Luka wrote:if it is just gating when the evelope is hit with larger peaks isnt that limiting not compression?
i would think adding an amp at the end of your chain would allow you to amplify the floor and still squash the peaks
it's not just gating on/off, the amount the gain reduction element (e.g. a VCA, or here, a borg2 filter acting as a low pass gate) reduces the gain is directly proportional (and inverted) to the input level.
remember there is no "envelope" module in this patch, only an envelope follower (the VCS patched as such).
as for limiting versus compression, they are both the same. a limiter is just a compressor with a very high ratio. in my patch you can't really control the ratio. you can alter the threshold by how hard you drive the patch. this "thresholdless" type can be found in an 1176 or chandler germ comp.
this patch does tend to darken things up a bit, i am sure it would be different/cleaner if you substituted a VCA for the low pass gate. try it and see! it does also pull down the volume somewhat, but like you say, that is what make up gain is for, and i can do that within the modular itself, or with an external pre.
