AUGUST 12th, 2017: NOTICE ..... I am aware that the first two and a half pages of this journal have no images. This is due to PHOTOBUCKET's latest policy which places a $400 per year charge on users that wish to embed photos in to forums (y'know, like what most everyone does). I am terribly sorry, but I am unwilling to be extorted out of $400 each year just for the ability to post images in a forum. Starting about halfway down page 3 of this thread I began using Muffwigglers' photo database instead of PHOTOBUCKET to embed images in to my threads. I am yet uncertain about exactly ~what~ I will do about these first 2.5 pages just now.
(Over time, I may attempt to replace each PB hosted image with the same image that I'll upload ... one at a time ... in to Muffwigglers' image database so that the proper images appear in the proper places .... obviously a long and tedious task so no promises there).
It's a shame since these first few pages had really detailed and informative pictures of the entire design and construction process of the dual Amherst cabinets I've used for this project. Please direct any anger or frustration about this situation to the fine assholes at PHOTOBUCKET for their recent (2017) decision to charge $400 per year to those of us that used PHOTOBUCKET to host images for our forum posts.
PHOTOBUCKET SUXABUCKET .... elitist assholes. I really hope their new policies will end up shitting all over their bottom line and PHOTOBUCKET KIXTHEBUCKET ... going down in the flames of Chapter 11 Bankruptsy ... or worse, having to sell off the company for $0.10 on the dollar. This is one shithead policy, to be sure.
Now, back to the construction journal .....
Thanks ... Brian.
The Super Mini Modular Synth Project
PROLOGUE: Hello folks. I'm using this thread as a sortof photo-journal for a modular project I've been working on for about a year. I'm far from wealthy so it has moved slowly, but as experienced wigglers will tell you, slow is best when it comes to setting up one's first modular system. As has been said any number of times in this and other forums, moving slowly sortof forces you to learn the abilities and limits of what you have more intimately. Throwing much thousands of munnay at a first-time modular synth is probably less desirable unless you intend on building a showpiece. Point being is that if you don't have a lot of munnies, don't feel like you can't do this, slow and steady is actually the better way to go about it. Not having cashola kindof forces a certain type of discipline on your progress. Call it an advantage. Along the way your ideas about what is ~good~ will also most likely change. So had you tossed together something ~complete~ by spending a pile of bux you'd most likely end up selling off some of the pieces (at a loss) to buy stuff that appeals to you more as you begin to use the system. Slow-going provides you with time to design the system as you learn to use what you have. So don't be discouraged if you feel like you have to buy this huge thing all at once and cannot afford it. The slow method is better, and having less money is a sortof automatic damper.
I wanted to create a MU system with the main ethos of it's design focused on the same sortof design ideas as the ARP 2600, the Tom Oberheim SEM (original or reissue), or perhaps the Analog Solutions Telemark v2 are designed around. That is to use a sortof hardwired (aka ~normalized~) synth with patch jacks that can override the normalized connections as well as add other modules to the setup or patch.
My own experience has taught me that the well-worn and time proven format of 2-vcos, mixer, vcf, vca, some lfos, 2 EGs, and a ring mod is usually plenty to get most synth sounds done. Like what 95% of most Minimoog patches are written with, or the Lil Phatty has. That said, I began there, using that format as a launch point.
UPPER CAB - The Synth: (refer to the upper half of the picture below).
-- (6sp) 2 Q106 VCOs with Q161 waveform mixers normalized to each one. That provided a single output jack for each of the two VCOs while still allowing selections of any waveform or combinations of waveforms.
-- (0sp) 1 Q116 Ring Modulator. It is what it is. It will actually be transfered to a double-width blank panel as part of a signal routing setup.
-- (2sp) 1 Q132 double-wide blank panel to serve as the housing for the Q116 Ring Modulator as well as some signal routing toggle switches used as part of the normalization system.
-- (1sp) 1 Quad LFO (Model 1250) by Synthetic Sound Labs. This serves as the primary LFO for doing standard LFO duties such as PWM and filter modulations.
-- (2sp) 1 Q150 Ladder VCF. This filter has two signal inputs, each with level attenuators. This serves as a 2-channel mixer and a filter all in one.
-- (2sp) 2 Q109 Envelope Generators.
-- (1sp) 1 Q108 VCA. This VCA receives the output of the Q150.
That totals to 14sp MU. Since I decided to use Amherst Design cabs for this project (14MU spaces per side) that worked out perfectly. 14sp filled one entire Amherst cab. I have not rec'd the Quad LFO yet, nor have I built the Q116 Ring Mod in the blank dbl-panel. So in the picture below imagine the quad lfo being where the ring mod is, and imagine the ring mod being built-in to the dbl blank panel along with some routing toggles.
LOWER CAB - The Expander: (refer to the lower half of the picture above)
-- (6sp) 3 Q106 VCOs.
-- (1sp) 1 Q112 4 channel mixer.
-- (2sp) 1 Q107 State Variable Filter.
-- (1sp) 1 Q162 Filter Mixer, normalized to the Q107 State Variable VCF.
-- (1sp) 1 Q109 Envelope Generator.
-- (1sp) 1 Q111 Pan/Fade.
-- (1sp) 1 Q128 Switch.
-- (1sp) 1 Q131 Single Width blank module that will be used as the CV/Gate/Other interface module.
That also totals out the 14 MU spaces, filling the lower cab. There is also a Q137 Power Control module located on the rear of the lower cab. The power supply I selected is the QPS1 which provides plenty of power for this system. For power distribution I used the QDH20 "DC Squid" to get started. I plan on refining power distribution somewhat, but to get started the QDH20 worked out just fine.
The picture below was taken before I properly arranged the modules in their present configuration, as shown in the top picture.
The upper cab is the basic synth, the lower cab is the expansion ~module~.
So the entire rig is sortof like having a totally patchable Minimoog sitting on top of a few modular modules used to expand it. Hence the little name I use for the sytem .. The SuperMini modular. The synth is a sortof "Super Minimoog" and the rest is expansion. The name may be thought of as a super mini-modular (a miniature modular synth system that is a bit ~super~ in it's own way) ... OR ... a super-minimoog made of a modular synth. Either way, Super Mini Modular is a fun name for it.
DIMENSIONS:
It dims out at 32 inches wide, 22 inches tall, and 9.5 inches deep. It weighs 34 pounds fully loaded with the PSU and DC squid installed. A nice size for hauling around, and does not take up half of a studio. It easily sits on a standard folding keyboard stand and is easy to carry by a single person due to it's relatively light weight and the carrying handles being sortof built-in to the cab design (the 2"x2" ~notches~ between the upper and lower cabs on the left and right of the whole thing, as seen in the rear-shot of the synth).
PLANNING AHEAD:
The essential plan is to normalize the upper cab's audio, cv, and gate connections. In doing so, most of all the synth sounds I typically use will require no patchcords whatsoever to create. However any of the normalized connections will be easy to override by inserting a patchcord into the normalized jacks. So absolutely none of the patchability features have been sacrificed at all.
The lower cab will remain totally modular with no normalized connections other than the Q107/Q162 relationship. This will provide me with extra modulations, more voices, and just plain old ~more synth~ when I need it.
I also plan on attempting to add some preset capability through the use of some of the MIDI controllable pots and switches available out there these days.
There is also a control interface that goes with this, to be housed in a BOX-11 frame which has been ordered. As well as a parallel-signal processing rack-based setup that is also all MU format that I use for FX.
EPILOGUE: This is just an introduction to the project, which covered a lot of territory (hence the length of the post). In posts ahead I will cover the details about the double-decker cab's construction, the normalizing of the synth module, the customized blank panels, the preset ideas and so on. I'll also provide links to vendors, sources, and suppliers as well. I'm offering up my progress for those of us out there that would like to build up something like this. My thoughts were to keep this system constrained within given structured limits, and to create a disciplined system that still has plenty of processing power. This keeps costs reigned-in, and doesn't overwhelm me with some sort of all-consuming monolithic monster. Large, ever-expanding systems may suit some people (which is just fine) but they are outside of my needs.
Thanks for taking a look. I'll be happy to answer questions or reply to remarks. I'll do my best to provide the answers you need.
Be well. RC7.
