Lost Sherman Filterbank Adapter
A place for the string slingers, pedal freaks and amp snobs in our midst.
swordsect
Post by swordsect » Sat Mar 28, 2009 11:53 am
I lost my Sherman Filterbank adapter, its the FB2 version.
Anybody know the specs on the adapter so i can replace it?
thanks!
surachai
Post by surachai » Sat Mar 28, 2009 12:46 pm
I'll just write everything I see:
Model No: APX412055
Input: 120V AC 60Hz 11W
Output: 15V AV 500mA
Class 2 Transormer
Let me know where you find a place that sells replacements. I've always been curious but too fat to look around google.
kidtesla
sucker for filters
Post by kidtesla » Sat Mar 28, 2009 1:01 pm
surachai
Post by surachai » Sat Mar 28, 2009 1:35 pm
THAR SHE BLOWS! Good call Tesla. I should learn how to use the intertubes.
wetterberg
Post by wetterberg » Sat Mar 28, 2009 1:36 pm
surachai wrote: Output: 15V AV 500mA
- is half the important bits - what is the polarity of it?
FYI the 15v 0.5A specs means that universal wall wart thingies will work here.
Kent
Curator/Janitor/Zookeeper
Post by Kent » Sat Mar 28, 2009 6:49 pm
I think that it is supposed to be "AC". Therefore, no polarity need apply here.
wetterberg
Post by wetterberg » Sun Mar 29, 2009 3:12 am
ah, well then there's all the info needed, really.
thomas6025
Post by thomas6025 » Fri Jan 06, 2017 10:41 am
Intact Herman at Sherman directly. That's what I did. He responded super fast and helped me sort out the problem of a bad online vendor sending me the wrong one (sent 12v not required 15v). It will take some time to get to the States but I just feel better getting one from manufacturer when possible.
Futuresound
Post by Futuresound » Fri Jan 06, 2017 12:52 pm
I bought a replacement from Big City Music last year, it worked perfectly.
For some reason it never occurred to me to contact Sherman... That's probably the best route, but options are always good.
thebends9
Post by thebends9 » Mon Aug 19, 2019 10:58 am
Bumping this up top - Are there any US based vendors with a comparable adapter?
Return to “Guitars, Basses, Amps & FX”
