For many years I goofed around with different configurations of guitar overdrives. Y'know, your basic opamp driven signal amplifier with a set of diodes shorted to ground to create that diode clipping distortion that so many guitar players dig the livin' shit out of. In that pursuit, I discovered that one of the main differences between different diodes used, was a difference in gain before the diodes actually clipped. (There's an entire shit-ton of reasons why that is such an important thing when an opamp/diode clipping overdrive units are used with guitars, this thread is not about that).
Anyhow, taking that experience into the studio this morning, I removed the diodes in the ring mod, and replaced them with a totally random selection of square-red LEDs. Besides, I wouldn't have the first clue of how to match LEDs as diodes anyhow.
It worked FAMOUSLY!!!! It created a ring mod that does precisely what I want one to do in the role it plays in my synthesizer. It created a fekking SCREAMING SCREECHING BEAST of a sound! And (just as I mentioned above regarding voltage-levels-before-clipping aspects of different diodes) the overall output level of the ring mod was increased dramatically.
Ok .. alright alright .... I'l shut up .... here's pics already ....
I also went ahead and added a proper VCF, as well as a signal mixer. So now this patch is ~pretty much~ the same setup as I have planned for my Super Mini Mod. I installed the Q150 ladder filter (LP 24db), and the STG Soundlabs "Mixer" (geez, I wonder how long it took Suit and Tie Guy to come up with that name? Work on it all month, did ya?). For anyone unaware, the STG "Mixer" is a modern copy of the R.A. Moog modular CP3 signal mixer. It's about one fat bastard! (the module, that is).
So this patch emulates precisely how a basic patch on the SMM synth (Super Mini Mod) is set up without a single patch cable. Oh man, bla bla bla already about how fekking GLORIOUS my synth is. Back to the ring mod ....
So the red LEDs worked out SUPER well. Much more output, ~holy shit~ amounts of top end freq-response now, too. And in a patch I can emulate with my SMM without any patch cables.
This test did 2 things .... it proved an idea about which diodes to use in the basic 2-transformer/4-diode passive ring modulator ...... and ..... it also proved out the topography of the way I want to configure my synth (normalizing routings).
The way I patched up in the first RM tests I used a different routing, using the feedback setup in my Q113 mixer to distort and drive the inputs to the RM (which my synth can do, but it would require patch cables).
This way that it's patched today, the VCO outs go directly into the RM's ins. You see, with either silicon or germanium diodes the signal is so eaten up by the restrictions the diodes place on it that I needed a serious signal boost going in AND coming out of the RM. Changing the diodes to LEDs really (really!) upped the output gain of the RM, so no extra signal boost was needed going in to the RM. So I didn't need to use the modded Q113 mixer to boost the living shit out of the VCO output to properly drive the RM anymore.
I still need a boost on the output though, but that's already baked in to the signal routing design that I have going on. I've placed another Dot Com mixer (a modded one, of course) on the Center Strip, providing boosted signal levels on the outputs of both Ring Mods (the right one for Voice 1, and the left one for Voice 2). RE; the picture below. the black knob is the RM's output level, and the red knob sets the drive level of the modded Dot Com mixer used for the RM's output. I'm using ONE Dot Com mixer PCB for both RMs, one bus per RM. The PCB itself will be stacked on top of the main mixer's PCB in the upper row (I had to have SOME place to put it, that was as good a place as any other!). This picture is of only half of the Center Strip ... which is home for the Ring Mod that services Voice 1.
Well, this patch pictured here in this post is an exact emulation of one of the SMM's voices, plus one of the VCFs in the lower row or modules, including the STG "Mixer" (geez .... "Mixer" ... really?) and one of the two VCFs I have going into the SMM.
I'm super excited! The sound is precisely what I'd hoped for. Think of what guitar players call "pinch harmonics" ... that's what I was going for, and that's what using LEDs in these particular passive transformer style ring modulators provide.
RC7 out.
EDITS:
1.) I may not even use the standard built ring modulators (the ones with the germamium diodes).
2.) That said, the two little ~blue~ toggle switches on the Center Strip will become *ON-OFF* instead of an *A/B* toggles for each Voice-RM.
3.) I'm not really sure just ~what~ I'll do with those 2 completed ring mods that have germanium diodes. Perhaps make a guitar pedal or something? Perhaps sell them? Dunno.
