CEM3328 Low Pass Filter Boards
executiveBlaster
Post by executiveBlaster »
edit: PCBs have arrived! Built the first one tonight and it kiiccckkss butttt. Pics and samples in the morning!
order list!
synthnut x 2
mono-poly x 2
raisinbag x 1
bjarneroe x 2
krisp14u x 2
dego x 2 & 2 j&p
xpander x 2 & 2 j&p
frozenkore x 1 & 1 j&p
carynrich x 1
if you're not on this list, you and I have made separate arrangements, or I forgot you 8_) I'll update this post when I order the pcbs. Thanks dudes! [/b]
To clarify, the jacks&pots boards are a pcb with footprints for erthenvar jacks and bi-tech pots, with rows of pads on the sides to connect to the main pcb via headers, sandwich style. Together they form a very shallow, 'wireless' module.
Original post:
Hey dudes,
So I have a few (~20) CEM3328 Low Pass Filter ICs, most of which are still safely socketed in my three Ensoniq Mirages. I made these pcbs
which are the filter set up with two cv inputs, one of which is normalled to the output of an AR circuit included on the board (I can't waste opamps...). This chip supports vcresonance, but I didn't include it on the board. It would be a snap to implement with the data sheet (which I'm uploading). Here's a pic of an assembled board connected to another (with the wrong pot footprints :ripbanana: )
I have 7 of those boards left, (and can part with them for cheap!) but what I'm really wondering is if anyone is interested in new pcbs for these chips. It would be a very small run, obviously, unless people wanted the pcbs and could source their own cems (they're out there!) That old layout was fairly random, so a new one could be specifically for skiff-friendly pcbs or whatever format we all agree on.
I'm attaching an audio sample, too, of a diy ota vco through the cem3328, both driven by a diy realtime sequencer (we'll talk about that elsewhere!)[/s]
diy vco through cem3328
eb-short.mp3
(419.42 KiB) Downloaded 159 times
c3328pdf.pdf
(220.16 KiB) Downloaded 125 times
Last edited by executiveBlaster on Fri Mar 01, 2013 4:25 pm, edited 9 times in total.
xpander
Post by xpander »
that's pretty cool! how much trouble would it be to do a run with a corrected control board?
executiveBlaster
None at all, that was the plan!
What format would you want? And would you still want the AR included?
dougt
Post by dougt »
I have a few CEM3328s at $15/ea if people need any for this...
synthnut
Post by synthnut »
I have a few 3328s king about in a drawer, so would bu up for a couple of boards, especially if you impliment the VC resonance too....
I'd only want the basic board as I'll be doing a MU panel rather than Euro for myself.
TTFN,
Ben
www.bigbluewave.co.uk
www.resynthesis.co.uk
mono-poly
Le Cheff
Post by mono-poly »
I'd like a board.
http://www.mono-poly.nl
http://www.noodlebar.org
WTB blue lantern purple vco
executiveBlaster
Cool! I'll PM you both.
Low-Gain
Post by Low-Gain »
I have about 3 mirages worth of these chips.. would def be interested! :)
xpander
Post by xpander »
executiveBlaster wrote:None at all, that was the plan!
euro. i'd rather have an attenuator on the input than an AR.
executiveBlaster
Well that's enough interest for me to do a revised run, definitely! If anyone still wants one of these "old" pcbs, let me know and you can still get it, but the revisions will be better. PCBs take 2-3 weeks to get to me, and I can order them first thing monday. Is that an aight wait for you guys?
@xpander totally, this chip really needs attenuated signal in so that you have fine control over how to pluck it (it really loves to be plucked!) If you're the only guy wanting the control board, you and I may have to work out something separate for those (not a prob, though)
What I'm hearing is:
attenuator on the signal input
vc res and attenuator
Do you guys need your platform specific power headers, or are pads ok? Most of my builds aren't hooked up to a euro busboard, so I don't automatically put those footprints on stuff, but I can.
@low-gain so you want 24? :hihi: jk, unless you do!
Bring on the thoughts there
Low-Gain
Post by Low-Gain »
depending on the price of the board i just might.
can i get a price break? :)
Also, is it the circuit pcb and the control panel pcb?
Maybe you can document a little more clearly as to exactly what this DIY pcb module will have for controls, etc.
executiveBlaster
@Low-Gain
The initial idea was to just be selling the circuit PCB, the "guts". If there's enough interest (so far it's only ol' xpander up there) I can do a control PCB as well, with bi-tech pots and erthenvar vertical jacks.
And yep, there'll be pricebreaks.
"Guts" PCB features:
Cutoff, Resonance, CV w/ Attenuator, CV without
+Sig w/ Attenuator and resonance scaling (see datasheet attached to first post)
-Sig without attenuator or resonance scaling.
Resonance CV input w/ Attenuator
Output
The panel I'd want to make does not include vc resonance though, as it severely complicates (or just widens) the layout. Checkums
Nowhere for poor vcresonance on that panel. I think this:
is wack. (I also labelled the cv input 'res' and the knob 'q' on accident...)
that being said I'm open to suggestions!
Boards will be $10 each or both for $18, + shipping
(cheaper if we get >50! wonder if there are even 50 chips among us..)
Low-Gain
Post by Low-Gain »
well like i said. i have 3 mirages worth. and if it is "tricked" out (which having cv res on the front panel would be nice) i'd likely buy up enough to cover all of my chips. Do i need that many? No. i'd likely sell most of them off as completed modules if you're ok with that.. as a basic.. "short run" of a build.
keeping a few for myself. It would put use to the chips i have just sitting around that i would otherwise likely not be able to get rid of for a value of the work i put into getting them.
executiveBlaster
My thoughts exactly low-gain, and no problem at all. I'm warming up to that second layout, what do you think about it? If vcres makes the difference, it's there!
raisinbag
Post by raisinbag »
Vcres is nice. I have on an evenfall filter and it is a nice option to have.
xpander
Post by xpander »
raisinbag wrote:Vcres is nice. I have on an evenfall filter and it is a nice option to have.
+1
i'm down for 2 sets of main pcb / control pcb / euro faceplates. i definitely think the limiting factor on this module will be the paucity of 3328's.
Dego
Post by Dego »
+1
I want the same. I really want a panel as well.
Low-Gain
Post by Low-Gain »
It makes a lot of sense to have.. But i'd probably put the cv res pot in the middle of the 4 pots..
take a look at panasonic snap in pots too.. I really like them. 50k linears work nicely..
http://www.mouser.com/ProductDetail/Pan ... U1tQ%3d%3d
http://www.digikey.com/product-detail/e ... -ND/243639
raisinbag
Post by raisinbag »
Nice! Blacet-mania! Ya those panasonics are nice. I have only used them on Johns boards, since that is what comes with the kit OR is what the pcb/ bom calls for, they are slick.
executiveBlaster
I'm pretty sure those pots will fit with the footprint I was planning on.
http://www.mouser.com/Search/ProductDet ... EC15BR100K
These are what I use. The footprint is called EVUF in diptrace, leading me to believe it's some kind of standard (EVUF is in the part number for your pots, too)
@Low-Gain you mean like this ?
I'm not crazy about 5 pots in a box like that, visually or spacially, but it might be aight, and I DO love the symmetry.
executiveBlaster
This chip also sports "Custom Tailoring of Volume vs Resonance", meaning that the output signal stays more or less the same volume as you turn up the resonance. It's so handy, as you can crank up into wet squelch without having to adjust anything else.
Here
www.soundcloud.com/executiveblaster
are some examples of what it sounds like. Every song on there uses this filter.
krisp14u
Oakley4All!
Post by krisp14u »
Put my name down for a 2 PCB's :hyper:
Cheers :guinness:
Paul
www.krisp1.com/store/
Low-Gain
Post by Low-Gain »
executiveBlaster wrote: @Low-Gain you mean like this ?
I dig it! :)
frozenkore
Post by frozenkore »
Please put me down for one set (both PCBs and a panel, if offered).
Cheers!
Brian
carynrich
Post by carynrich »
i'll take one circuit pcb, thanks.
