Korg Monotribe modifications thread
You need 4 pole mini jack, tip as GATE, ring2 as CV, sleeve Ground. It has V/Oct or Hz
I can't read Japanese but it looks like you can config it to work with most things.
Edit looks like ring1 is not used
I think the King Korg cable will have 4 pole 3.5mm but given the pinout it is quite easy to make a converter cable/box to use it with whatever you want. I might start making some not sure yet as might not be worth it.
For example to make a cable for the A4 you want a 4p 3.5mm to a TRS 6.35mm, total cost for cable and parts about £3 time to make 20 minutes.
- radiokoala
- must. build. jacuzzi
I soldered such a cable but it doesn't work
One side is a 4-pole 3.5mm, and the double cable is split to two separate ones with mono 3.5mm outs (one for cv, another-for gate). When I plug any of those mono e.g. to headphones out, then speaker turns off (as it would usually do, when any cable is plugged). The same with sync in - I plug them, and monotribe stops playing (as it does when a cable is inserted but transmits no signal).
But if I plug a 4-pole jack to any of those outputs/inputs, nothing happens.
To see if cable at all is working I even plugged it with this 4-pole side to headphones out, but inserted not fully, so that a sleeve was not in a socket. Either of mono outs plugged to a mixer transmitted audio okay.
And yes, I have a 2.11 firmware.
What could be a problem??
Witness 60 minutes of audio-visual industrial psy-techno
jam-offering (and press like so this wipes away minecraft
videos clean from the trends and we get to see
some proper rave action there, FINALLY):
/ My electro-rap debut!! (video)
/ Analog & modular videos
- radiokoala
Hey igormpc, is your name Igor?? Because if so, well so is mine
Can't not help the namesake, and thank you very much darenager, I figured out everything thanks to your reply
So, a translation:
to make everything work, turn off monotribe and then turn on holding SN+Gate buttons.
Step 1 = activate CV/gate
Step 2 = V/oct or Hz/V mode
Step 3 = normal gate or inverted trigger
So, basically you upload your firmware, then enter this mode and, most importantly, press step 1. CV/gate is now active, and to save changes, press REC.
Then ... that's it, there you go !!
PS: Holy shit I spent nearly two hours already sequencing monotribe from my module...I will upload something soon! (Like audio.
So, a translation:
Yes if it is blown you can simply bypass it with a jumper - you will lose the protection of the (or not as it is blown!) fuse but if you are not able to replace it at least it will get it working again, assuming this is your problem.Altitude909 wrote:on the base board (the one with a speaker) there is a 0603 surface mount fuse marked FU1 (it as an M on it), check if that is blown
- radiokoala
"In addition, the gate voltage, please fit up to 20V."wednesday wrote:...so if this thing can accept gate triggers I'm assuming the answer to my question is yes, I can use a 12v trigger to sync the monotribe and it won't be damaged?
BTW, as promised, I updated the CV/gate demo! (Find here)
- Altitude909
Hooooooly crap! Missing a whole new operating system is what I get for living under a rock. I'm also curious to know if it'll play nice with my MIDI mod. If so,
Obviously Korg really want to show off the KingKORG's CV capabilities, but this update will also allow the MS-20 mini to control the Monotribe (fuckin' stoked for that). I don't think it's a coincidence at all.
- radiokoala
WoahJayEm wrote:For those with proper cables, press record and you can save your sequence. Still only 16 steps though
I also discovered that in cv/gate mode sync in/out are not tied together, and you have absolutely independent clock out. Drum and synth sections therefore can have two completely separate tempos which again is quite cool!
- Altitude909
Yes. The only quirk is that when they added 8 more steps, they added them in between the 8th notes, while keeping the time signature the same so if you slave it to a midi clock, it will run at 2x normal time if you want like a normal 16 step sequenceSuineder wrote:Hooooooly crap! Missing a whole new operating system is what I get for living under a rock. I'm also curious to know if it'll play nice with my MIDI mod. If so,![]()
- radiokoala
Monotribe has a half tempo setting - hold gate and then press 8. That would solve the problem. 8_)Altitude909 wrote:Yes. The only quirk is that when they added 8 more steps, they added them in between the 8th notes, while keeping the time signature the same so if you slave it to a midi clock, it will run at 2x normal time if you want like a normal 16 step sequenceSuineder wrote:Hooooooly crap! Missing a whole new operating system is what I get for living under a rock. I'm also curious to know if it'll play nice with my MIDI mod. If so,![]()
I know the half-tempo feature affects the sync i/o, but does it really apply to MIDI clock as well? That'd be kind of neat (I added MIDI to my 'tribe, but I truthfully haven't used it much).
Now, what would be really cool is if the engineers found a way to apply active step to all 16 steps in a sequence instead of the 8 sets of two. Not sure how they'd pull it off, though, because you already need three fingers to change the length of a synth or drum sequence. Perhaps add the gate time button? Sounds a bit unwieldy. Whatever, I'm fine with the active step the way it is.
- Altitude909
That does not apply to midi clock syncradiokoala wrote: Monotribe has a half tempo setting - hold gate and then press 8. That would solve the problem. 8_)
https://soundcloud.com/telegasms
Maybe. It depends on how the cable is wired. If, say, the stereo tip connects to the 4-pole tip and the mono tip goes to the second ring or vice versa, it would work. You'd have to do a continuity test.telegasm wrote:Sorry for the dumb question, but would this cable work?
http://www.lunashops.com/goods.php?id=2053
i think it's remarkable that they can add (analog) cv/gate control via a (digital) firmware update.
does this mean that the incoming cv/gate signals are first digitized before they control the analog synth section?
and would that in turn mean that incoming cv/gate-notes will be sent as midi notes in realtime if you have the midi out mod installed?
that would make the tribe into a cv/gate-to-midi converter!
has anybody with a midi-modded monotribe and fw 2.11 tried this?
- StepLogik
That would be my guess. I suspect they just tied the three poles of the input jack to the GPIO pins on the CPU. So, they can do whatever the software dictates.bartleby wrote:i think it's remarkable that they can add (analog) cv/gate control via a (digital) firmware update.
