Is a convolution module possible?
10 Miles High
Post by 10 Miles High » Sun Mar 24, 2019 3:33 pm
Tats developed for Red Bull Academy this thing:
https://www.electronicbeats.net/the-fee ... ike-never/
Granular, but he says convolution also.
10 Mh
wavejockey
Post by wavejockey » Mon Mar 25, 2019 3:34 am
earx wrote:Hi guys,
Anyway.. the biggest design choice is now to go for:
A. full sized version with proper sized display, proper large pots with knobs on them. 500 EUR
B. uVersion, with mini display, naked pots. 350 EUR?
A; full size please
take a look at knobs & OLED in Rossum Electro Morpheus & Assimil8tor
what about loading IRs ? (instead of creating your own)
earx
Post by earx » Mon Mar 25, 2019 3:45 am
tiger001 wrote:what about loading IRs ? (instead of creating your own)
Oh that's already possible. A basic function of any convolution response. Just plug in USB/SD and scroll through them using the rotary encoder..
NS4W
Post by NS4W » Mon Mar 25, 2019 3:53 am
What parameters would be actively tweaked? If its a matter of setup and then just playing I dont mind a small interface. Modules made for wiggling are always nice if they are on the roomy side :tu:
earx
Post by earx » Mon Mar 25, 2019 4:07 am
The Rossum modules look ace btw! Thanks for the tip!
earx
Post by earx » Mon Mar 25, 2019 4:16 am
NS4W wrote:What parameters would be actively tweaked? If its a matter of setup and then just playing I dont mind a small interface. Modules made for wiggling are always nice if they are on the roomy side :tu:
Right now we have the following knobs:
* predelay 0..2000 ms
* envelope attack
* envelope release
* dry
* wet
* inputgain .. this is now digital, but analog would be much better (right?). The idea is to accept both doepfer and line levels.
* stereo width (mid-side)
The following digital controls:
4 buttonleds: Record, Store, Audition (play response only), and one more for which have no idea yet.
1 rotary encoder to select responses from USB/SD/internal. Push it to scroll faster.
And the following CV's:
- HP cutoff
- LP cutoff
- Stereo width
I chose these because in a block convolver it takes time to recompute the response if you apply envelopes, predelay, etc. Filter and mid-side settings are immediate.
Hooft
Post by Hooft » Mon Mar 25, 2019 7:54 am
FULL SIZE please.
It's all about being able to play/perform with.
Related: E-RM Grain Convolver, in depth:
Yup.
cackland
Post by cackland » Mon Mar 25, 2019 9:39 am
Why not have a single control for dry / wet? Also, I would consider having cv over this parameter.
Also, what kind of HP are you thinking for each version? And would the micro version have the same control parameters but with the 9mm song huei potentiometers?
earx
Post by earx » Mon Mar 25, 2019 11:13 am
Dry/Wet on CV sounds like a plan actually! Low pass is probably not useful anyway on a reverb. High pass much more so!
Check out our latest news for a pic of the unit including all the controls. We went for naked Alps pots now. They feel good, but well.. mini is mini. https://www.tastychips.nl/?p=3526
I'm really glad most people here prefer full size!
Thanks for the granular convolver. I actually heard that it was partly inspired by our GR-1. A great thing to be noticed by the Korg veteran designer in this way!
cackland
Post by cackland » Mon Mar 25, 2019 12:24 pm
There is a lot of extra room on that control board.... I would definitely urge to go full size pots, with an improved layout. If this is the 'mini' version, I would be concerned about the regular sized version.
Assuming there will be a secondary component PCB, or will all the components be on the bottom layer?
earx
Post by earx » Mon Mar 25, 2019 1:31 pm
cackland wrote:There is a lot of extra room on that control board.... I would definitely urge to go full size pots, with an improved layout. If this is the 'mini' version, I would be concerned about the regular sized version.
Oh, for sure.. Yeah. This prototype is a single PCB, but already working on a sandwich version. Most definitely will place proper knobs on there. :)
jorg
Post by jorg » Mon Mar 25, 2019 2:53 pm
Dr. Sketch-n-Etch wrote:I'm not interested in digital implementations, but am now quite intrigued about the possibility of an analog approach to convolution filtering.
Well, I suppose you could call all of our analog filters and delays "convolution" but they don't do the sort of general-purpose thing the OP is talking about. With digital convolution, you can model real spaces with uncanny realism. It is pretty costly in CPU, but even little ARM controllers these days are fairly amazing, and might be able to do some limited convolutions. The most important piece is a good FFT.
wsy
Post by wsy » Mon Mar 25, 2019 5:04 pm
There's really several ways to go about this problem, and the best way is different depending on the inputs.
If one or the other inputs is basically an impulse (or a few impulses, at various times) then
the brute force implementation is often faster. Yeah, FFT is O(N log N) but if one input is
only four impulses or something small like that, then log-1 N is sixteen and that isn't a big
window at all. And that's brute force.
If most of the values are exactly zero, then the "brute force" implementation, operating
on a run-length encoded table, is O(N).
Or if all of the values in one of the tables is constant (or slowly varying) then again, it's O(N) [[ run double buffering and crossfadel]].
And now ya got me thinking about this....
wavejockey
Post by wavejockey » Tue Mar 26, 2019 3:00 am
earx wrote: * dry
* wet
- HP cutoff
- Stereo width
if going analog for the input gain means bringing in artifacts and/or noise i would not vouch for it
(if one would like analog gain, that they'll put in a valve before then)
knob 4: shift?
a cv input that can be assigned arbitrary? (like on my ensoniq DP/4)
Paranormal Patroler
Post by Paranormal Patroler » Tue Mar 26, 2019 3:32 am
+1 on the smaller version. If IR and convolution is your thing at the studio there are full fledged options outside the modular. If you're a performing artist that needs convolution (like I am) then a smaller version would be more appealing for a live oriented case.
Just my 2 cents.
wavejockey
Post by wavejockey » Tue Mar 26, 2019 4:03 am
a) what other hardware versions ?
Paranormal Patroler
Post by Paranormal Patroler » Tue Mar 26, 2019 4:33 am
tiger001 wrote:a) what other hardware versions ?
I didn't claim hardware, but I'll humor you none the less. Logidy EPSi is one. Mungo module C0 is another. Software options (as per my studio reference) are abound.
mcnys
Post by mcnys » Tue Mar 26, 2019 5:56 am
i would like a smaller version tbh, and here is why: a convolution reverb is more of a set it and leave it kind of device, not very performable module so smaller footprint makes more sense for me (also cheaper price hehe). Other than that i'm hyped for whatever version it will be in the end.
*puts 50 euro in to the piggy bank*
Paranormal Patroler
Post by Paranormal Patroler » Tue Mar 26, 2019 8:05 am
By the way, IR are really nice for percussion purposes. So a smaller module would also make more sense if want to buy a couple to enhance the sounds of your percussion.
jorg
Post by jorg » Tue Mar 26, 2019 2:20 pm
wsy wrote:...If one or the other inputs is basically an impulse (or a few impulses, at various times) then the brute force implementation is often faster...
Yes but that's not a very general case. OK as a percussive or plucked sound source, but not practical as an effect.
earx
Post by earx » Sun Mar 31, 2019 10:32 am
Paranormal Patroler wrote:By the way, IR are really nice for percussion purposes. So a smaller module would also make more sense if want to buy a couple to enhance the sounds of your percussion.
Ok, noted. But you can already use 2 separate ins and outs on this module. It would probably be possible to have 4 ins and outs as well..
Buyakasoundman
Post by Buyakasoundman » Sun Mar 31, 2019 1:12 pm
YES YES this!!! 4 ins and outs please
wavejockey
Post by wavejockey » Tue Apr 02, 2019 12:54 am
now we are on DP/4, DPSv55/77 & Lexicon territory
if (enough) routing possibilities are available, this is a no-brainer
earx
Post by earx » Wed May 01, 2019 11:16 am
Current revision:
As you can see we went for full sized. Otherwise the user interface would suffer.
This baby can now:
- Record and store responses to USB stick
- "Scan" the envelope over the response, moving it around from early reflections up to the tail. using the pot directly under the display
- And last but not least it can crossfade between two responses in real time. This can also be done using CV.
Another improvement:
It can accept stereo jack input directly from your laptop or phone, or use two separate mono jacks.
Now looking at options to pitchbend the input and output, to keep the response consonant with the input.
The main issue here is the eurorack form factor. I'd actually want to add a crossfader, and a pitch knob.. but where to leave it all? :lol:
brandonlogic
Post by brandonlogic » Wed May 01, 2019 12:09 pm
earx wrote:Current revision:
This baby can now:
It looks like theres space for a new more knobs on the left side?
