert Euro wild west reference here. It's bad patching practice and should be avoided.
- soundmachines
- Veteran Wiggler
My two cents...maudibe wrote:Just to add my bit...
---cut cut---
--cut cut--
In no (static) way you can have a sum that is bigger than the power supply rails!!!.
In your example (mutamix) you just 'saturate' the output of the opamps (normally at a voltage of 12V minus the IC dropout voltage) and you can never jump out of that range...
I think that stackcables need a little bit of attention from the user. The fact is that you can not only overdrive INPUTS but also OUTPUTS!!!! It depends on the circuitry used on the different modules... Basically, you can go from 'malfunctions' (out of tune oscs, etc..) to 'slow burnout' of some modules...
cheers!
Karl_Joseph
- Veteran Wiggler
I do feel like all of this info should be make more explicit by TipTop. Like they should come with an info tag, or it should be prominent on the website.
There's really nothing stopping people from using these incorrectly. You'd have to be an avid Muffwiggler to know any different it seems.
Just my 2-cents.
Just my 2-cents.
- raulsworldofsynths
- I'd patch that!
Until I saw a stackable in real life I was a bit baffled by how they worked. Not being from an electronics background at all, most of the jacks I knew were from headphones and my understanding was it was a one way street.UmFuFu wrote:I do feel like all of this info should be make more explicit by TipTop. Like they should come with an info tag, or it should be prominent on the website.
Just my 2-cents.
So when I'd read about people's love for stackcables, but no description on the ah site,having never seen one I thought "WoW, these are pricy cables!"
Then at a convention I saw some Buchla style cables that allow for multiplying. The light came on.
Sometimes it takes a bit to sink in
Don't even get me started on the jacks from the Doepfer A152 Track and Hold which work both as inputs and outputs!
There's some strange black magic in there.
Just grabbed a bunch of these. Great info thanks.
Modular Videos
www.youtube.com/AndrewHunterMusic
Webpage
www.andrewhuntermusic.com
Band
www.atomzero.com
Webpage
Band
www.atomzero.com
You can connect along to as many inputs as you like using passive mults or stack cables (integrated passive mults) from ONE and only one output. How much droop you get will depend on the module which is doing the output, generally you will only notice droop on pitch CV's being sent to oscillators when the source is quantised.tommaso wrote:Another question about stackables:
can I use both sides of a stackable to mult a signal?
Something like this
[massive image]
Can I continue this kind of chain? Is there any risk or I'll experience only signal drop?
Thanx in advance mates
