Snarky Tuner ($12 Tuner Mod for Modular)
pulplogic
Post by pulplogic »
The Snark SN-2 makes a descent little tuner for modular. It costs around $12 on ebay and the mods for adding a 3.5mm phone connection is fairly easy to do. I simply removed the internal piezo sensor and connected directly to its connections.
aladan
Desperately Seeking Sondra
Post by aladan »
That's way cool... couldn't stop myself, just bought one! :)
pulplogic
Post by pulplogic »
aladan wrote:That's way cool... couldn't stop myself, just bought one! :)
Thanks, here are a couple of assembly pictures:
Cut the tabs down so they don't contact the piezo sensor and solder the ground and signal wires.
The flex tube was scavenged from a broken usb led lamp. Hot glue secures it into the socket.
aladan
Post by aladan »
pulplogic wrote:Thanks, here are a couple of assembly pictures:
Very helpful, thank you!
L-1
Post by L-1 »
Great! Ordered one.
pulplogic
Post by pulplogic »
Here’s a little more info on how to modify the Snark SN-2 tuner.
aladan
Post by aladan »
Still waiting for mine to arrive in Oz *sigh*
makers
Post by makers »
I just did this and it works really well!
joshuagoran
Post by joshuagoran »
@makers did you use a USB lamp flex tube, too, or did you figure something else out? I'm glad to see this dug up, looks like a great tool!
makers
Post by makers »
I used the original arm with a ball joint on each end. I removed the ball from one end so it fit into an 1/8" jack. Then used heat shink to keep those two parts together. The wires had to enter the 1/8" jack through a hole I drilled in the side. Finicky build but it works well with minimal parts. The pitch tracking on the latest model seems very stable.
craigwilliamsmusic
Post by craigwilliamsmusic »
i built two of these (one for me and one for a friend that lent me his 909 and 101) and they work great.
diablojoy
Post by diablojoy »
I panelised an SN-8 version
a couple of months back
added a 3.3v regulator so no battery any more
brought all the switches out to the panel and added an in and buffered through jack
really useful module
also bought a couple of even cheaper ENO music ET-33
tuners , i plan to do the same with them.
joshuagoran
@diablojoy I would love to see a picture if you get a chance! That sounds like a really graceful setup.
squarewavesurfer
Post by squarewavesurfer »
Thanks for this DIY!
ES
Post by ES »
Awesome! Ive been looking for a direct and quick way to tune up my oscillators this is perfect thanks!!!
sduck
experimental use of gravity
Post by sduck »
Just got a superSnark at guitar center - looking forward to doing this mod thing.
mothertongue
Post by mothertongue »
Sweet! I have an extra Snark tuner in my bag :tu:
Mr. Enjin
Post by Mr. Enjin »
That's awesomely simple and cheap! :tu:
widdly
Post by widdly »
This is a neat idead but damn you banana plugs!
:sadbanana:
jgb
Post by jgb »
Must. Have. Tuner! The same procedure for modding the super snarks?
sduck
Post by sduck »
It looks pretty similar inside. I haven't wired mine up yet, but I'd presume it's the same.
Mr. Enjin
Post by Mr. Enjin »
Just ordered 3 of em from scAmazon for 9.95 a pop...extras..ya know, 'cause it seems there's always at least one person in any band that never fecking has a tuner :doh: [/u]
sduck
Post by sduck »
Ok, this was a lot easier than I thought it was going to be. First, I scoured the whole house, trying to find some kind of flexi tube I could use, cause that looks really cool. After spending way too much time doing that, I realized I was probably just overthinking things, and that I could just use the clip that comes with it, attach it to a jack of a clipped off patch cord. So I picked out a suitably colored Hosa patch cord and got busy (purple works best! :hmm: ).
Opened it up, removed the piezo, drilled a hole, stripped the wires, soldered them on, put little bits of electrical tape over the business side to prevent accidental contacts on reassembly, re-attached the little button pieces, reassembled the whole thing, it works great!
The super snark has a little spring thing for the ground contact, otherwise the connections are the same as in the pictures and videos above.
This method might not work so well with euro size patch cords, but with 1/4" ones it's fine.
squarewavesurfer
sduck wrote:The super snark has a little spring thing for the ground contact, otherwise the connections are the same as in the pictures and videos above.
I should have mentioned that my SN-2 (pictured above) also had a spring for the ground contact. This is probably just the way they are making these tuners now.
hangovercat
domestic party animal
Post by hangovercat »
That's going to be super handy. Thanks a ton.
"An idea isn't responsible for the people who believe in it." – Don Marquis
ModularGrid
BandCamp
SoundCloud
