Buffered mults
Buffered mults
I'd like to make up a buffered mult on strip board for shits and giggles. I can't seem to find a decent schematic to learn from. I am guessing you basically run signal through an opamp at unity gain and then?????????
this discussion is just going on over at e-m: http://electro-music.com/forum/topic-56272.html
Here's another thread. This one has some layouts posted.
http://www.electro-music.com/forum/viewtopic.php?t=49356
Ya I already did the dreaded search and found nothing frutful. I'll go check out the posts you other guys made and check back with more questions (when I'm off the ski hill, yipeeeeeee!)sduck wrote:Boy am I glad you asked. I was thinking of building up a few also, but my powers of searching on this website are weak, so hopefully someone will post a schematic. Or I'll have to try doing the dreaded search...
Here you go:
Place a temporary load, the 100K resistor with the dotted line, on one of the outputs. Put a steady voltage signal into the input. Adjust the potentiometer so that output voltage measured at the top of the load resistor equals the input voltage.
Knobcon Nine - 2021 Photo Album
Check the new Grove Audio Outlet Store. Module specials, used stuff, pro audio gear and more.
For sale: Used Synthesizers.com Q-107 State Variable Filter; Used Strymon Big Sky
Tesla Science Center http://www.teslasciencecenter.org
I made a slight mistake in the schematic which has already been corrected. The potentiometer should be a 10K which will give a X1 +- 5% gain adjust range.
How critical is the value of the 27pF cap (will 33 be ok?);
What about the 95.3K resistor. Naturally, I don't have that in my parts bin so how about 30+30+30+3.3+3.3... new at this so please bear with me.
Is the point that you can affect between a 90-something K resistance and a 105 or so amount of resistance thus boosting or cutting the voltage in order to dial in unity?
Final stupid question of the evening, how to wire the 10K pot? I've seen the 1,2,3 (ground,wiper/center,+xV) wiring, should two of the terminals be connected together, if so which? Thanks.
i built the one listed in this thread - the schematic provided by Big G resolved all my concerns with standard buffering circuits and works great
viewtopic.php?t=19142&highlight=buffered+mult
The capacitor gives the circuit stability when the gain of the amp is set near X1. The value is not too critical. I would say anything between 22 and 100pF would be fine. If you go higher than that, you will be affecting the high frequency response.EMwhite wrote:How critical is the value of the 27pF cap (will 33 be ok?);
95.3K is the nearest value to 95K in 1%. A 82K and a 12K in series would work in 5% values.EMwhite wrote: What about the 95.3K resistor. Naturally, I don't have that in my parts bin so how about 30+30+30+3.3+3.3... new at this so please bear with me.
Yes, that is the reason. A common use of a buffered mult would be to distribute note CV values to multiple oscillators. The value of the gain needs to be as close to X1 as possible in order to maintain the 1V/Octave scaling. If the gain is not close to that value, you would be only able to tune all oscillators to be in tune at one value. The oscillators will stay relatively in tune with each other but all would go out of tune the further from that "in tune" value they got.EMwhite wrote: Is the point that you can affect between a 90-something K resistance and a 105 or so amount of resistance thus boosting or cutting the voltage in order to dial in unity?
You could use only two of the three pot connections, the wiper and one of the end connections. I usually connect the wiper to one of the end connections and use that in conjunction with the other end connection in this sort of application. That way, there is always a DC path returning to the negative input from the output which prevents bumps in the gain of the amp as the wiper scraps along the surface of the resistance element. If the path opens briefly, the gain of the circuit will head for infinity and produce noticeably more noise in the output. I usually also arrange the connections so the higher resistance occurs in the clockwise direction which would produce higher gain but that is only a cultural bias toward right-handedness.EMwhite wrote: Final stupid question of the evening, how to wire the 10K pot? I've seen the 1,2,3 (ground,wiper/center,+xV) wiring, should two of the terminals be connected together, if so which? Thanks.
I was suggesting using an op amp such as the TL062, TL064, TL072, TL074, TL082, TL084 series but any quality, low offset, high speed opamp will work. The capacitor assures stability so the choice of device shouldn't matter too much. I wouldn't use "old timey" op amps like 741s though as they just don't have very good frequency response.glitchpop wrote:1. IC is listed as TL0XX. Does that mean any opamp will do?
The op amp power pins do need to be connected to a power source. Whether it is +-12V or +-15V doesn't matter. You should use the same power as your other synth modules are powered with.glitchpop wrote:2. +-12V is not shown on the schematic is that assumed to be connected to appropriate pins? Or is it/ will it work unpowered?
Pardon, but could this buffer work off a 9v battery? Am looking at attempting a "portable" buffered mult!burdij wrote: The op amp power pins do need to be connected to a power source. Whether it is +-12V or +-15V doesn't matter. You should use the same power as your other synth modules are powered with.
so... how does burdij's single op-amp design with output compensation in the feedback path compare to Big G's circuit? I was under the impression that each output needs its own buffer.Luka wrote:i built the one listed in this thread - the schematic provided by Big G resolved all my concerns with standard buffering circuits and works great
You can tie as many 101K loads (the equivalent load of the output resistor and one input load of the next stage) to the output of the opamp in the circuit shown as you like as long as the total load at the maximum output swing stays below the maximum current output of the op amp used. For a TL074, the maximum output swing is +-13.5 V with a 10K load. Ten parallel output loads of 101K is roughly 10K ohms. I don't know if I would use that many as the total capacitance of all the cables plugged into the outputs would start to become a significant value.roglok wrote:so... how does burdij's single op-amp design with output compensation in the feedback path compare to Big G's circuit? I was under the impression that each output needs its own buffer.Luka wrote:i built the one listed in this thread - the schematic provided by Big G resolved all my concerns with standard buffering circuits and works great
If you use two 9V batteries, one for positive and one for negative, the circuit should work properly. Remember that lowering the supply voltages will also lower your output voltage swing "headroom". For a TL074, the output voltage will swing to within about 1.5 volts of the power supply voltage values and, as mentioned in the previous post, will also be dependent on the load on the opamp output since the amplifier has some finite output impedance. You could look around for an opamp designed to do "rail-to-rail" output swing like an LT1677 for this application to fully utilize the available power supply range.qfactor wrote:Pardon, but could this buffer work off a 9v battery? Am looking at attempting a "portable" buffered mult!burdij wrote: The op amp power pins do need to be connected to a power source. Whether it is +-12V or +-15V doesn't matter. You should use the same power as your other synth modules are powered with.
Thanks, that sounds great! Still I don't understand why most buffered multiple designs are built around multiple op-amp buffers when it only requires one. What I understood from your reply is that with your design it's possible to use a single op-amp (e.g. TL071) for up to 10 outputs and still have an accurate 1:1 output scale. Are other designs overcomplicating the matter then?burdij wrote:You can tie as many 101K loads (the equivalent load of the output resistor and one input load of the next stage) to the output of the opamp in the circuit shown as you like as long as the total load at the maximum output swing stays below the maximum current output of the op amp used. For a TL074, the maximum output swing is +-13.5 V with a 10K load. Ten parallel output loads of 101K is roughly 10K ohms. I don't know if I would use that many as the total capacitance of all the cables plugged into the outputs would start to become a significant value.roglok wrote:so... how does burdij's single op-amp design with output compensation in the feedback path compare to Big G's circuit? I was under the impression that each output needs its own buffer.Luka wrote:i built the one listed in this thread - the schematic provided by Big G resolved all my concerns with standard buffering circuits and works great
I don't see the point with all those components. One non-inverting OPamp will do fine, and skip all the resistors. Also skip the 1k resistors and you need no calibrations.burdij wrote:Here you go:
The 1k resistors are only for short-circuit protection, and if you happen to short and destroy an OPamp (I never did) then just replace it.
