Rogan knobs group buy
decaying.sine
Broken <--> Fixed
Post by decaying.sine »
A couple of us wanted to start a thread to see if there are wigglers interested in a Rogan knob group buy. These are the knobs used on some Buchla modules and an example can be seen below in zthee's JH FS-1A design.
Some Basic Information
oberkorn was kind enough to do some background research on the knobs and it appears that there is a minimum of 500 required to make a purchase. The price per part for Model RB67 size '0' skirted in Blue 1/4" shaft (e.g., range, fm and cv tune on the fs-1a module below) is:
For an order of 500 pieces: $0.85 per part
For an order of 1000 pieces: $0.79 per part
The Rogan website is: http://roganknobs.com/
Initially, we have interest in all three sizes used by Buchla in both red and blue color. I'll post the model numbers and links to the specifications in the original post once we collect all the fine details. If you are interested in purchasing some of these knobs, let us know here.
Knob Color
Blue
Red
Knob Types and Options
Unskirted Knobs
The unskirted knobs have two types. There is a deep core version and a standard round version. Please note that having the painted indicator line is not a default option. There is no indicator line on the small unskirted knobs in the FS-1A picture below, but there is an indicator line on some of the other unskirted knobs pictured.
Deep Core Version: http://rogan.rogancorp.com/item/rb67-se ... /item-1910?
Rounded (non-deep core) Version: http://rogan.rogancorp.com/item/rb67-se ... /item-1904?
Skirted Knobs
Size "0" Skirted Version: http://rogan.rogancorp.com/item/rb67-se ... |1057|1087
See picture above for Size "0" Skirted Version of knobs.
Size "xxx" Skirted Version: I will add the link with the specifications when I find out exactly the right size.[/i]
Options
If you are interested in purchasing these knobs in the group buy, please consider filling out these simple forms.
RB67-0-SK, RB67 Round Control Knobs with Skirt Form (Small with Skirt)
Knob Size: 0
Material: ABS or Custom
Shaft Configuration: Bushing with Set Screw or Custom
Color: Black, Grey, Blue, Red, White, Yellow, or Custom
Finish: Gloss, Matte, or Custom
Options: Decorative Inlay Style Top, Painted Line Indicator
Total Quantity Desired:
RB67-xxx-SK, RB67 Round Control Knobs with Skirt (Large with Skirt)
Knob Size: xxx
RB67 Series Round Control Knobs Form
Knob Style: Deep Core or Plain Round
Knob Size: 0
Last edited by decaying.sine on Sat May 14, 2011 4:30 pm, edited 2 times in total.
Brian
decaying.sine
Broken <--> Fixed
Here are my order choices in the forms. You can see where I indicated my color choice and also the options that I selected. In terms of options, I want to order the default Buchla options, and I will verify that these are actually the defaults.
Knob Size: 0
Material: ABS
Color: Blue
Finish: Gloss
Options: Painted Line Indicator
Total Quantity Desired: 50
Knob Size: xxx
Material: ABS
Color: Blue
Finish: Gloss
Total Quantity Desired: 30
Knob Style: Plain Round
Knob Size: 0
Material: ABS
Color: Blue
Finish: Gloss
Knob Size: 0
Material: ABS
Color: Red
Finish: Gloss
Knob Size: xxx
Material: ABS
Color: Red
Finish: Gloss
Knob Size: 0
Material: ABS
Color: Red
Finish: Gloss
_________________
Brian
Brian
Kent
Curator/Janitor/Zookeeper
Post by Kent »
Most definitely interested. Just lemme know the details so that I can ratchet it up beyond "interested". :tu:
@n@log
Post by @n@log »
Some prices from rogan for all models:
500x 200-0302-001 - RB-67-0-ML $1.800000 $900.00
RB-67-0-ML KNOB, ABS BLUE GL, .250 BUSH, ONE SOC SCREW,
SPUN INLAY W/BLK LINE, PACK
500x 200-1702-001 - RB-67-0-SK-7-M $2.650000 $1,325.00
RB-67-0-SK-7-M KNOB, ABS BLUE 5500 GL, .250 BUSH, TWO SOC
SCREWS, SK W/WHT ARROW, SPUN INLAY, PACK
500x 202-0305-001 - RB-67-2A-SK-7-M $3.320000 $1,660.00
RB-67-2A-SK-7-M KNOB, ABS BLUE 5500 GL, .250 BUSH, ONE SOC
SCREW, SK W/WHT ARROW, SPUN INLAY
Grand
500x RB-67-0-DC BLUE ALUM. INLAY BLK LINE
250 BUSHING 1 SET SCREW $1.800000 $900.00
500x RB-67-1-SK-7-M Red Aluminum Inlay, white
solid arrow 250 bush 2 set screws $2.130000 $1,065.00
decaying.sine
Broken <--> Fixed
Excellent. Thanks for that! :sb:
Brian
@n@log
Post by @n@log »
yeah,i think the $0.85 price most be per 5000... :hihi:
note that rogan don't do custom jobs anymore for the alpha types shafts,alpha's are only D-shaft and thats it,sadly
active
Post by active »
i'm also interested. i have been holding off on getting any knobs until i found some that i would like on most of my DIY stuff. these are looking pretty awesome. so count me in for a decent amount!
megaohm
Post by megaohm »
@n@log wrote: note that rogan don't do custom jobs anymore for the alpha types shafts,alpha's are only D-shaft and thats it,sadly
Are you saying they don't make these for fully round 1/4" shafts?
Only D-shaft?
www.MegaOhmAudio.com
Will work for pistachios
giorgio
NITE MIND
Post by giorgio »
I'd be interested in probably 6 or 8 of the big ones, and a bunch of the smaller ones, not sure exactly which of which quite yet. sounds promising though.
decaying.sine
Broken <--> Fixed
Only D-shaft?
I think they work best on round shafts and not the D-shafts. However, I think that we should verify this for everyone.
If you have an E-M group buy Rogan knob from the most recent purchase, can you verify if these fit the round AND d-shaft alpha pots?
I'll ask Rogan for samples, but I am sure they will say F-me.
Brian
Bricks
paper kettle
Post by Bricks »
My EM group buys were all set screw for round shaft, and at least $4 each
decaying.sine
Broken <--> Fixed
If anyone has exact specs from other group buys, let me know. I am going to start requesting formal quotes from Rogan on monday. I think the one that I need a model number for is the large skirted knob. What size is that bitch? The others seem to be size "0."
Brian
FrankV
waggling wiggler
Post by FrankV »
Definitely interested. Will have to do some head-scratching on quantities...
F
bwhittington
Terrifying Brain Secret
Post by bwhittington »
FrankV wrote:Definitely interested. Will have to do some head-scratching on quantities...
F
Me, too.
Thanks for exploring this, Brian.
@n@log
Post by @n@log »
Only D-shaft?
Yes,but the alpha range note,not the RB67
This is the 'alpha' range red knob :
Alpha red.jpg (34.24 KiB) Viewed 3177 times
@n@log
Post by @n@log »
RB67 range..
zthee
Panelhöna
Post by zthee »
I'd be interested in the small skirted.
No PM's please! Send an e-mail - ttsh(a)thehumancomparator.net
Information regarding the Two Thousand Six Hundred DIY project - > http://www.thehumancomparator.net
_
"Oh Batman, why you got to be so heteronormative?".
@n@log
Post by @n@log »
decaying.sine wrote:If anyone has exact specs from other group buys, let me know. I am going to start requesting formal quotes from Rogan on monday. I think the one that I need a model number for is the large skirted knob. What size is that bitch? The others seem to be size "0."
Grand
sanders
Post by sanders »
I'd like some red knobs.
It's been pointed out, but maybe worth saying, the red knobs on the 208, 297, system interface, etc are sized in between the small "0" and large "2A". So, if one orders them as RB67, they'd have to be size "1". The only other red knobs are the skirtless "0" used only on the 208.
Original Buchla knobs used only one set screw.
oberkorn
Post by oberkorn »
absolutely interested!
give me a day or two to go though my notes so i can count how many knobs I need.
you have to pay for the music but the noise is free
tailwagger
Post by tailwagger »
Interested in the smaller Rogans for the buchla DIY projects.
On the keyboard
decaying.sine
Broken <--> Fixed
Still dilly dallying compiling information. Definitely going to do this though.
Brian
mome rath
a dubious cube of margarine
Post by mome rath »
zthee wrote:I'd be interested in the small skirted.
:hihi:
soundcloud, dear friends
good trader cred
instagraM
guest wrote: Fri Jan 03, 2020 2:45 pm basically, as the dude put it "no walter, youre not wrong, youre just an asshole".
zoogoo wrote: your stupid
djs
Post by djs »
I'd like one big skirted one (blue)
5 small skirted ones (blue)
10 small non skirted ones (5 blue, 5 red)
@neutronstar604
mckenic
Post by mckenic »
Not worked anything out yet but these look great and I'd be down for some too please!
