[Order] - Euro Panels for J3RK Crossfader
clarke68
Post by clarke68 » Tue Apr 10, 2012 9:16 am
Euro panels for J3RK's Crossfader PCBs are now available from Synthcube. Panels come in two sizes:
4HP
8HP
Both can operate as a crossfader or a panner, see J3RK's post below for details. Note there has been a recent change to the 4HP panel. I designed these panels with the 9mm Alpha pots in mind. Others may work, but measurements have not been verified.
Pricing is as follows:
4HP is $15
8HP panel is $20
Shipping Info
Shipping rates are per order, for any number of panels (up to a point...very large orders may require a larger box/more $$$, I'll let you know):
U.S. - $5.35
Canada/Mexico - $12.95
All other countries - $16.95
These rates are for USPS Priority, which does not include tracking on international shipments. I've had a few cases where international customers have had delays receiving their panels, and the lack of tracking has been frustrating. If you would like registered mail, tracking, or insurance let me know when you place your order and I'll get back to you with a price.
Also let me know if you'd like to add any other panels to your order, or if you want to combine shipping with an order you've already placed.
When I get your order, I will reply with a Paypal invoice, due May 4, 2012. I'll shoot to have the panel order placed on April 20, 2012 (this will have panels shipping out to you mid- to late May), but the date can move either direction if it makes sense.
clarke68
Post by clarke68 » Tue Apr 10, 2012 9:17 am
Order List
a100user - 1 4HP
asterisk - 2 4HP
bonusplays - 2 4HP
bleeps - 1 4HP, 1 8HP
brother303 - 1 4HP
chocolatyshatner - 2 4HP
corex - 2 4HP, 2 8HP
Dego - 2 4HP
far gon - 2 4HP, 2 8HP
frozenkore - 1 8HP
gwaidan - 1 4HP, 1 8HP
Juxwl - 1 4HP
keninverse - 2 8HP
Lofi Junglist - 2 4HP
microfauna - 2 8HP
mikecameron - 1 4HP
mOBiTh - 2 4HP, 2 8HP
monobass - 2 4HP, 2 8HP
mono-poly - 3 4HP
msprigings - 1 4HP
nangu - 5 4HP, 5 8HP
ndkent - 1 4HP, 1 8HP
norbwuertz - 1 4HP
pheops - 1 8HP
regenbot - 1 4HP, 1 8HP
ringstone - 2 4HP, 2 8HP
spotta - 1 4HP, 1 8HP
synaptech - 2 4HP, 2 8HP
wwall - 3 4HP
I have received payment from the people in blue.
clarke68
Post by clarke68 » Tue Apr 10, 2012 9:27 am
Two new panels:
Turns out J3RK's Crossfader PCB works as a Panner with a slight change to the build, so I designed a panel to suit:
Panner
There's a couple of tweaks I'd like to make (I'd actually like to bump it up to 6HP) but let me know if you have any thoughts.
Modular DJ Crossfader
I don't expect there will be enough interest to run this (would be great if there was, I could use this thing), but I thought I'd show it off anyway. It's wide enough that the PCB will mount parallel to the panel, so it's skiff friendly (16HP). I designed it for a 45mm slide pot, but right now I don't know of any that are "loose" like a regular DJ crossfader. If you know of one, please post...along with any other suggestions.
keninverse
Post by keninverse » Tue Apr 10, 2012 10:03 am
In for two of the 8hp.
corex
scare the dog!
Post by corex » Tue Apr 10, 2012 10:30 am
Is there any way that a two-input, two-output 4HP panel would be possible (maybe replace the inverted mix out with VCA1 & 2 out)? I think it would be sweet to have a 4HP combo module (panner/xfader).
I also like the parallel-mount skiff-friendly version with a slider. I don't mind the graffiti, and there's something fun about the slider.
rico loverde
Post by rico loverde » Tue Apr 10, 2012 10:37 am
i love the dj style, personally i don't know if id do it though as the hp is a bit much for me for a crossfader. although maybe adding a panner to it would make it easier to handle the hp usage. that would take 2 pcbs though i assume. i really like it though. great idea. I'm down for 1 of the 4hp panners and 1 4hp crossfader.
wwall
Post by wwall » Tue Apr 10, 2012 12:52 pm
Can the 8HP function as both a fader and panner, or does the circuit board require too many tweaks to pull double-duty? Maybe J3RK can chime in with some more info. If it can do both with only changes to the I/O structure that may determine whether I go with 4HP or 8HP.
J3RK
Post by J3RK » Tue Apr 10, 2012 12:55 pm
wwall wrote:Can the 8HP function as both a fader and panner, or does the circuit board require too many tweaks to pull double-duty? Maybe J3RK can chime in with some more info. If it can do both with only changes to the I/O structure that may determine whether I go with 4HP or 8HP.
It can really do both, but I would personally want one for each. Maybe 4HP and 4HP.
You'd need the 8HP panel to do both, because you need the individual VCA outs. Basically, you either need to normal (per others' suggestions) input one and input 2, or just cable it (if you have stackable or bananas,) and take the individual VCA outs for left and right. Pretty simple really, but the way I use the crossfader, it would be nice to have it dedicated. (that way you can crossfade filter responses or waveforms, or audio sources, while panning the signal at or near the output. It's all down to personal taste and necessity really.
chocolatyshatner
Post by chocolatyshatner » Tue Apr 10, 2012 4:30 pm
I'd like 2 4hp crossfader panels.
Thonk Support
aka Monobass
Post by Thonk Support » Tue Apr 10, 2012 4:55 pm
I'll take 2 4hp crossfaders and 2 8hp crossfaders
scozbor
100th Member!
Post by scozbor » Tue Apr 10, 2012 6:49 pm
1 x 8hp crossfader :tu:
wwall
Post by wwall » Tue Apr 10, 2012 7:59 pm
J3RK wrote:It can really do both, but I would personally want one for each. Maybe 4HP and 4HP.
If I'm understanding correctly then, the 8HP can both pan and fade. In that case I'd be interested in one of each panel: 1x4HP panner, 1x4HP crossfader, & 1x8HP crossfader.
asterisk
Post by asterisk » Wed Apr 11, 2012 2:28 am
id like 2 of the regular 8HP ones please. (im not sure what i requested before)
msprigings
Post by msprigings » Wed Apr 11, 2012 6:26 am
edited posted again later in the thread.
synaptech
Post by synaptech » Wed Apr 11, 2012 1:36 pm
2x 4hp and 2x 8hp please! :tu:
janvanvolt
Post by janvanvolt » Wed Apr 11, 2012 4:44 pm
1x 4hp
1x 8hp.
spotta
Needs more wigglin' time
Post by spotta » Wed Apr 11, 2012 5:12 pm
1x 8HP xfade
1x 4HP xfade
1x 4HP panner.
Love the Dj style one too :sb:
Spotta
regenbot
Post by regenbot » Thu Apr 12, 2012 1:04 am
2x 8hp i think, maybe hard to decide :hmm:
clarke68
Post by clarke68 » Thu Apr 12, 2012 1:43 pm
Update: quotes are in, and my pricing guesstimates will hold...$15 for the 4HP panel, and $20 for the 8HP. Right now, there is enough interest to do the 8HP run, but not enough for the 4HP. That may not matter...orders have exceeded interest on every panel run I've done so far, but I'm considering the following things:
1. Going ahead and taking orders for the 4HP panel anyway, but people should know that if it doesn't pan out, you'll either need to change your order or get a refund.
2. Changing the 4HP panel to this, which has the same "It's a fader! It's also a panner!" functionality as the 8HP version:
I'm hoping this won't cannibalize too much interest from the 8HP panel. I'd appreciate a few quick thoughts about this new 4HP panel, particularly if it will change your order.
Thanks! I'd like to open this up to orders today...I'm shooting to have everything in this current crop of panels (see my sig) ready to ship mid-late May.
DIY Euro synth panels: Synthcube
clarkerobinson.com - music, video, synth panels, and more!
regenbot
Post by regenbot » Thu Apr 12, 2012 2:00 pm
The new 4hp looks great so i'll take one of each instead of two 8hp.
a100user
All the gear, no idea!
Post by a100user » Thu Apr 12, 2012 4:11 pm
4hp x1 please
I'm looking for nothing at this moment in time
keninverse
Post by keninverse » Thu Apr 12, 2012 4:50 pm
I'll take two of the 8hp.
clarke68
Post by clarke68 » Fri Apr 13, 2012 2:59 am
Okay, I updated the 4HP panel in the first post, and opened the thread up for orders. Come one, come all!
corex
scare the dog!
Post by corex » Fri Apr 13, 2012 1:19 pm
I would like 2x 4HP, 1x 8HP and 1x DJ xfader. If the slider variant doesn't work out, then I will take 2x 4HP and 2x 8HP.
asterisk
Post by asterisk » Fri Apr 13, 2012 8:22 pm
ooh i think i want 2x 4HP panels now...ordering now.
