Triple Wave Folder - DIY
Anybody here build a TWF? I have a pcb and I'm interested to see the part numbers on your BOM. Especially if you saved it at mouser.
- Thonk Support
- aka Monobass
- Thonk Support
- aka Monobass
not sure yet, but definitely as shallow as poss.. must be some pictures of other euro builds around
- Thonk Support
- aka Monobass
I might actually panel it together with something else.
My TWF PCB just arrived too.
Mounting parallel to the panel certainly makes sense.
Unfortunately, the PCB is just a few mm wide for a 14HP panel, which is why the production model is 15HP.
I plan to add attenuators to each of the Bias CV inputs.
This partly justifies bumping up the panel width a few HP to an even number.
Could maybe also add a 3-channel bi-polar mixer behind the same panel, or one of Negativspace's (2.0) Buchlidian Voltage Processor PCBs.
Any suggestions?
Thinking about laying out my panel in a downward cascade, the opposite of the Toppobrillo panel.
Also, putting the Bias 'All' CV and attenuator inputs, and Input 1B attenuator/Offset at the top.
Any suggestions?
- rico loverde
theres pix of the build somewhere in this threadPF wrote:
This is a custom build that i ordered from a wiggler here.
viewtopic.php?t=49531
- rico loverde
- negativspace
- Manhattan Analog
Here's the pics of my build... I decided to do a parallel-mount on this one just to see if I could. The brackets are all hand-cut from thin aluminum sheet, using heavy-duty kitchen scissors. (Extra high-tech, yo.) I'm not sure I'd recommend it... it looks sexy in pictures but the wiring under the PCB is thick, to say the least, and getting the brackets all made was a pain in my ass. Note the intricate system of washers used as spacers...
Edit: It wouldn't be hard to put holes for standoffs on the panel, I think. I just try to avoid that unless it's completely necessary.
All i can say is....negativspace wrote:Here's the pics of my build... I decided to do a parallel-mount on this one just to see if I could. The brackets are all hand-cut from thin aluminum sheet, using heavy-duty kitchen scissors. (Extra high-tech, yo.) I'm not sure I'd recommend it... it looks sexy in pictures but the wiring under the PCB is thick, to say the least, and getting the brackets all made was a pain in my ass.
They are so good looking....
- negativspace
- Manhattan Analog
Here's what I ended up getting.
Note:
1) I opted not to get the headers for pots and jacks
2) I already have a bunch of jacks I got from here: http://erthenvar.com/
3) I couldn't find a non smd ferrite bead. Anybody have a part number?
http://www.mouser.com:80/ProjectManager ... 180633a056
Note:
- Thonk Support
- aka Monobass
I'll have a new batch of TWF PCBs in stock at Thonk soon, 281 PCBs too.
http://www.thonk.co.uk/product-category/toppobrillo/
- Veteran Wiggler
