[Closed] Bipolar mixer / offset boards
* update Sep28 2012 * All sent out!
* update Sep26 2012 * PCBs have arrived. I'll start shipping next monday. Non-EU orders will be sent first.
PCB: 9.40 Euros, Panel 16.50 Euros. These prices include shipping inside the EU.
* edit Sep 5th 2011 * Second round!
* edit July 15th 2011 * BOM is available at the end of this post
PM me for PayPal details. When you PayPal me please include your Muff Wiggler nick in the message and of course quantities how many pcbs and/or panels you order.
Shipping will start as soon as I have all the boards and panels here. Last time it took only one day to get them all out.
PayPal payment is the only way to reserve anything. I will not order or hold any boards or panels without payment. Sorry for that, but I have had bad experiences in the past people not paying their orders.
You will find all the relevant updates in this first post!
I have been asked several times about the possibility to buy BiMix mixer boards.
Because it would be useful to have these boards in hand for my future projects, I decided to check whether there would be any interest in a group buy?
You can read about the module here:
viewtopic.php?t=34410
* I won't do ready made modules.
* I won't do any kits. Just bare pcb is offered. All the parts are pretty basic and normally available in stores.
* I'll do a panel run if there is enough interest. Panel can be seen in the BiMix thread.
* I will provide BOM
* I won't be able to help with building. I don't have time for that. You have to have some knowledge about building these things.
Board is approximately 105mm x 44mm in size. Through hole / single sided / silk screened / with solder mask. Board can be panel mounted with 9mm Alpha pots or similar.
Module was done for the +-12V eurorack system. I have tested it in my frac rack and it works fine with +-15V power too. Only one resistor should be changed to different value.
Prices:
9.40 euros per pcb
16.50 euros per panel.
These prices include the shipping inside the EU.
All the shipments to non-EU countries: add 8 euros per order because I have to use registered shipping.
Material list for the board:
4x 0.1uF (100nF) capacitor
4x 47pF capasitor
2x 10uF electrolytic capacitor
4x 100k linear potentiometer + knobs
(9mm Alpha pots or similar if you want to panel mount the board with pots)
1x 82k resistor
- 82k will give a bit over 6V offset in +/-12V system
- 140K would be 5V in in +/-12V system
- In +/-15v system the values are approx. 130K and 200K
- you can use anything between those figures
10x 100k resistor (use 1% or better)
1x 1k resistor
2x ferrite beads / 10R resistors
4x 3 pin jumpers for bipolar / unipolar control. 1 jumper per every input and output
1x 2 pin jumper for activating / deactivating the offset cv in un-patched input 1
(You can bring these jumpers to front panel with 5x SPDT switches. Not possible in my 4HP panel.)
3x mono jack
1x switching mono jack (for the offset input)
2x OPA2134 IC (if you plan to mix only cv it's a lot cheaper to use 2x TL072 or similar)
Optional:
2x 8 pin IC sockets
1x 2x5 pin or 2x8 pin power cable socket
Building should be very straight forward. There is a couple of tight fits but I have had no trouble to get everything in place. Straight line between two pads means jumpwire.
One important building note: There are two pads marked with "X". Connect these two X-pads with a fly wire.
Prices:
9.40 euros per pcb
4x 47pF capasitor
1x 82k resistor
1x 1k resistor
3x mono jack
Optional:
2x 8 pin IC sockets
My releases: https://laitoshuoltaja.bandcamp.com/releases
My sound art & live gigs: https://www.facebook.com/Laitoshuoltaja/
Modular live gigs (our modular band): https://konekonekone.bandcamp.com/releases
Modular Patch of The Week Channel on YouTube: https://www.youtube.com/channel/UCTYqCy ... pvEmilJScg
- rico loverde
- brother303
Ok, I'll do a small run.
Board: 8.50 euros
Panel: 16.00 euros
Both prices include shipping inside the EU.
PM me if interested.
Board: 8.50 euros
Panel: 16.00 euros
I will take orders until July 18th.
No more interested wigglers?
- Blinkar blå
BOM available in the first post
- brother303
One day notice!
Not many hours left...
- rico loverde
- brother303
Can't give you an exact date because I don't know it but I will send them forward immediately when I receive them. Order was made on July 18th.
- brother303
Was just a little curious...
Cheers
Greg
Thanks for reply,no problem here!theabsent wrote:Can't give you an exact date because I don't know it but I will send them forward immediately when I receive them. Order was made on July 18th.
Cheers
Greg
Peake wrote: DIY is all about the backlog. If you don't have a huge backlog, you aren't trying hard enough.
PCBs are in. I will build one and test it and start the shipping process. Should not take long.
PCBs are fine! It was an easy build. Took me under an hour to complete fully. Will start shipping tomorrow.
Oh, forgot that. I'll figure it out asap.depth20 wrote:Any news on the xxxk resistor for +15V rail?
edit: check the first post for info
Second round will be opened in a day or two.
