Random looping 16-step sequences
Tombola
Post by Tombola » Wed Feb 01, 2012 6:03 am
***UPDATE: Latest details, PCB etc now here: viewtopic.php?t=60740
Quite pleased with how this is coming along - inspired by Wiard Noisering / CGS Gated Comparator / Navs Bitsy module
Bricks
paper kettle
Post by Bricks » Wed Feb 01, 2012 6:09 am
:sb: :sb: :sb:
JP
Post by JP » Wed Feb 01, 2012 9:55 am
:yay:
glitched01
Post by glitched01 » Wed Feb 01, 2012 11:48 am
This is exactly what I've been wanting to build, but had no idea how! Highly interested.
Tombola
Post by Tombola » Wed Feb 01, 2012 12:18 pm
glitched01 wrote:This is exactly what I've been wanting to build, but had no idea how! Highly interested.
Will definitely post a schematic. It's quite a fun thing once it gets going - the button programming bit took about 10 minutes to add and is really nice. Also surprisingly easy to add steps - could make it a 32 step sequencer with two extra chips.
regenbot
Post by regenbot » Wed Feb 01, 2012 12:46 pm
wow, that looks really great. You have to get into pcb making business with all these great projects you do :tu:
J3RK
Post by J3RK » Wed Feb 01, 2012 12:59 pm
Very cool! I'd love to build one of these. If you like, I'd be happy to lay out a board, and send to you/post the gerbers here at some point. Just have a couple of other things to finish up first.
mckenic
Post by mckenic » Wed Feb 01, 2012 1:06 pm
Ooh Err!
Is the button press re-randomizing each time? Is the output quantized because it sounds WICKED!
If you do a kit/ANYTHING with this - PLEASE put me down for one!!!
Great stuff indeed! :tu:
ATOM
Post by ATOM » Wed Feb 01, 2012 1:06 pm
Really cool.
Please make a pcb for this one.
ATOM
http://atommodular.blogspot.com/
"One day we will be improved"
pulse_divider
Post by pulse_divider » Wed Feb 01, 2012 1:10 pm
Yeah, this is fantastic. I'd also love a PCB if you make them.
asterisk
Post by asterisk » Wed Feb 01, 2012 1:14 pm
nice, i love the blinkin lights
surgesg
Post by surgesg » Wed Feb 01, 2012 1:22 pm
really nice - would love to see/hear more
Navs
Post by Navs » Wed Feb 01, 2012 1:41 pm
Bloody. Marvellous. :yay:
Put me down for a PCB too :lol:
Tombola
Post by Tombola » Wed Feb 01, 2012 1:44 pm
mckenic wrote:Is the button press re-randomizing each time? Is the output quantized because it sounds WICKED!
The output is going through an A156 a quantiser, but it is a stepped output, doesn't sound that much different without.
How this works:
The shift register is like a ring, 16 steps long. Each step contains a 0 or a 1.
8 of the steps are connected to an 8-bit Digital to Analog converter.
So, imagine the sequence is this:
1000000000000000
With the DAC looking at the first 8 bits - it sees 10000000 - which is 128, so it will output a roughly half-scale voltage - about 4 volts.
The clock ticks, the shift register moves on in a loop, with no new data added. It now says:
0100000000000000
The DAC 'sees' 01000000 which is 64, quarter scale, about 2 volts.
And so on.
New data gets into the ring in two ways at the moment.
There's a switch to fill it with random bits (provided by a wogglebug burst output at the moment) - leave the switch open, and it just creates a string of random notes. Close the loop, and it stops adding new data, but loops the existing sequence.
The two buttons in the top video let you add zeros and ones to the sequence. The right button adds ones, the left button adds zeros.
I want it to be controllable, but not programmable, if you see what I mean. So you can steer it in a direction, but not sit there tapping in melodies in binary.
Pfurmel
Post by Pfurmel » Wed Feb 01, 2012 2:02 pm
This is deadly, excellent work.
iopop
Post by iopop » Wed Feb 01, 2012 2:11 pm
Great experiment!
Interesting idea to let the shift register have 16 bits but only using 8. When using the external input, you load one bit per clock?
lms.ktp
Post by lms.ktp » Wed Feb 01, 2012 2:11 pm
What a beauty :sb:
ossi_fx
Post by ossi_fx » Wed Feb 01, 2012 2:23 pm
Oh jeah, can´t wait schematic for this one :hyper:
Great job!
papercutnoise
Post by papercutnoise » Wed Feb 01, 2012 7:17 pm
Been dying to see a schematic since I first read about this on Nav's. Count me in for a pcb too :)
Good Transactions with: Pfurmel, Parallel Worlds (x2), Miditerranean, Ping Panic (x2), Soy Sos, jenamu6, READYdot, Poladark, Synesthesia, audioCTRL, dansna, Glitchmachines, RealDudes, wavecircle, msh
Isaiah
Post by Isaiah » Thu Feb 02, 2012 4:10 am
Good work!
This is similar to a circuit I've been working on for a while.
Mine is a 4-stage Serial In/Parallel Out SR similar to Ken's Gated Comparator, but with the Data input normalled to an in-built noise source.
There is manual and voltage control over looping the binary states held in the 4 stages.
Each stage has a Gate output and a pot to generate CV.
There is a CV output and an output for the noise source.
I also plan to add some other functions to the module, maybe a binary counter, I'm really not sure yet...
FetidEye
demonic space drone
Post by FetidEye » Thu Feb 02, 2012 4:22 am
very nice! would also like a pcb if happening :)
Thonk Support
aka Monobass
Post by Thonk Support » Thu Feb 02, 2012 4:45 am
very nice Tom, is this another Arduino/ATMega based project?
Tombola
Post by Tombola » Thu Feb 02, 2012 5:50 am
Monobass wrote:very nice Tom, is this another Arduino/ATMega based project?
No, this is proper hardware - a few CMOS chips.
Problem with software is people come over and crash it when you're doing a demo!
neilbaldwin
Post by neilbaldwin » Thu Feb 02, 2012 6:31 am
Yeah, great stuff Tom.
I'm still getting my head around your reverb driver - going to attempt to just build it on strip board as a personal challenge - so I'll wait patiently for a possible PCB of this one. :hihi:
Slightly off-topic: from a friend on here I know what your 'proper job' is so I was wondering how you ended up with electronics skills? Self-taught? I only ask because I find your stuff inspiring - it's where I'm trying to get to with my DIY, in very small frustrated steps :hihi:
Thonk Support
aka Monobass
Post by Thonk Support » Thu Feb 02, 2012 7:20 am
Heh, don't let Spandex touch it, he'll coax out hitherto hidden magic smoke.
