Animal Factory Amplification
Silent Way VCO Calibration
Moderators: Kent, os, Kent, os
Navs
Post by Navs »
I'm trying out the demo of SW 1.3 with the headphone out of my RME Fireface400.
Calibration works perfectly from C1 - F4 (absolute revelation to hear my M15 tracking so well! :hihi: ) but then things go awry.
The calibrate graphic on the plug-in seems to confirm this (see attachment).
Am I doing something wrong or is this maybe a limitation of the FF400's outs?
I also got a similar result with my Cwejman VCO-2RM ...
Cheers,
Navs
silent way vco calibration kink
os
Post by os »
That looks fine to me - the jaggy line at the top is where you hit the max voltage and it wraps round the top octave.
If you need more range, use an input that's adjustable and not fixed 1v/octave. E.g. If you can set the VCO to 0.5v/octave then you'll double the reachable note range.
wetterberg
Post by wetterberg »
os wrote: If you can set the VCO to 0.5v/octave then you'll double the reachable note range.
-but this will also affect your resolution, right?
Either way, the wrapping around the octave is a nice clever little solution. Good thinking, that.
os
Post by os »
I have to give Graham at http://www.hinton-instruments.co.uk/ credit for suggesting that feature.
Navs
Post by Navs »
Thanks for the confirmation os!
I tried multing and then boosting the CV (A-133) but got the best results using a positive offset of about 2.5V via an A-138 mixer: five perfect octaves :)
os
Post by os »
Sounds good!
What's the oscillator you're using? I'd like to add it to the chart:
http://www.expert-sleepers.co.uk/siwacompatibility.html
Navs
Post by Navs »
I can add a Cwejman VCO-2RM and Cyndustries ZO to your list (C1 - C6), with the caveat that the Zero wobbles a bit in the lower registers and, once you start applying FM indexes in excess of 100%, pitch becomes a relative issue ;)
I also got a Cwejman MMF-1 filter to track perfectly from C1 - C6.
Doepfer's A-105 is a little less stable (+/- 1-2 cents) over the same span, but easily close enough for rock 'n' roll.
Malekko/ Wiard Borg didn't fare as well: +/- 15 cents, but I didn't expect it to.
Two wild cards:
Bananalogue/ Serge VCS, C1 - C5, up to 6 cents off, but hey!
Plan B Model 10 EG, C2 - C4, +/- 20-40 cents. Also surprising.
The tricky part here is figuring how much Timebase modulation to apply.
With the VCOs and filters that are calibrated for 1V/O maybe these results shouldn't be too surprising.
I guess the real issue is that there are still only two (three if you count the RME's phones out) compatible audio interfaces ...
os
Post by os »
Thanks for all those, that's great information.
For the more 'wobbly' modules, I could probably add a more accurate (but much slower) calibration process that fine tuned each note in turn. Do you think that's worth doing? Would users be willing to sit through such a process?
Btw you more than qualify for the bounty, if you can get something on YouTube:
http://www.expert-sleepers.co.uk/index_ ... bounty.php
Navs
Post by Navs »
If it's an easy to implement option, then yes. I'd be happy to test it for you.
The current calibration routine seems to work fine for VCOs and filters with 1V/O inputs though.
Out of interest, how slow is 'much slower'?
Thanks for the bounty tip-off!
os
Post by os »
OK, I'll add it to the "to-do" list.
You can hear the current calibration routine stepping between pitches, and how long it spends on each one. Imagine that stepping over all 128 possible MIDI notes.
1nput0utput
Post by 1nput0utput »
Navs wrote:I guess the real issue is that there are still only two (three if you count the RME's phones out) compatible audio interfaces ...
Almost all MOTU interfaces are compatible. That's way more than two.
Navs
Post by Navs »
You're absolutely right.
I should have written 'two or three brands' i.e. MOTU, Alesis (& RME).
os
Post by os »
Navs
Post by Navs »
os wrote:And Terratec, apparently
10V - Interesting!
Are you finding the Ultralite's 4-5V max output a limitation?
os
Post by os »
No, but bear in mind this is the only way I've ever controlled a modular - I don't have any history with MIDI/CV etc. to compare against.
Analog>Plugins
Post by Analog>Plugins »
I would certainly be happy with a high quality calibration mode for sure.
Don't worry about the time it takes....3 mins would be fine for me.
Loving the updates OS.
antenne
Post by antenne »
you can add a Serge DSG (dual slope generator)
to the list - just calibrated one for tracking over 6 octaves
i also am loving the updates - thanks os
kim
antenne
Post by antenne »
you can also add a Serge VCFQ ( variable q filter ) patched to
self-oscillate
and ofcourse
the "regular" Serge oscillator modules:
PCO ( precision oscillator )
NTO ( new timbral oscillator )
FREQ ( frequency shifter )
kim
os
Post by os »
Thanks for the info!
mono-poly
Le Cheff
Post by mono-poly »
Can i callibrate in the range of -10v to 10v?
http://www.mono-poly.nl
http://www.noodlebar.org
WTB blue lantern purple vco
os
Post by os »
If your audio interface generates that voltage range, yes.
espacevue
Post by espacevue »
I'm trying out Silent Way for the first time with my MOTU 828x. It is working,
only it seems like the 828x's output voltage is super low, as I'm only getting around 1.5 octaves of pitch from the Silent Way voici controller, cf screenshot of the calibration diagram:
Same thing trying to modulate filter freq with envelopes on a different output of the 828x.
Has anyone experienced this before? Is there a way I can get more voltage out of the 828x? I know that an ES-3 would solve this problem, but it seems like I should be getting more out of the 828x.
Cheers!
espacevue
Post by espacevue »
I found a solution which I thought I'd share for others having the same problem: I used the MOTU software mixer (CueMix FX) DSP compressor to increase the output gain using the "makeup gain" param:
Now I have about 5 octaves of tracking which is cool:
I don't know if this is the cleanest way to achieve this but it seems to work.
Anyone know of a less hacky way to get max output voltage from an 828x?
Cheers
Return to “Expert Sleepers”
