Tap Tempo LFO module
davebr
Post by davebr » Fri May 11, 2012 11:09 pm
I wanted a Tap Tempo LFO module and decided to design one using the Molten Voltage/Pedal Sync MV-55 Tru-Foot LFO chip. I used the "B" version which powers up to the CV inputs rather than the default program. I built the Tap Tempo LFO into a 2U MOTM-style module.
It has both CV inputs and controls for Rate, Ratio, Duty, and Offset. I added level switches for +/-5 volt or 0 to +5 volt outputs. I added an external tap / clock input with an LED to indicate when the LFO is in sync with the external input. LEDs on all three outputs indicate the polarity (red/green for +/-5 volt and green/off for 0 to +5 volt operation).
I used a momentary toggle switch for the tap as I would rather press "down" rather than "into" a module.
The MV-55B does require about 85 mA of 3.3V so I added an option to run the module off of +/-15 volts or +5 and +/-15 volts. I hand wired the board since I was only building one. I have schematics, photos, and a lot of scope images on my Tap Tempo LFO page.
Molten Voltage/Pedal Sync was very quick to respond to all of my emails about the operation of this and their other parts. I have links to both sites on my page.
Dave
numbertalk
Hunnert Buck
Post by numbertalk » Fri May 11, 2012 11:11 pm
Very cool. Thanks for sharing.
boothnavy
Post by boothnavy » Fri May 11, 2012 11:27 pm
Dang Dave, that's smooth like silk, like a glass of milk.
boothnavy - synthesist
www.analogcraftsman.com
msprigings
Post by msprigings » Fri May 11, 2012 11:29 pm
Looks great Dave!
falafelbiels
still learning to wiggle
Post by falafelbiels » Sat May 12, 2012 5:24 am
Mine died on me :eek:
DIY Euro + new cabinet = :eurosmoke:
I'm going to build all over though, likely with all bells and whistles like yours'.
Very neat build!
L-1
Post by L-1 » Sat May 12, 2012 7:57 am
Want to build. Chips are at Smallbear http://www.smallbearelec.com/servlet/Detail?no=929
numbertalk
Hunnert Buck
Post by numbertalk » Sat May 12, 2012 11:01 am
Any chance Dave of doing a run of PCBs for this, either you or someone else? I'd be down for 1 for sure.
MoltenVoltage
Post by MoltenVoltage » Sat May 12, 2012 11:37 am
L-1 wrote:Want to build. Chips are at Smallbear http://www.smallbearelec.com/servlet/Detail?no=929
SmallBear doesn't yet stock MV-55B which is the version Dave used that reads the pots on startup rather than loading program 1 (the chip was designed to also be programmable and MIDI controlled but I made a modified version at Dave's suggestion).
You can email me if you want to order MV-55B at
questions@moltenvoltage.com
Great work Dave!
- William
falafelbiels
Post by falafelbiels » Sat May 12, 2012 6:35 pm
MoltenVoltage
Hey you on here!
keninverse
Post by keninverse » Sat May 12, 2012 9:18 pm
Mr. Dave...it looks like you're using TE headers and connectors. How are these compared to Molex KK MTAs?
davebr
Post by davebr » Sun May 13, 2012 12:41 am
keninverse wrote:Mr. Dave...it looks like you're using TE headers and connectors. How are these compared to Molex KK MTAs?
I am using the TE headers and connectors. I like them a bit better than the Molex. I'm not sure why exactly but the plastic seems to be a bit softer. I have the crimper for them but I always just press the wires in with a small screwdriver and then solder them for a reliable connection. I'm not a big fan of crimp connectors on wires.
I list the generic parts I use on my Parts page.
Dave
sonicwarrior
Post by sonicwarrior » Tue Jun 12, 2012 4:10 am
Nice alternative to the Tap Tempo LFO from Electric Druid.
Would be nice to have a finished PCB for this (gee, I'm lazy).
Soundcloud
Luka
Post by Luka » Sat Oct 13, 2012 7:57 pm
this looks great dave!
