[IN STOCK] L-1 2180VCF Eurorack.
L-1
Post by L-1 » Fri Nov 30, 2012 8:48 am
Detailed info on my site: http://l-1.su/2180VCF.html
I made THAT2180 based multimode VCF. Original design.Two chips used.
It works, sounds clean. Only I need now trim correct CV range. Q and cutoff are CV controllable, LP BP HP outs.
Will post news into this thread.
:sb:
msprigings
Post by msprigings » Fri Nov 30, 2012 9:09 am
Awesome can't wait to hear more details.
NorthernLightX
Post by NorthernLightX » Fri Nov 30, 2012 10:16 am
Great news, now I know what to do with those spare THAT ICs... downside is my backlog just grew even larger :)
Peake
Post by Peake » Fri Nov 30, 2012 11:52 am
This should be good!
Emalot
Post by Emalot » Fri Nov 30, 2012 1:10 pm
L-1 you're a genius!
SMS303
Tha BABELFISH Wiggler...
Post by SMS303 » Fri Nov 30, 2012 1:22 pm
Emalot wrote:L-1 you're a genius!
ho ho..... Albert Einstein and Isaac Newton were real genius'.....
L-1 fully understand THAT2180's and felt in love with them 8_) ;)
Way to go Alex! :tu:
------------> Jaime Murray does Capua...... ------------------------------------------>
Emalot
Post by Emalot » Fri Nov 30, 2012 1:56 pm
Ok, what i want to say it's more:
L-1 tu es génial!
L-1, you propose the best SDIY design this last time!
(Where did you buy your THAT2180?)
SMS303
Post by SMS303 » Fri Nov 30, 2012 2:02 pm
Emalot wrote:Ok, what i want to say it's more:
L-1 tu es génial!
:mrgreen:
hpsounds
the french icelander
Post by hpsounds » Fri Nov 30, 2012 2:58 pm
:eek: :wow:
Hédi K.
wavehead
Post by wavehead » Fri Nov 30, 2012 3:43 pm
what would this filter sound like... anything to compare it to?
it doesn't seem as if there are a lot of options for super precise, clean filters with big ranges (especially band-pass filters). would be awesome if something with the cutoff range, bandwidth and tracking of cwejman BP filters existed. L-1 I'm looking at you!
Post by Synthbuilder » Fri Nov 30, 2012 5:05 pm
I've done this too. I think it was the SVF Issue 4 which first came into being when the CA3280 stopped being produced. Although I liked the sound of it I found the resonance hard to tame when the filter was oscillating - I put this down the insufficient gain matching between the two THAT devices. In the end I went back to the old LM13700. I do still use the THAT2180 in my one pole HP & LP VCFs on the noise module though.
Tony
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Fri Nov 30, 2012 7:43 pm
How would a THAT2180 VCF be all that different from an SSM2164 VCF (of which I've designed and built a half dozen)?
We're a perfect match. Never believe anything else.
wavehead
Post by wavehead » Fri Nov 30, 2012 8:16 pm
dave have you etched up a board for your SVF yet? that looks like a nice contender for a precise BP with nice tracking, etc.
the 2164 does seem like an under-utilized chip that works perfectly for a ton of different uses and I'm surprised to not see more circuits using it.
L-1
Post by L-1 » Fri Nov 30, 2012 9:33 pm
First sample. Not very accurate record sometimes overloaded. Will record better later.
I think I need to reduce Q range.
I feed EG to Q CV and LFO to cutoff CV.
2180VCF.mp3
(4.72 MiB) Downloaded 194 times
Peake
Post by Peake » Fri Nov 30, 2012 10:53 pm
Dr., all OTA filters sound different. I have a Mankato =and= I like the way the Roland 3109 and SSM2040 sound...all different in good ways.
Lutin
Post by Lutin » Sat Dec 01, 2012 9:27 am
I like it! Sounds really pleasant and a bit quirky
frijitz
Post by frijitz » Sat Dec 01, 2012 10:03 am
I tried making a VCO with the 2180. It wouldn't even come close to decent tracking. I can't imagine how a filter could possibly do so either.
Ian
L-1
Post by L-1 » Sat Dec 01, 2012 10:05 am
This is simplified schematic. CV can be temperature compensated with two 2K tempcos.
L-1
Post by L-1 » Sat Dec 01, 2012 11:41 am
I recorded traditional basic patch with this filter. Sounds promised.
2180VCF3.mp3
(2.14 MiB) Downloaded 152 times
L-1
Post by L-1 » Sat Dec 01, 2012 11:55 am
This is the filter itself.
Peake
Post by Peake » Sat Dec 01, 2012 12:56 pm
frijitz wrote:I tried making a VCO with the 2180. It wouldn't even come close to decent tracking. I can't imagine how a filter could possibly do so either.
Ian
I have never, ever come close to even wondering if the Buchla 291 and 292 filters track or not. I just use them and have a blast.
:despair:
L-1
Post by L-1 » Sat Dec 01, 2012 1:01 pm
I didn't worked on tracking this filter yet. But THAT2180 has ideal exponential response. Will post the results.
Graham Hinton
Post by Graham Hinton » Sat Dec 01, 2012 1:15 pm
L-1 wrote:This is simplified schematic.
This is a twenty year old THAT application note and I did it at Solid State Logic ten years before that (with dbx 2150s).
How exactly are you claiming this to be an original circuit?
L-1
Post by L-1 » Sat Dec 01, 2012 1:32 pm
I used the materials of AES 13th international conference signed by Gary K. Herbert and Fred Floru. And calculated all components values from attached equations.
Peake
Post by Peake » Sat Dec 01, 2012 4:34 pm
OTA designs using VCAs are as old as the one used in the EMU modular, or older; I'm not an expert. That doesn't matter.
http://html.alldatasheet.com/html-pdf/9 ... M2020.html
L-1, please enjoy yourself making circuits. Thank you for sharing them.
