machinedrum... mk1 or mk2
ok, i have been drooling over a machinedrum for years and it looks like i might actually be able to afford one.
I have a quick question for others out there in regards to the MK1 or MK2 version of the SPS-1UW.
I have seen a rather sharp price difference between the two even on the used market, and i was wondering what the differences are with the MK2 other than the slimmer profile.
- modularplanner
- Grand Master Flash
The MkI went out of production once they started manufacturing the MkII, so any MkI Machinedrums will have 32 steps to it.
The difference in price on the used market is pretty dramatic right now, and I think it really just comes down to how you intend on using it. The differences between MkI and MkII are subtle save for the 64-step to 32-step sequencer. The UW MkII has a bit more RAM to it and more RAM and ROM slots, but I think 32 ROM slots is more than enough for most and I think many users rarely use more than one RAM machine at a time. Plus the RAM and ROM both share the same memory, so adding more slots and only an extra 0.5mb of RAM doesn't open the floor quite as much as it may seem. Again though, it comes down to how you plan on using it.
ok, the link you sent mentioned that the MK1 has 2 ram machines and the MK2 has 4 ram machines.
Whats that all about
Anyways, to clarify i am to a guy on craigslist who has a SPS-1UW MK1 for a decent price.
Just trying to figure out if i should grab this one for $1300 cash or if it is worth my while to grab one brand new from moog audio for $2000+ lots of tax.
- suboptimal
- A Towering Mediocrity
GeneralBigBag
- My codename's Happy Harry, I'm Into CV
The RAM record machine is set up to sample audio either from the external inputs or resampling from the master output of the MD. Each RAM machine can sample up to 2/4 (mk1/mk2) bars of audio, which can be replayed by as many RAM play machines as you like, each with different settings. Having 2 RAM machines means you can have two pieces of audio floating around, having 4 means you double the live sampling capacity.suboptimal wrote: Each RAM machine can play back a sample, so you get two more with the mk2.
If the money's not a big deal, I would say that this, plus the 4 bar pattern length makes it well worthwhile to get a Mk2.
- sascha.victoria
- deleted/nevermind
There are nice features to the mkII, but none are "necessary", IMO, although I did upgrade to the mkII from the mkI.
However, I would definitely say get the UW. I definitely would not want to be without the sample recording and mangling that's capable with the UW.
- syzygywell
- aligned wiggler
- suboptimal
Congrats on your new MD. I have a pre-UW mk1 and love it.
Most important single piece of advice ever about the MD is that when you are building a new kit, be sure to lower the individual instruments' VOL parameter to about 50% as a starting point. The default settings on the MD are to max out VOL as well as channel level, which gobbles up the instrument's headroom. Turning down VOL to 50% allows for a lot more dynamic control, as well as easing off the digital aggression until you need it. I think a lot of people who don't like the MD sound after playing with it for a couple hours aren't aware of this issue.
comaduster
I recently had to sell a UW MKII. Missing it a ton now.
Great little box.
I'm amazed that nobody ever talks about balanced vs unbalanced connectors when comparing the MK1 and MK2 models. Seems like a big one to me.
I guess that underlying technical improvements can sometimes fall wayside of new features.
It's definitely not worth the price alone, but it rarely comes up.
Great little box.
- stevenclements
I've been jonesing for a Machine Drum as well... I've yet to make the jump... I just wonder how useful is the UW if you have samplers and such that can do pretty much what the UW will do. Granted the 12 bit crunch is nice and I do miss that from the Emax II, but I recently bought an Akai MPC2500 (swing baby) and am trying to justify to myself that the UW would not be necessary... (but I'm sure I'll still want it)
sdc
sdc
life is a treasure... dig it!
acidphakist
- *Probably* not a cyborg.
IMHO the 'UW' is not worth the extra cost. I have the mk2 MD-UW and LOVE it but hardly ever make use of the ROM or RAM machines. I suppose I'm not imaginative enough but the RAM machines only seem to be useful for interesting delay and flange EFX. As for a sampler, I am lazy and use Battery.
Keep in mind I don't play live and don't need a looper. And I also make dancefloor-oriented music so I don't like when things get wonky (think about triggering a 2 bar loop you just sampled but offset and with a different playback speed. Cool, but can you say train wreck?)
I agree, however, that the extra 32 steps of sequencing are worth the price of admission to mk2.
"Will you be my mommy?"
-Nelson Babbon
-Nelson Babbon
