Aalto + Max/Msp + TouchOsc
wednesdayayay
Post by wednesdayayay »
I have been working on this for a while and it is finally getting to be useable
I have several more things planned that i deleted so I can update later
most importantly a modulation matrix for all the attenuators where you attach the patch cords
also integration of the arduino shield "repatcher" firstly for physically controlling aalto paramters with more precision than midi provides but secondly it will allow me to patch the my soundplanes signals around to different thing be it aalto/ effects/ modulation layouts
in the archive you will find two files one is the touch osc template and one is a max/msp patch
you will have to point max to your aalto vst (not component)
you will have to change the ip/port numbers to match your own
you can use this in presentation mode alone
midi map is built in so when the space bar is pressed and you are hovering over an aalto parameter it can be midi mapped by moving a midi controller
I have added a randomize all sequencer values button in the touch osc template
I have added several encoders to act as fine tuners for the parameter they are nestled within (filter cutoff, delay time, env2 repeat, feedback, pitch, ratio, LFO freq, seq rate) each encoder can easily be set to a more or less coarse tuning. a built in mechanism is planned for the update.
All five volume controls are also easily available to use
i have also added a couple extra sliders and toggles for extra control over the sequencer
in the top pair the slider controls the randomization of all 16 sequencer steps in two different ways which is switched between with the toggle to the right of the slider
the first way the slider works is by randomly cycling through different sequencer step numbers and assigning the current slider value to it
the second way uses the [bucket] object to send the current slider value down the sequencer steps right to left (this can be changed)
the slider under that controls the randomization of all 16 sequencer steps in two different ways
the first randomizes every sequencer step upon each movement the value of the slider affects the probability of each step being on/off
the second way is just the same as the first except it only randomizes the steps every 16 values entered into the slider
hope you enjoy
wednesdayayay
here is a video of me messing around with the layout
https://www.youtube.com/watch?v=XG0h0se ... e=youtu.be
oootini
Post by oootini »
wednesdayayay wrote:here is a video of me messing around with the layout
wow. that looks great!
mckenic
Post by mckenic »
How is only NOW Im grokking this!
Thank you!!!
wednesdayayay
the first video is more about showing off the template the other two are me using it for a bit of fun
djorkaeff
Post by djorkaeff »
great work! thank you for sharing!
glia
Post by glia »
wednesdayayay wrote:[video][/video]
when is the new template available?
this is fantastic!
wednesdayayay
here is a recording from last night where I was using a soundplane but not the ipad
I actually am just getting ready to mess around a bit
I kept meaning to sweep through and delete unnecessary things but here it is as I have been using it lately
glia
Post by glia »
THANKS
wednesdayayay
No problem I'm just thrilled people may find this useful
onurkalaycioglu
Post by onurkalaycioglu »
thats a dense touch osc template... awesome.
Return to “Music Software”
