3d image manipulator << SOLVED! >>
smrl
Post by smrl »
lizlarsen
Post by lizlarsen »
It's hard to say without a closer look at the names on the controls and jacks, but that looks awesome! It definitely looks like a vector monitor setup of some kind.
daverj
Vintage Video Wiggler
Post by daverj »
The left side looks like a Tektronix X-Y display (or a clone of it).
The company still exists but just makes professional LCD monitors. No sign of what that item was. It has the feel of a piece of test equipment for a government contractor.
smrl
Post by smrl »
Well, I spent the :75: because curiosity got the best of me. I'm glad I did.
and here's some 3d feedback:
Matos
Modular masturbator
Post by Matos »
Cowabunga! Thats awesome. Glad your gamble paid off.
bitSmasher
Post by bitSmasher »
Far out...
:woah:
Bet it has a huge amount of potential for rescanning!
smrl
Post by smrl »
Also, yes, the X Y and Z inputs on the back are summing. I need to drive them with at least 5v though. They seem to be high bandwidth but all I'm testing with is ramps into video encoder into video IN & oscillator into voltage bridge to amplify, to the other inputs. It looks like freq. response is rolling off around where the '074 usually does, so it's hard to tell.
smrl
Post by smrl »
http://www.datasheetarchive.com/6125A-datasheet.html
Check out the application notes -- it looks like this device was pretty much pulled directly from it. It's got several cards on the inside with these epoxy-potted modules on them -- beyond these 'black boxes' it looks fairly straightforward. The good news is that it looks to be all voltage-controlled already so modding this thing for external control should be simple.
daverj
Post by daverj »
That's a pretty cool module
i.m.klif
Post by i.m.klif »
these guys seem to have over 5000 of these chips!
i asked for a quote
http://www.solarelect.icsupply.com/item ... 0AF0530%7D
smrl
Post by smrl »
Yeah, and they also have 4027 CEM3379's! ;)
I sent a quote anyway, if they have them I might have some idea of what to do with 'em...
Veqtor
Post by Veqtor »
Wow, it would be cool if a module was made using em. I think a x and y ramp rotator could have many uses, not just vector rescanning!
Hell, it could probably even have some uses for audio waveshaping.
lizlarsen
Post by lizlarsen »
No kidding!
i.m.klif
Post by i.m.klif »
i just got a reply from chip dealers..... they don't have any left.... :bang:
still, the chip pdf is a nice reading. it explains a logic begind a 3d image rotation in a form of a short abstract.
lizlarsen
Post by lizlarsen »
My partner Ed sent me some notes on this. You could do what this chip does (XY ramp rotator) with the waveshaper portion of our Video Colorspace Modulator module and a 4-quadrant multiplier (something we have on our development list.) We tried a patch out like that recently, but only had the 2-quadrant multipliers (VCAs) in our TVFKG modules to use. Here was the result, driving a vector monitor:
https://www.facebook.com/photo.php?v=3065613327786
(The video is on Facebook, which I don't think I can embed directly, but should be publicly accessible.)
i.m.klif
Post by i.m.klif »
mmmm nice :)
Veqtor
Post by Veqtor »
creatorlars wrote:My partner Ed sent me some notes on this. You could do what this chip does (XY ramp rotator) with the waveshaper portion of our Video Colorspace Modulator module and a 4-quadrant multiplier (something we have on our development list.) We tried a patch out like that recently, but only had the 2-quadrant multipliers (VCAs) in our TVFKG modules to use. Here was the result, driving a vector monitor:
This is incredible.
So, how would one go about colorizing this stuff?
It would be interesting if there was a way to finally bring in vector information into a digital domain, perform real-time segmentation etc like you can do with point cloud data from the kinect...
You could then use a feedback loop like the one above to generate geometry that is then rendered with shaders etc.
*I will look into it.
smrl
Post by smrl »
Yeah. A few of us have been looking into using FPGAs to do whatever data transformations into a framebuffer, at which point you could send it to multiple outputs or synthesize a color composite video image, etc. If you wanted to keep it in the analogue domain, the simplest way is really to rephotograph it and colorize that image.
Also there are 3d vector monitors, used in older arcade machines. That could be a possible source for colorized vectors. They're pretty rare.
Side note: I've added voltage control to almost all the parameters on this piece! Haven't yet stiched it back together. Works brilliantly tho!
lizlarsen
Post by lizlarsen »
That's looking great smrl!
You can run it through modules in the same system to do the analogue colorization. If you're rescanning that means you need two source cameras (or a video feed and a camera). There was a period in the late 70's at EVL when they did a lot of work with generating vector graphic animations using a computer and vector monitor, that were then colorized using the Sandin Image Processor. Such as this collaboration between Tom DeFanti and Dan Sandin:
macumbista
Post by macumbista »
smrl wrote:http://www.datasheetarchive.com/6125A-datasheet.html
Hi. Late to the party! What IC are you speaking of? The link gives me some random diodes.
Your machine looks very similar to this one:
http://www.hologlyphics.com/OEI_3D_Display_Modules.pdf
I'm trying to reproduce its functionality on audio domain signals in Pure Data at the moment so any info resources help. I'd love to check the application notes you have mentioned. Thanks!
Esoteric drones and nonlinear distortion
Custom, handmade experimental instruments
http://macumbista.net
smrl
Post by smrl »
Yes, internally it is all OEI modules on daughterboards. It's just branded Data Check. I don't know if there were other manufacturers or not.
download.php?id=11757
There is the documentation, also at one time I had the OEI 6125A datasheet (which is the rotator IC) and it has a 3-axis rotation diagram in there as well. I can't seem to locate it online any more but only just briefly tried to look - if you can't find it i'm sure I have it saved somewhere.
macumbista
Fantastic thanks for all the details! Everything except the video scan processing can be done in the audio domain, and I'm thinking of some "slow scan" tricks to get primitive video in as well. The PDF you attached here is definitely helpful.
macumbista
Ah and now I see the actual OEI 6125A datasheet at the bottom of the page!
Yes the same info is in your PDF and in the OEI_3D_Display_Modules.pdf I linked to as well on Walter Funk's page.
Return to “Video Synthesis”
