FatRocky wrote:Do i need to have these three modules attached at the back for full functionality?.. For what i see in this graphic manual , there is a whole lot of functions they can do independently .
If you have all three, you probably want to install the jumper cables between the boards. The four PDO outputs go to the QAAF inputs, which is very handy. However, if you patch a different signal into one of the QAAF inputs it's going to mix with the three remaining PDO signals. I also found that if the normalizing cable to the QAAF is omitted, its outputs exhibit a DC offset.
PDO outputs 2,3,4 are normalized into the three signal input of the TVCA. And then the three output of the TVCA normalize to the three phase CV inputs on the PDO. If you have a PDO MkII, it has switches on each phase CV channel to select between the output of the TVCA, the panel jack, or a mix of both. So the TVCA outputs can be switched off and not impact the PDO.
I opted NOT to connect the PDO outputs to the TVCA inputs. It's easy enough to patch these when you want to. My reason was that now the TVCA is easier to use independently as a mixer, and also the bipolar offsets are available when nothing is patch to a signal input.
