Envelope Generators With Freerun option?
goom
Post by goom »
I'd like to have a freerun EG option. This will allow the EG to continue it's whole ADSR cycle even if the gate is removed before the cycle is complete. It would be best to have it as a switchable (on-off) function.
Does such a beast exist in the modular world? If one doesn't exist, would it be possible to build a helper circuit to mod an existing EG. I'm using MOTM and Oakley EGs.
diophantine
Post by diophantine »
I suppose it would need to be something like Korg's ADHSR, as found on the MS-10 and MS-20, where H is the "hold time": basically time it adds onto the input gate length.
Otherwise, the EG's "S" portion doesn't know how long to run (and would, by default, be zero).
I'm not sure of any modular EG that provides this explicitly.
The Universal Event Generator could give you the equivalent of an ADHSR, but it would be on 100% of the time (unless I'm forgetting a mode on there).
e-grad
Post by e-grad »
That's not possible for an ADSR which needs a gate for the sustain.
All stages are time based except for the sustain stage which determines the output level. The sustain's time is dictated by the gate length minus the attack and decay stages; the output level during the sustain stage is set by the sustain pot.
Avatar: A lusona by the Chokwe people.
elektrograd
e-grad
Post by e-grad »
diophantine beat me to it.
The non-Euro Blacet EG01 has a free run mode which is two stages (AD) only. You might be interested in the online manual:
http://www.blacet.com/EGmanualBasic.pdf
elektrograd
diophantine
Also, I'm thinking freerunning isn't the right feature name here, as that is generally used for a looping (lfo) mode. (The Oakley has this for A/D too.)
e-grad
Post by e-grad »
diophantine wrote:Also, I'm thinking freerunning isn't the right feature name here, as that is generally used for a looping (lfo) mode. (The Oakley has this for A/D too.)
True. Free running should be independent from any trig/gate.
elektrograd
giorgio
NITE MIND
Post by giorgio »
MATHS
sduck
experimental use of gravity
Post by sduck »
The best thing for your format currently that is available prebuilt is the UEG - no, it's not looping 100% of the time, it can also work as a regular eg but with more stages to deal with.
The serge/cgs VSC can be set to loop, but is only AD.
Post by Synthbuilder »
This:
http://www.oakleysound.com/vrg.htm
But you're going to have to wait. I'm laying out the board right now. PCBs should be available by the end of the month if all goes well.
Tony
diophantine
Folks, the OP isn't looking for a looping ADSR, at least not from his description.
goom, looking at the UEG manual, it may suit your needs by switching between Gated Finish Loop and Gated Release modes, though if your gate is too long it will loop.
http://www.encoreelectronics.com/UEGManual2.pdf
goom
Post by goom »
Synthbuilder wrote:This:
Tony
Whoa! Very cool. Thanks Tony. As long as it will peak to the max voltage (5V, hopefully) even after the gate is removed, it looks like a perfect module to mate with my existing setup. I don't understand all the other options, but it looks like a very versatile module. Can you share any more info?
e-grad
Post by e-grad »
The ASys Trapezoid Generator should fit the bill whereas the On stage would be similiar to a full level sustain stage. However that is still a three stage envelope since there's no decay. Yet there's no complete ADSR equivalent without a gate.
http://www.analoguesystems.co.uk/pdf/RS510E.pdf
elektrograd
goom
Post by goom »
diophantine wrote:I suppose it would need to be something like Korg's ADHSR, as found on the MS-10 and MS-20, where H is the "hold time": basically time it adds onto the input gate length.
I hadn't thought of the Korg ADHSR, but it looks like it could also work. I actually already own a UEG, but for this freerun function, I feel it's using a stick of TNT when all I want it to light a candle. :)
Speaking of the freerun moniker, that's what Oberheim called this function in the Xpander and M12. I just associated with that when I thought about the function.
goom
Post by goom »
Thanks for all the suggestions. I'll check them all out to see what's best, but so far the new Oakley module seems very cool.
Actually, if you already have an issue 3 or 4 Oakley ADSR/VCA module then you could remove C13 and put in its place a 1nF cap and a switch in series. Turning off the switch would force the ADSR to complete the attack phase whether the gate is there or not. The decay would kick in as normal after the attack peak has been reached. That is you'll get a one shot AD output.
Tony
CLee
Post by CLee »
If you're into DIY the VCS/DUSG from Ken Stone.
The trigger input does an AR one shot envelope. Connecting OUT to TRIG gives you looping. Gate into IN gives you ASR envelopes.
Navs
Post by Navs »
e-grad wrote:That's not possible for an ADSR
Yes, it is ;)
If you've got a gate delay and a comparator, you can achieve both types of 'free-run' that have been discussed (see attached MP3).
With a gate delay like the A-162, set the delay to zero and the length to taste. This provides the gate that the sustain requires. This mimics the response of AD envelopes like the VCS, which complete regardless of gate duration.
If you then mult that gate to a comparator with a suitable threshold, you'll get a second gate when the first expires. Mix the two signals and feed them to the input of the gate delay and you've got a looping ADSR.
The A-162 is great for these sorts of tricks and can also be used with AD envelopes which have an End Out to achieve the Envelator's delayed looping.
goom
Post by goom »
Tony, I have the issue 1 and issue 2 Oakley EGs. I also have MOTM EGs and the Encore UEG. Do you know what price point the VRG will be?
Thanks everyone for the suggestions. I will look into everything you've mentioned.
dkcg
Post by dkcg »
If you have a fast sequencer and a slew (or adjustable portamento in the sequencer), you can make an ADSR (or more complex shapes) shaped envelope loop or freakout (in a good way). Depends on the sequencer and the patch (I think a VC addressed envelope would be easier to time out the stages), I bet a Z8000 and a Maths could give you some crazy or musical envelopes tho. Maybe add in a couple comparators to make your steps for the stages. Whatever works. :hmm:
This is how I would set up a looping complex envelope in the buchla, with the 250e. A slewed sequencer probably wouldn't be the snappiest, fastest envelope, but an interesting one with multiple stages.
goom wrote:Tony, I have the issue 1 and issue 2 Oakley EGs.
Do you have the original issue 1 and 2 ADSR/VCA or the issue 1 and 2 VC-ADSR PCBs?
If it's the ADSR/VCA (Omeg green pots) then it's C39 (issue 1) or C9 (issue 2) you need to take out.
If it's the post 2005 non looping VC-ADSR boards (Spectrol/Vishay pots) then it's C12 you need to take out.
goom wrote:Do you know what price point the VRG will be?
The PCBs will be about £18 assuming they go right at the first run. For the ready made ones I don't know yet what price Paul will sell them at.
Tony
e-grad
Post by e-grad »
Yes, it is ;)
With a gate delay like the A-162, set the delay to zero and the length to taste. This provides the gate that the sustain requires. This mimics the response of AD envelopes like the VCS, which complete regardless of gate duration. [...]
There's a reason why you've chopped off a part a the quote.
e-grad wrote:That's not possible for an ADSR which needs a gate for the sustain.
:doh:
However, of course it's helpful to draw the attention to possible sources of gate signals.
elektrograd
goom
Post by goom »
Tony
Thanks, Tony. I have the original issue. 1 and issue 2 ADSR/VCA modules. Yep, I'm kickin' it old school! :D
Navs
Post by Navs »
e-grad wrote:
Yes, it is ;)
:doh:
Guilty as charged :lol:
e-grad wrote: However, of course it's helpful to draw the attention to possible sources of gate signals.
And that's all I wanted to do :hug: These are modular synths, after all ...
e-grad
Post by e-grad »
Navs wrote:Guilty as charged :lol:
No prob, neighbour. :party:
elektrograd
