Wiard 1200 Series Info
Discussion and support for Wiard Products
Moderators: Kent, grantrichter, carygrace
Babaluma
Post by Babaluma » Fri May 22, 2009 10:33 pm
I thought I'd post all the information I have collected on these modules over the years from the Wiard Yahoo Group and personal emails from Grant.
It would also be good if people would refer others to this post when a similar question comes up again.
This information is from various uncredited authors, but most of it is from either Grant himself or The Good Doc Mabuce. If anyone feels I shouldn't be reposting this info, then please take it down. The reason people go uncredited is that this document has been collected over years and years and has been edited for clarity for my own personal use.
All this info really deserves to go into proper manuals, but as Grant is very busy it appears that they might not see the light of day for some time.
Please add any other info on the Wiard 1200 series only (that includes the original Frac Rack modules, the new Malekko Euro modules, and any other format that might be released in the future), if you feel it is something that is not covered here.
Perhaps we could also use this post to discuss aspects of the 1200 series which we are still not clear on.
I hope this is helpful to some of you!
Gregg
WIARD INFORMATION
NOISE RING INFO:
I am wondering if can anyone explain the relationship between the "Ring" lights and the bits flowing through the shift register. It seems that higher voltages are present when the LEDs are red, but I can't quite understand how the three states (green, red, off) relate to the two states (one, zero) of the shift register.
the shift register is an 8-bit register divided into two four-bit 'nibbles'.
the first nibble is:
do
d1
d2
d3
and the second is
d4
d5
d6
d7
the 4 leds indicate a comparison between the states of the following pairs of
bits:
d0 - d4
d1 - d5
d2 - d6
d3 - d7
using d0-d4 as an example:
when d0 = d4 led is OFF
when d0 > d4 led is green
when d0 < d4 led is red
(I might have the green/red states reversed)
My assumption regarding why Grant used this method is that it is a good indicator of CHANGE - which is the exact type of feedback the user needs to adjust probablility controls. The compromise is of course that it is very hard to determine the exact state of the 8-bit register from this 4-led display. But (i likewise assume) devoting an entire 8-led subassembly and the requisite panel real estate for a direct register display would have been more costly. The 'Goldberg jr.' that i gave Grant in July 2001 had an 8-led direct display but no clock or data indicators. I'm impressed with the efficiency and economy of the scheme Grant devised to get a lot of feed back to the user with just 8 lights and very low current consumption. Hope this helps you 'read' what your marvelous little gadget is doing.
I am having a hard time getting the noise ring to process external data. In particular, I have been unable to achieve the phased sound when patching another oscillator into the chance input jack. When I do this and monitor the main out I hear nothing at all. Has anyone else had this problem? What could I be doing wrong?
1. Make sure the "Change" pot is all the way up (LED full on).
2. Input a VCO 10 volt peak to peak triangle or sawtooth wave into "Chance In" jack.
3. Adjust "Chance" control so some LED signal is seen.
4. Monitor main output and play with VCO frequency and "Rate" setting.
Run an external audio signal of +/- 5 volts into the "Chance In" input jack. This is normalled to the white noise output.
Set the "Change" knob all the way on. Vary the "Chance" control knob to change the sound.
Also vary the "Rate" knob to change the sound. You can reduce the setting of the "Change" control knob as an experiment.
In order to avoid re-inventing the wheel, please read the circuit desciption Grant posted at:
http://www.wiard.com/1200/NR/Noise_Ring.html
i will be referring to the block diagram he posted.
regarding digital noise:
If we force a feature-by-feature comparison of the I.D. and the N.R, the one feature that the N.R. lacks is a 'conventional' digital noise source. The main and aux outputs of the N.R. are both digital noise , to be sure, but they are both variable in spectrum and controlled by the two CV vectors, "Change' & Chance'. This makes them a little different from conventionally produced digital noise sources (such as the now extinct MM5x37 chips).
The Blacet I.D. is a very full featured implementation of a tried and true, time-honored method of random voltage generation in analog modulars. To wit, a noise source (continuously variable between digital or analog) is 'snapshotted' by a sample hold at a voltage controlled sample rate and output as random steps. The pattern of these steps vary in amplitude according to the spectrum of the input noise and , in duration by the clock rate. Thus, the output steps are derived dirctly from the noise sources, analog , digital or some mix of both.
The Wiard N.R. uses analog noise at a basic source point in it's algorithm, but never directly. This noise is never sampled by an sample/hold circuit, in fact there are no sample/hold circuits in the N.R and this is a fundamental distinction. (It will help to consult the N.R. block diagram, at this point) You may already know how a shift register works but for anyone who doesn't, i'm going to use the analogy of a conveyer belt with room for 8 people....
In the N.R., analog noise is used to tickle the threshold of a comparator, the comparator flips on and off producing either 'someone' or 'no one'. depending on the state of the comparator. This person/non-person stands OFF the conveyer belt waiting for a signal. The signal comes from the clock. The clock is also a 2-state device. We'll call them 'tick' and 'tock'. Remember that the clock is not steady. It varies with a CV. This is important. When the clock is in a 'tock' state , nothing happens. The conveyer belt doesn't move and no one steps on. The N.R.'s output is static. But when the clock switches to "tick" the conveyer belt moves one step and if the comparator was tickled to it's 'someone' state, someone steps aboard. If it was in 'no one' state the conveyer moves one step with an empty place. On the next tick the conveyer lurches forward and if anyone was in the last (8th) position they get dumped off. Another thing happens at each tick, the DAC takes a snapshot of the pattern of occupied and unoccupied places on the conveyer, and based on that pattern it sends a voltage to the output, a different voltage for every different pattern, Thus as the two devices, comparator and clock, go on flickering , the conveyer gets loaded with different patterns that SHIFT on each tick. This cycling of patterns is the heart of the N.R.'s method, and this is very close to the classic function of a digital shift register.
But there are some twists! And one of the more brilliant twists that Grant conceived is depicted in the block digram by the line marked 'old data' feeding the "solid state switch' . This is controlled by the 'Change' control. As the 'Change' control vector decreases, the chances INCREASE that the passenger who was just dumped off the end of the conveyer will get another turn and move right back to the front of the conveyer again and prevents any 'new' passengers (from the flickering comparator) from boarding. The effect of this is a 'circular' buffer wherein the pattern repeats ad infinitum until 'new' passengers are re-introduced by increasing the change control. At slow clock rates this results in cycling patterns. At audio clock rates the effect is a clearly discernible pitch. The wonderful thing about this is that the change control vector is continuous and thus, at audio frequencies, random audio (noise) will start to organize itself into a pitched tone. The 'between states' are sublime (to my perverse ear, anyway) and if you descend into chaos again , when you morph to pitch the next time there's no guarantee that you'll get the same wave as before. Please forgive me for editorializing, but the resulting patterns are exquisite!!! i'm sorry to confess my fetish, but that's just the very definition of my personal idea of a good time!
To drag this screed back to the issue of comparison. The method of pattern generation just described is very different than the sample/hold method used by the I.D. (and MANY other RVG is modular synth history). Most importantly, this method yields a very different character of output patterns than a sample/hold-based design produces. The noise sources are never sampled directly and thus, the output SOUNDS different from sample/hold-based output. i've foolishly engaged in past disputes about whether this is can be called 'random' or not, and if it IS randow, how random is it? That's a semantic issue and a waste of time. The bottom line is that the noise ring yields MUSICALLY interesting patterns (to my ear) and that's what matters. In all fairness, Sample/holds yield interesting patterns too (i have 9 versions of them, at last count) but the noise ring's output is distinct from all of them. The other very important distinction is the effect of the ability to exercise a very fine level of control over the 'chance' and 'change' parameters. This is a unique and VERY powerful feature.
The Buchla "Sources of Uncertainty' is the seminal circuit that employs a similar use of noise (as a modulator of the sampled source, rather than the noise being the sampled source itself), and a recursive structure that can create suprisngly musical patterns in the name of UNCERTAINTY, which I think is a better term than RANDOMNESS.
When I use the term entropy I mean Shannon's measure of information entropy, not thermodynamic entropy (which uses a similar equation, the reason Shannon used the term "entropy"). Information entropy is just a histogram of the number of levels in a matrix of information, expressed as the number of bits needed to store that number of levels. If there are only two levels, you only need 1 bit to store it. If there are 4 levels, you need 2 bits to store the information and so on.
The original Buchla 266 presented control of the level entropy of the uncertainty source (from 1 to 6 bits). But there was no control over the frequency spectrum entropy (if you calculated the information entropy of the DFT). The Buchla 265 sample and hold presented control of the time spectrum entropy via the recursion control, but not the level entropy.
The Noise Ring provides both types of control, level entropy via the "Chance" control, and frequency spectrum entropy via the "Change" control.
I don't know if this is scientifically true, but it is believeable that the ear does both types of entropy measurements at a very fundimental level. The ear uses a kind of "battery" system to supply the ear, because blood flow would be too noisy. The ear uses "hairs" to sense both level and frequency information. IF an excited cell uses more "current" than a non-excited one, then the way the ear is structured, the information entropy is proportional to the "current draw" for the two different "hair" structures. One for levels (amplifier cells) and one for time spectrum entropy (cochlial cells). Higher information entropy excites more cells, which draw more "current".
JAG INFO:
The JAG is a new module design that takes any two input voltages, and makes all the inversions and combinations available simultaneously. It is a two input, ten output folder/twister/combiner.
It operates up to a full 20 kHz bandwidth, so you can combine audio waveforms. You could take two waveforms from the same VCO and generate 10 variations. As an effect unit, it is most like ring modulation or other non-linear mixing sound. Makes an interesting fuzz box with 10 output variations.
There is an input polarity switch which switches between a 0-10 volt inputs and +/- 5 volt inputs. Also the 8 outputs can be used to control all 4 ADSR parameters of two envelope generators simultaneously. Combining two LFOs give 10 variations for sweeping and control of parameters. Up to 8 bandpass filters can be controlled by Joystick for generating formants or comb filters (like a phase shifter constructed of individually controllable peaks or notches). You could also look at it as a kind of Cartesian barberpole generator.
The original X and Y inputs are passed through to be used in the patch. Or a second unit with X and Y switched will give another 10 functions shifted by 90 degrees. The output fuctions can also be used as inputs to another JAG for really bizarre shapes.
The most obvious application is for panning. The corner functions supply control for the 4 VCAs, and the edge function supplies a correction function for equal power panning. The function is used to boost the output in the middle of the pan, eliminating the power drop in the middle.
Run the other way, it is useful for Joystick controlled MIXING. For example, running 4 waveforms from a VCO to 4 VCAs allows you to mix them with a Joystick. This is also called "Vector Synthesis" since the Joystick voltages can be replaced with envelope voltages or LFOs. The 4 waveforms could also be the output of 4 different effects units or other waveform processors.
Another example is to use two envelopes as the inputs. This will produce 10 envelope "variations" that can be routed to 10 different parameters in a patch (PWM, filter sweep, filter Q, crossfading between two filters, waveshape control, envelopes times etc.).
If a Joystick is used, it gives you control of patch timbre in real time. Fun when you are running a sequence and dynamically morphing timbres. For example, the four corner or side functions can control all 4 attack, decay, sustain and release times at once. So the single Joystick can give you all possible envelope shapes mapped across the Joystick plane.
Complicated, mysterious, yes, but I also think it will be great fun too. There are 9 LEDS on the faceplate that indicate the output voltages. A great light show, but it also gives an intuative grasp of what is happening.
This experimental module produces 10 complex output voltages from two input voltages. It has 9 LEDs of every color except violet.
The most obvious application is control signals for quadraphonic panning. It also provides the control signals for volume and reverberation control for location modulation. If you have worked with the Buchla reverb module, this allows you to patch up the "Recede" fuction where volume, reverb and panning are controlled automatically.
Using the Borg Filters in the VCA mode also provides the high frequency roll-off with distance cue, which mimics the effect of humidity damping with acoustic signals.
A less obvious application is timbre control via joystick. Since you have 10 crossfading control signals, you can route them to filter frequency, filter Q, PWM, waveshape select, filter type select and anything else. Now you can adjust 10 parameters simultaneously using a single joystick.
> What is the upper frequency limit for the JAG?
The op-amps are TL074s. It should work to about 2 megahertz. IN other words you could process video with it (what that would get you I do not know).
> Will it work at audio rates?
No problem.
> Is it all analog?
Discrete class A circuitry actually.
> The polarity switch switches the INPUTS only. Use in the down position for 0 - 10 volt joysticks and envelope generators.
> Use in the up position for dual LFOs that produce +/- 5 volt waveforms.
> The outputs are always 0 - 10 volts (approx.)
First off the best and easiest way to comprehend the JAG is in a demo. This is one module wherein the visual feedback from the panel LED's are the best way to comprehend the functions. If you know someone with a JAG i urge you to go borrow some time with it. (that will be LOTs more fun than reading this anyway!)
The first, important distinction, is that the JAG is NOT a joystick. It's a processor. (it can even process audio, but for sake of clarity i'm not even going there).
The X & Y jacks are INPUTs, They can certainly be connected to your A-174's but they can just as easily accept a couple of LFO's or Envelopes.
The JAG turns the TWO vectors of control at the X & Y inputs into ten INDEPENDENT output vectors, at each LED (and the two 'invisible vectors of "dome" and "edge") by comparison a conventional Joystick outputs only two INDEPENDENT vectors per module (x & y). You can mult the outputs of the A-174 (to the limit of the joystick's available drive current) but that doesn't multiply the number of INDEPENDENT vectors available.
Those are some of the essential differences. That key word i keep capitalizing is Independent vectors of control; the ability to move one CV up- while moving another down - while holding three other CVs steady- and creating a 'bump' in yet another CV.... ALL WITH ONE MOTION! Combined with a joystick, i find the JAG can output an array of CV's that allow me to rival the level of control over an analog synth that one can exert over an acoustic instrument. Used a different way the JAG outputs enough control to allow you to 'conduct' complex 'ensembles' of multiple voices.
to compare again... with 2 joysticks you have independent mix control over 4 voices (via VCA's). with 2 JAGs you would have independent mix control over 20 voices (likewise via VCA's)
The "Dome" function indicator is the Yellow LED in the middle. The "Edge" function is the inverse of dome (more or less).
BTW, the color mapping of the LEDs is inspired by one of the Chinese color mapping of the "Ba-Gua" or eight sided figure showing the eight possible outcomes of the three "I-Ching" coins. Blue was substituted for black (North). When I mentioned Feng Shui to my fellow engineer Chunning Sang, he replied "Next you'll be telling me you've seen a UFO, only my grandparents believe in that stuff!"
Both Western and Eastern Geomancy are fascinating topics however. It is amazing how much the human belief system has changed over a short time. For example, earlier humans believed that evil traveled in straight lines, and avoided straight lines in art and even fences. This is why much early art contains great complexity (such as celtic knots). It was believed that these highly tangeld lines would prevent the entrance of evil. The idea was so universal that there is a specific word for it, "apotropaic" meaning "intended to ward off evil or bad influences". Rest assured, all Wiard product produce waveforms of apotropaic complexity, and can only be good for you! I am only kidding around, so don't send the guys from the Funny Farm.
BOOGIE INFO:
The two major variables in filter design are the topology and the transconductor type. A transconductor for synthesizers in simple terms is just a voltage controlled resistor.
The Moog transistor ladder, EMS diode filter and the Boogie filter are all 4 pole Butterworth lowpass filters. Each LP filter "pole" or stage reduces the output by 6 dB per octave. What that techno speak means is each time the frequency doubles, the amplitude is reduced by half. Putting 4 stages in series makes a 24 dB per octave filter, or each time the frequency doubles, the output is reduce to 1/16. The Moog ladder uses transistors as the transconductor, the EMS uses diodes and the Boogie filter uses Vactrols as the transconductor. In theory, there should be no difference in the "sound" of all three. But the ear is such a fantastic discriminator, that it can detect the mathematical defects in each design, so they sound slightly different.
The Boogie (from Boog "Buchla + Moog") uses Vactrols as the transconductor. This should be the closest to mathematically perfect, because the photo resistors are true conductors, not semi-conductors used in a current starved mode to behave as AC resistors. Also the Vactrols optically isolate the control signals from the audio path, eliminating any control voltage bleedthru or thumping.
Another advantage is that resistors are not active noise sources like transistors or diodes, so there is much less "hiss" to deal with. There is always some hiss because electricity does not flow in a perfectly smooth stream but rather in "clumps" of various size groups of electrons. When this "clumpy" current passes through a resistor, it produces a clumpy voltage because of Ohms Law (E = I * R). That is called thermal noise, because the molecular vibrations cause the chaotic electron behavior which we perceive as clumpyness. It is actually a chaotic system of coupled oscillators where each molecule is an oscillator, but that is getting too far out.
Semi-conductors have an added noise source which is the "diode drop" a kind of quantum waterfall, where more clumpyness is added as the electron groups try to decide if they are going to go over the waterfall or not. This is where the noise comes from in a reverse bias transistor. You just hook the transistor up in the worst possible way to bring out the quantum waterfall noise.
So the Boogie is designed to have less noise and distortion than the Moog or EMS implementations of a Butterworth 4 stage filter. This may disappoint people who LIKE noise and distortion. My philosopy is to start with the least possible distortion, then use either over driving or special circuitry to add it back in when you want it.
For the technically inclined, have a look at
http://www.musicsynthesizer.com/Circuit ... %20VCF.htm
The opening block diagram is practically a schematic for the Boogie filter with A,B,C and D being the 6,12,18 and 24 dB per octave outputs. The mixing is done externally by YOU. The resistors shown are actual Vactrol resistors in the Boogie design, instead of a shorthand symbol for the OTA's in a 3372 chip. That eliminates about 100 transistors from the signal path, and should be much quieter. Plus the mixer can be VCA based like the Blacet Quad VCA. So a sequencer or 4 envelopes can be used to mix the filter "poles" for filter mode sequencing or envelope morphing.
Here are some operating notes:
This is an extension of the Lowpass Gate technology using a Butterworth circuit instead of a Sallen-Key. But it is still a gate, and goes all the way off. You can use it like a combo VCF-VCA. The Frequency control range is very wide, from off to 20 kHz. The wide range is to accomodate using the 6 dB/Oct output like a VCA. It will gate either audio or control voltages.
You can use it like a Mini-Moog type filter, in addition to using it like a Lowpass Gate.
With high levels of resonance, the filter will produce distortion at the cutoff frequency. This is useful for processing tracks.
The red jumpers on the back control the phase of the 12 and 24 dB/octave outputs. In the bottom position, the phase is inverted. In the top position, the phase is positive. When mixing the different outputs, the inverted phase allows the Matrix 12 type responses. If you move them to the top position, you can use a JAG and 4 VCAs to make a variable slope filter.
For some background information on using the Boogie Filter for other filter types, see:
which is the section from the service manual on the Oberheim Expander filter. Of course the Boogie Filter uses discrete Vactrols rather than the CEM chip for improved noise and distortion. Cell one is the 6 dB output, cell two is the 12 dB output and so on. Notice the inverters on the 12 and 24 dB outputs, which makes the math "trick" work. You can get some idea of mixing coefficients from the resistor values in the summing networks.
> Sorry if it's obvious, but could someone tell me exactly what a low
> pass gate is, and how I can use my Boogie filter as such?
It's a mode unique to photo-electric filters. Any other transconductor (transistor, diode, OTA) can not run to zero control current without making bad things happen to the DC bias and producing 15 volt thumps. But photo-electric filters go completely off (0 Hz). This allows you to use the filter as a combined VCF and VCA.
In the West Coast model, the complex timbres are generated before the filter via complex oscillators, non-linear waveshapers, FM or additive synthesis. The "gate" is then used for final amplitude and spectral shaping.
The Boogie supports both modes, either straight subtractive with a following VCA, like the East Coast instruments, or gating and spectral shaping without a following VCA, like the West Coast instruments.
The main frequency control covers 20 octaves, 0 to 20 Hz, which is 10 octaves, and 20 Hz to 20 kHz, which is another 10 octaves.
To "gate" with the Boogie, set initial frequency to zero and control range to max. Resonance is set to zero. A 10 volt signal into "Control In" will then sweep the filter from 0 Hz to 20 kHz. The 6 dB output is approx. equivalent to the Buchla 292 "combo" mode, and the 12 dB output is approx. equivalent to the 292 "filter" mode. But the Hamamatsu opto- couplers decay in 20 ms., rather than the 200 ms. decay of the VTL5C3/2 used in the Buchla 292C.
One jumper is for the 24 dB output and the other for the 12 dB output. Move both to top position if your mixing with the Blacet Mixer Processor. Leave both at bottom position if you are mixing with the Blacet Quad VCA.
The effect is high frequency roll off over distance with humidity (adds friction to air). That was the error in the speed of sound measurement variation that Newton never solved. It took 200 years after his death to figure it out (according to PBS). The VCA (or Combo) mode is 6 dB per octave, probably average humidity. 3 dB / Oct would be dry air and 12 dB / Oct would be a visably foggy night (just guessing). Also the 6 dB output of the Boogie can be used for the same effect.
To Summarize: Humidty forms a lowpass filter over distance in air. To simulate this effect in panning, use low pass gates (Borg, Boogie) instead of plain VCAs.
I finally got around to writing an Excel spreadsheet to calculate all the gain settings for the Xpander switchable mixer. (See BoogieModes.jpg) That is what that mess of resistors does before UX14, a CD4051 eight way selector switch. A little later I will write a note to show how to add a simple switch between C1 and ground which will add in the other 8 modes for a total of 16. I unitzed the spreadsheet data to use with the Boogie Filter and any 4 input linear mixer. The file is called Multimode.jpg, you will need to view it at the largest size, or download it.
The table assumes all 4 Boogie outputs are connected to all 4 inputs on a mixer with unity gain output and controls calibrated 0 to 100%. The table also assumes the two red option jumpers on the rear of the Boogie Filter are in the down position. 100% means fader is fully on, 0% means fader is fully off. 50% is fader at halfway point and so forth. There are a few 33% settings and a 17% setting. Feel around the suggested starting points for best results.
All of these are only suggested starting points. ANY setting of the mixer faders will produce some kind of filter. As always with music, adjust by ear and personal taste. You may very well discover a setting Oberheim never even knew existed. Consider running the 24, 18, 12 and 6 dB poles through different effects chains. Unlimited sonic possibilities.
Boogie Filter's 16 Different Modes (Both red jumpers must be in the DOWN position):
Out Of The Box:
1) 4 Pole Low Pass:
24 100%
18 0%
12 0%
06 0%
2) 3 Pole Low Pass:
24 0%
18 100%
12 0%
06 0%
3) 2 Pole Low Pass:
24 0%
18 0%
12 100%
06 0%
4) 1 Pole Low Pass:
24 0%
18 0%
12 0%
06 100%
With External Mixing:
5) 2 Pole Band Pass:
24 0%
18 0%
12 100%
06 100%
6) 2 Pole High Pass + 1 Pole Low Pass:
24 0%
18 0%
12 100%
06 50%
7) 3 Pole High Pass + 1 Pole Low Pass:
24 33%
18 100%
12 100%
06 33%
8) 4 Pole Band Pass:
24 50%
18 100%
12 50%
06 0%
9) 2 Pole Notch + 1 Pole Low Pass:
24 0%
18 100%
12 100%
06 50%
10) 3 Pole All Pass + 1 Pole Low Pass:
24 66%
18 100%
12 50%
06 17%
With External Mixing Plus C1 Switched Out:
11) 1 Pole High Pass:
24 0%
18 0%
12 100%
06 100%
12) 2 Pole High Pass:
24 0%
18 0%
12 100%
06 50%
13) 3 Pole High Pass:
24 33%
18 100%
12 100%
06 33%
14) 2 Pole High Pass + 1 Pole Low Pass:
24 50%
18 100%
12 50%
06 0%
15) 2 Pole Notch:
24 0%
18 100%
12 100%
06 50 %
16) 3 Pole All Pass:
24 66%
18 100%
12 50%
06 17%
BORG 2 INFO:
Design Notes: Keeps all the good things from the original design but adds a couple of nice enhancements.
1. The Vactrols have been upgraded to "warp" speed Silonex NSL-32SR3. The module will gate with a 2 millisecond control pulse. This increases the top end usable BPM, which is kind of low with a VTL5C3. Call this one the "better for dance tracks" model.
2. The non-linear circuit elements from the MS-20 resonance loop have been added and that op-amp brought out as an output. This gives you a built in mild distortion device. There is a red jumper on the back that can be moved to disconect the limiting diodes. Dual outputs can be used in stereo.
The Korg MS-20 added some diodes to the feedback amp used to give resonance. The effect is to have the resonance vary with the amplitude of the INPUT signal. So the resonance is self limiting, and you can max it out and it will "squelch" with input amplitude. This feature is controlled by the red option jumper on the back of the Borg 2 modules. With the jumper in place, you will probabaly get better results with the filter AFTER the VCA (assuming a subtractive patch). This way the little circuit will crank the resonance up and down for you automatically, kind of like gain riding. With the jumper moved to a single pin, it will offer all the time "rip-your-head-off" resonance like the Borg 1. Because the Borg 2 IS a Borg 1 with much faster Vactrols and the one added tweak.
Some people are confused thinking this is an MS-20 style filter, but it is a Low Pass Gate with an MS-20ish gimmick.
The jumper on the Borg 2 enables the zener diodes across the feedback op-amp. IN = more MS 20 like. OUT = more like Borg 1
In a Sallen-Key design there are two integrators in series. The Main Out comes from there. The Aux Out comes from the peaking stage which has limiting diodes (remove the red jumper = remove limiting diodes). So the Main Out is filtered where as the Aux Out has more harmonics.
THE WIARD PHILOSOPHY:
I will try to explain a little of the philosophy behind the Wiard modules. It has to do with the "East vs. West" coast synthesizer history. This is an over simplified explaination, some "East Coast" instruments support FM for example.
It really starts with the concept of a patch. In the "East Coast" instruments (basically all synthesizer manufacturers except Wiard, Buchla and Serge) you have a subtractive synthesis patch entirely oriented towards the filter. This is your classic VCO-VCF-VCA connection with ADSR type envelopes. The envelopes generators typically have only a single output. The oscillators usually have very simple waveforms such as sawtooth and square wave. This is what most people are introduced to and why many people are puzzled by more complex instruments like the Wiard. This patch makes sense for playing with a black and white type keyboard. It produce a limited but pleasing range of timbres and is easy to operate and understand.
In the "West Coast" instruments, there are 3 possible synthesis modes. Additive, non- linear waveshaping and dynamic depth FM are the primary synthesis modes. "East Coast" subtractive synthesis is typically not DIRECTLY supported. It was not in the Buchla or Serge (no 24 dB/Oct. resonant filter). Good aproximations of subtractive synthesis can be patch on the Serge with cascaded filters. These instruments are oriented towards controlling with a multiple output sequencer or multiple output complex envelope generator intead of a black and white keyboard. They produce a larger and more importantly, different set of timbres than the simpler "East Coast" instruments.
The classic patch in a "West Coast" instrument involves two blocks. The first is a complex oscillator which supports both non-linear waveshaping and dynamic depth FM (Buchla 259 and Serge NTO). The second signal processor is a Lowpass Gate or "frequency and amplitude domain processor". The primary timbre generation is done directly with the oscillator, and the Lowpass Gate just tweaks the amplitude and frequency character. These two blocks are designed to be controlled by one complex envelope generator with multiple outputs routed to all the timbre factors.
Once again this is a simplifed explaination to illustrate subtle points. Actual usage involves a combination of both techniques.
In the 1200 series we have the groundwork laid for a complex "West Coast" voice. The JAG will convert two simple ADSR envelopes into a multiple output complex envelope generator. The Boogie Filter can be used as a Lowpass Gate but also supports the "East Coast" Moog type subtractive character. The Borg 2 Filter is a classic Lowpass Gate that can also be used like the "East Coast" MS20 subtractive filter.
The icing on the cake is the complex oscillator. The Wiard Synthesizer Mini-Wave and VCO (manufactured under license by Blacet Research) is a type of complex oscillator and non- linear waveshaper already well established. A lot of good work has been done with these Wiard designs. Improving on such a solid base is no easy task.
It would be great if a complex oscillator could support as many timbre modes as possible. Simultaneous support for multiple non-linear waveshaping, dynamic depth PM and wavetable would be ideal. If each of these was independent, you could look at them like geometric axis. Modulating the timbre parameters then becomes a matter of "walking about" in a large timbre space with multiple dimensions of simultaneous control. This is true timbre morphing and not just simple crossfading between timbres (which is good too).
This is where my research is currently focused. Exactly when the complex oscillator will be finished depends upon sales of the existing 1200 series modules. If the public is not interested in the extra "West Coast" synthesis methodology, it would be foolish to waste time and money on products for that purpose.
"East Coast" designs are as common as dandelions, but I feel support for subtractive synthesis should be included in a complete instrument. That is why the Wiard designs support BOTH East and West Coast synthesis methods. For example, any Wiard complex VCO will include classic subtractive waveform outputs in addition to the complex outputs.
I think that I need to focus on education to promote the idea of the more complex synthesis "West Coast" style. I am going to try and write manuals for the Boogie and Borg 2 modules that cover the less obvious operating modes. For the short term, I will be concentrating on that.
As always, thank you to all you fine people for your continued support and all the amazing music you have sent me. Keep up the good work and thank you again.
Some more comments on "West Coast" techniques.
The main difference between the two techniques are how the filter is applied. In "East Coast" technique, you start with simple waveforms and used the filter to do your timbre control. The classic East Coast patch is VCO - VCF - VCA with ADSR envelopes for the VCF and VCA.
In one of the "West Coast" techniques, you start with complex waveforms and use the filter just to do final tone shaping. Of course crank up the resonance if you want to mix the two techniques.
How do you get complex waveforms? The Wiard-Blacet Mini-wave or 300 series Waveform City is a good source of complex waveforms when used as a wavetable playback device. These complex waveforms can be made even more complex by the use of synch and FM at the same time. The Mini-wave/Wavefrom city can also be used as a wave multiplier for non-linear synthesis.
Here are a couple of simple patches that are "West" sounding.
VCO(sine) - VCA - LINFMVCO(sine) - Borg in lowpass gate mode (VCA).
You use the first VCA to dynamically control the depth of linear FM. Envelopes are routed to the FM depth VCA and to the Borg tone shaper. The use of sine waves produces "nice" sounding FM along with the soft Borg envelope. With the first VCO set to about 7 Hz and the linear FM control of the second VCO barely open, you have dynamic and natural sounding vibrato.
VCO(sine) - LINFMVCO(sine) - VCA - Mini-wave(+/- 5v) - Borg in lowpass gate mode (VCA)
This is a fixed depth FM patch going to a dynamic depth wave multiplier. Envelopes are routed to the first VCA and to the Borg. The VCA before the Mini-Wave needs to have controls to set initial volume and control the amount of envelope (like an ARP 2600 VCA has). You want to adjust the VCA so it is about 20% on with no envelope. Then adjust the amount of envelope sweep to your taste. You can play with any bank or wave in the Mini- wave but Bank 13 is designed just for this use.
Banks 0 to 7 of the "Socket Rocket" chip are designed to process audio input. In this case the VCA is set 100% on. Bank 6 "Bit Decimation" can really make a drum track gnarly when set to 4 bits or less. One thing to look at is the "Socket Rocket" users manual. This is a 10 meg pdf file:
http://www.musicsynthesizer.com/DIY/Gra ... nthdiy.htm
and scroll to the bottom under "Discontinued Products" Right click on "Socket Rocket Final Manual" and save the pdf file to the desktop or your prefered location. This has ideas for using the waves in the Socket Rocket chip. I used an ARP 2600 and 1630 sequencer to reference the patches.
FILTERS IN MUSICAL TERMS:
It may be helpful to discuss filters in musical terms, rather than engineering terms.
Two 12 dB/Oct filters can always be put in series to make a 24 dB/Oct filter. "Compound" filters like this are essential to really creative synthesis. Another example is a bandpass filter in parallel with a lowpass filter. The reason for this is to make a Formant. Using the lowpass with resonance, and offsetting a parallel band pass with resonance you get a formant. Drive both with a narrow pulse wave and you have a primitive voice synthesizer that can give you vowel like sounds (if the filters are tuned properly). Using a Joystick to control each filter allows you to "speak" different vowels (well, like EEEE and AAAA). If you have two filters try it, it's fun.
A waveform processed by a 12 dB/Oct filter will have stronger harmonic content relative to the fundamental. The tone will be "brighter" in musical terms. These voices are usually used in the treble register as lead voices playing the melody or counterpoint.
A waveform processed by a 24 dB/Oct filter will have weaker harmonic content relative to the fundamental. The tone will be "darker" in musical terms (more muted). These voices are usually used in the bass register for the bass line. The strong presence of the fundimental makes them good for bass lines. You can also take the sine wave output of the VCO and mix it with the filtered tone. This give independent control of the balance between fundamental and harmonics.
The Wiard Boogie Filter provides simultaneous outputs for 6 , 12, 18 and 24 decibels per octave. It's an alternate reality filter which answers the question "What if Don Buchla had designed the filter for the Minimoog?". It is suitable for use in both the bass and treble registers, and as a lowpass gate. Decay time is 20 ms. compared to the 200 ms. decay time of the Buchla 292.
I deliberately designed a series of modules to compliment the Blacet line. In particular, I concentrated on controllers for Blacet modules acting as audio generators. I also added a really phat Moog style filter.
The Joystick/JAG combo is a genuinely new controller system that produces morphing tones unlike any synth before now. Of course, with 10 outputs, you need a lot of patchcords (twelve if you count the 2 original joystick axis, which are passed through by a multiple). One customer has even built a complete 2600 style instrument, centered around the JAG and Joystick. Google "Auralesque" in the next few weeks. The JAG is built entirely of 1% metal film resistor for stability and accurate computation. All of the 1200 series modules use only 1% metal film resistors.
FILTER TRICKS:
Running two borgs in parallel produces astonishing stereo images, from natural spacializing to sweet resonant phasing effect when animated...
It's also possible to create some really beautiful and precise harmonic/formant structures when mixing the boogie's and the two borg's outputs in parallel and setting one of them to track the keyboard. (btw my borgs sound a bit different, the last one I received distorts more easily, but with a more crunchy sound, and allows to highlight specific harmonics more precisely, with an even more "woody" sound than the other (!))
I've also been able to find a very convincing cello sound with the boogie as a control source : use the boogie to shape white noise (find the right mix of its four outputs), control its frequency with an eg (I used the very nice bananalogue vcs for this, too sad it's output isn't normalised to the "both" input...), and crank up its resonance. Then patch the mixer's output to the control input of a borg, the vactrols will do the rest ! (adjusting the boogie's parameters allows for a lot of funny effects, like when the borg's vactrols won't be able to track anymore, but there's a sweet spot where the attack is a cello one !) (the other borg is used as tone/body shaper, and the sound source is the sine output of a fixed frequency vco, fm'd and sync'd by a tracking vco/miniwave).
As for the noise ring, it conducts bird singing very convincingly, especially when the miniwave is used as a transfer function device in order to get different probabilities' distribution...But I like it mostly as control source modifier/exciter and tone source (in which case I patch a note-on pulse to the ext change input, to get that ever phased-out sound without clicks)...(It woud be great to have a jumper on its back, allowing to use the clock output as a clock input?)
A Dingleberry Monstrosity
eat the kids first
Post by A Dingleberry Monstrosity » Fri May 22, 2009 10:34 pm
mother of god
We make guitar pedals: whimsymachines.com :party:
panda30y
Post by panda30y » Fri May 22, 2009 10:48 pm
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
DAMN! Very nice, someone should sticky this work of art.
Pockets McCoy
Boll Weevils In Yo Field
Post by Pockets McCoy » Fri May 22, 2009 11:50 pm
Good lord, man...this is like the Wiard version of the Serge spreadsheet. Ridiculously informative, unfathomably interesting, brain-shatteringly complete.
I'm kind of stunned... :eek: :goo: :sb: :hail:
Oh, and THANKS!!!
felix
Loves the manuals!
Post by felix » Sat May 23, 2009 1:14 am
:hail:
Kwote
Voltage Controlled Crackpot
Post by Kwote » Sat May 23, 2009 1:21 am
i'm too tired to take all that in, but hell yes sticky this shit immediately. i'll be reading shortly. possibly printing. heh.
Self expression is as essential as breathing
kwotemusic.com
my other sites
felix
Loves the manuals!
Post by felix » Sat May 23, 2009 1:23 am
haha, I forgot I'm a mod in this subforum!
STICKIED! :party:
Kwote
Post by Kwote » Sat May 23, 2009 1:24 am
felix wrote:haha, I forgot I'm a mod in this subforum!
STICKIED! :party:
i think it's a sign. :hail:
kwotemusic.com
my other sites
Babaluma
Post by Babaluma » Sat May 23, 2009 1:29 am
this info regarding the borg2 is still a little confusing to me, so i thought i'd try and make it a little easier to understand:
borg2 aux out = the direct sound of the filter from the peaking stage (less filtered/more harmonics)
borg2 main out = as above but run through two integrators in series (more filtered/less harmonics)
borg2 jumper in = zener diodes across the feedback opamp (more limiting/distortion a la MS20)
borg2 jumper out = the limiting diodes are removed (higher resonance/screaming a la original 300 series borg).
things which are still not clear to me: does the jumper only affect the aux out? or is the aux out the same as removing the jumper?
maybe malekko could jump in here?
plord
Wacky for Wiard Wiggler
Post by plord » Sat May 23, 2009 10:49 am
Thanks baba, there is stuff in here that I don't even have in the master wiard-list-tips file. Mind if I add it?
Babaluma
Post by Babaluma » Sat May 23, 2009 11:11 am
not at all, please go ahead. like i said before, some of this comes from private emails with grant, the rest was saved as it was posted, or trawled for after the fact, from the wiard yahoo group.
btw, if there's 1200 series info that you have that you would like included here, then please either post it, or pm it to me and i'll add it to the top post.
hpsounds
the french icelander
Post by hpsounds » Sat May 23, 2009 11:23 am
Nice !!!!
:hail:
Many thanks !
Hédi K.
chamomileshark
Post by chamomileshark » Sun May 24, 2009 5:50 am
Fantastic, I was wrestling with the noise ring only last night. I didn't realise that the Borg 2 aux ouput was different!
Kwote
Post by Kwote » Mon May 25, 2009 8:22 pm
goddamn. i'm still too lazy to read this shit. oh well. time should whip me into shape sooner or later.
kwotemusic.com
my other sites
Babaluma
Post by Babaluma » Wed Jun 03, 2009 5:02 am
no takers on my question re: the borg? surely we have some more tech savvy dudes than i here?
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Wed Jun 03, 2009 9:23 am
Noise Ring modifications-
Today i soldered a switch where the red jumper goes at the back of the pcb- the jumper lets the user select between forward data recycling and inverted.
It's really useful to have a switch there!
I'm building a small panel for it, plus, since my Noise Ring is the 6 jack version with no Noise Output, i soldered a wire from J11 on the board, which is the Noise Test jumper. Now i have a direct noise output. I'll wire a pot in there for volume, and i think i'll mult the noise jack so i have multiple noise sources (only one of these will have the volume pot).
I will post some demos of the differences between forward/inverted data recycling & some photos showing the modification procedure, should anyone want to try it out. It can make the Noise Ring even more bizzare & is definitely worthwhile.
I'd also like to find out what can be done with the expansion/test socket on the back.
Babaluma
Post by Babaluma » Wed Jun 03, 2009 9:35 am
sounds great!
ndkent
Post by ndkent » Sun Jul 12, 2009 6:15 pm
Regarding the Boogie, does "C1 Switched out" refer to both jumpers inverting the outputs? Or is it some kind of legacy info from the CEM chip that doesn't apply to the Boogie?
mono-poly
Le Cheff
Post by mono-poly » Sun Jul 12, 2009 6:20 pm
Yeah Maleko should really put that jumper in front as a switch.
IMHO all jumpers should be replaced on all modules with a switch.
http://www.mono-poly.nl
http://www.noodlebar.org
WTB blue lantern purple vco
Cybananna
Funniest Guy
Post by Cybananna » Sun Jul 12, 2009 8:53 pm
Nice info thanks! :banana:
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Mon Nov 23, 2009 9:18 pm
Babaluma
Post by Babaluma » Mon Nov 23, 2009 9:29 pm
great mod!
Roycie Roller
Death Row Wiggler
Post by Roycie Roller » Mon Nov 23, 2009 9:40 pm
It's a lot of fun switching between the two modes. You get some really crazy patterns going.
sonicwarrior
Re: Wiard 1200 Series Info
Post by sonicwarrior » Sun Feb 14, 2010 8:40 am
Babaluma wrote:Image
Can you export the original source to GIF or PNG?
JPG is a bad choice for a black and white only image. It looks unsharp because of that.
fengland
Post by fengland » Tue May 10, 2011 2:16 pm
this is an old post but thanks a lot for this. great summary of the differences between east coast and west coast synthesis. I know of Buchla and heard music made on them but I didn't realize it was a whole different synthesis approach. this is giving me new inspiration for building and using my modular! thank.
Return to “Wiard”
