4hp Spring Reverb driver module - schematic, pics, sounds
Tombola
Post by Tombola »
I was just about to buy an A199 spring reverb when I decided to save 4hp of space and build my own.
The circuit is based on Roy Mallory's tech note and tone control, which is useful - a symmetrical cut/boost of bass and treble. The drive, recovery, tone and blend buffer take the four amps in a TL074.
The gain on the drive circuit is reduced quite a bit - R10 is 660R rather than 62R (it's R1 in Mallory's article), and the recovery circuit has a variable drive.
I put a couple of phono jacks on the back of my Doepfer case, so it's easy to plug in an external tank - a nice rich 6-spring 9EB2C1B (mainly because I built the circuit with the 8EB2C1B from a fender amp)
http://soundcloud.com/musicthing/diy-sp ... erb-module
UPDATE: See revised schematic
NB - this is a revised schematic correcting a phase problem - use this schematic!
revised spring module.png (22.82 KiB) Viewed 10524 times
limpmeat
Post by limpmeat »
looks great, love the front panel
Neutron7
Oldschool bleeper
Post by Neutron7 »
that tank sounds really nice. great job!
mikecameron
Thread Killer
Post by mikecameron »
I have been thinking of doing this very thing! Thanks for sharing your work, I'll be building it soon. :yay:
jimmyambulance
Post by jimmyambulance »
can't wait to try this out!
Dego
Post by Dego »
Very nice :)
BugBrand
Knowledge of Bugs
Post by BugBrand »
Nice work.
And especially thanks for the links to Roy Mallory's interesting articles.
mig27
Post by mig27 »
Nice one!
And I also dig the plexi front plate.
Looks a bit like my OSC303.
Care to share how you built these?
I'm currently looking cheaper front plate alternatives than the usual Schaeffer job :75:
Michael
Tombola
Post by Tombola »
Some notes about the laser panel process here:
viewtopic.php?t=35668
mig27
Post by mig27 »
Thanks, appreciated.
Must look into this closer--
M
KNYST
hiding in the forest
Post by KNYST »
sound, panel, photos, work, are all: :sb:
NOISE HEALS.
patch responsibly.
LISTEN | WATCH
Jarno
Post by Jarno »
Thought you needed something with a bit more oomph to drive a reverb tank. Nice n small this, superb!
fluxmonkey
Post by fluxmonkey »
nice to hear a demo comparison between the 2 springs.
www.fluxmonkey.com
boothnavy
Post by boothnavy »
If you made R10 in your circuit variable with a pot, could you then control the input amount?
Also, would any modification be necessary if using 15v?
boothnavy - synthesist
www.analogcraftsman.com
Tombola
Post by Tombola »
Boothnavy: I did try that on the breadboard with a 1k pot, because I assumed I'd build it with variable drive and fixed recovery. It didn't work well for me - very limited useful range, quick to distort in a nasty way, but then I didn't test it with a huge range of input signals.
Re: 15v - sorry, I have no idea - I guess the TL074 datasheet would give you the max voltage. The other values don't seem that critical so you'll probably be fine.
Tombola
Post by Tombola »
R9 is another interesting one - it's a kind of damping/stabilising on the recovery circuit - worth experimenting with - or removing - on breadboard
Tombola
Post by Tombola »
BugBrand wrote:Nice work.
Very kind - particularly given that you got me started on this in the first place:
http://musicthing.blogspot.com/2008/11/ ... ng-in.html
Glitch Militia
Post by Glitch Militia »
What input / output impedance is this designed for ? I do not know that tank that you got.
I currently got this one on breadboard, tweaking some values etc. I like the sound of yours, so I'll try that next. :yay:
Tombola
Post by Tombola »
Both my tanks are 800 Ohm / 58 Ohm (input impedance / DC). 2575 Ohm / 200 Ohm (output impedance / DC).
Tombola
Post by Tombola »
This shows off the sound of the big six spring tank quite well. (
Disappointingly, the six springs are actually mounted as three springs with joints between the separate springs... )
http://soundcloud.com/musicthing/maths- ... llator-diy
timpecter
Post by timpecter »
That is a great demo, Tombola! I'm experimenting with spring reverb now and it's inspiring to hear.
cyklopljud
Post by cyklopljud »
Yes yes maybe I'm a lazy DIY'er, but.... any chance of a vero layout of this anywhere..... :help:
Tombola
Post by Tombola »
Sorry, as you can see from the pic, I laid it out in a rather freestyle/chaotic way on pad-per-hole perfboad with lots of kynar wire... Would be a tiny board if you did it properly!
Jarno
Post by Jarno »
I consider myself to be lazy as well, and I think duplicating a vero or perf layout is just too much effort, I always make it up as I go. So much easier when you just have to look at the schematic instead of also looking at the layout as well, of course a pcb is even easier still ;-)
Tombola
Post by Tombola »
I always build first on breadboard, to get the thing working and get confidence that all the components are right and that I 'know' the circuit - I don't think I've ever successfully built a circuit by following a vero layout - I'm not precise/patient enough. I have a shelf full of non-working stompbox circuits built like that! :doh:
