Adapting the EuroRack audio world for video synthesis
I'm new to the world of video synthesis, and as a starting point I purchased a Dave Jones MVP, as it seemed like the best option for getting started on my student budget.
I'm wondering if there is a way to expand my video system now. i.e If I purchased some lzx modules, such as the waveform generator and the triple multimode filter, would these input directly into the mvp, or would I still need the lzx encoder and synch generator?
I also have an expert sleepers system, and want to use it with my video system to experiment with pattern synthesis. Has anyone tried making audio max/msp patches, then using them through a converter such expert sleepers to generate video patterns before?
What are the best modules I should look at purchasing in the future to experiment with pattern synthesis?
And finally.... Has anyone had success downloading the pdf's under the Diy schematics section on the lzx industries website?
All three sound good and I'd like to try making them, however when I open the pdfs, there are just a few random indecipherable symbols scattered across the page, it's by no means a readable schematic!
Thanks to everyone for there help and advice to a video synth newbie!
The MVIP has a video input which expects a composite video signal. It extracts the sync information from that to create the sync on the video output. So only real composite video signals can go in there. (like the output of an LZX encoder, a DVD player, camera, etc...)Egor wrote:I'm new to the world of video synthesis, and as a starting point I purchased a Dave Jones MVP, as it seemed like the best option for getting started on my student budget.
It also have CV inputs. Those are expecting audio rate and below. And are expecting standard +/-5v Euro signals. So the LZX 0-1v signals would be fairly small. And anything above the audio range won't be seen. So you can't really put video rate oscillators in those and get video rate bars or shapes.
The MVIP works fine processing the output of the LZX encoder. So to go that route you would need their oscillators and the sync gen/encoder modules to feed video rate oscillations and shapes into the video input of the MVIP.
What are you opening them with? Do you have Acrobat Reader (Adobe Reader) installed? (get it free at adobe.com) I just went and checked and all three display fine as PDF files. If you just open them as text files then you'll see a bunch of strange character symbols and not the schematics.Egor wrote:And finally.... Has anyone had success downloading the pdf's under the Diy schematics section on the lzx industries website?
- nickciontea
- brownshoesonly
- Cobramatic
- Veteran Wiggler
Tried out the TipTop Z3000 Osc with the LZX.
Specs suggest it gets into video rates.
My trials gives 1 vertical line without syncing and upto 3 vertical lines if synced via Line rate into the 1v/octave input. For some reason the 'sync' input is a lot less useful at Line rates.
A few diagonal lines are possible also.
Horizontal lines are all good as expected - no need to sync to Field rate as the Osc is very stable.
As it has all usual waveforms out and 2x FM and PWM cv control in then it works well as a lower frequency VWG, which is damn handy 'cos there are still no VWG's out there (no stock for at least a year now.....)
Grab one if you can't get a VWG!
Been using the Malekko Wiard Anti-Osc for interesting wave folded vertical lines too via the 'Mayhem' output.
- Cat-A-Tonic
- Lobsters love Muff
Doepfer A-172 Max/Min works great with LZX video.
As I understand it Max/Min is synonymous with
Analogue AND/OR,
and Peak & Through.
...but the LZX module is 'digital' Logic, right?
Just 0 and 1v, nothing in between, right?
Analogue AND/OR,
and Peak & Through.
<iframe src=https://audius.co/embed/track/Eq4Qw?flavor=card width="100%" height="480" allow="encrypted-media" style="border: none;"></iframe>
<iframe src=https://audius.co/embed/track/bQ2RM?flavor=card width="100%" height="480" allow="encrypted-media" style="border: none;"></iframe>
Correct. The new version of VBM has a "MAX" output (analog OR.) Digital logic serves its purpose with the LZX logic modules, but analog logic is arguably more useful for compositing video signals....but the LZX module is 'digital' Logic, right?
Does the Doepfer Min/Max lose any resolution on video signals?? If not that's awesome. It probably uses discrete transistor logic.
LZX Industries | http://www.lzxindustries.net
- Cat-A-Tonic
The Doepfer Max/Min uses 2x LM324 chips.lizlarsen wrote:Correct. The new version of VBM has a "MAX" output (analog OR.) Digital logic serves its purpose with the LZX logic modules, but analog logic is arguably more useful for compositing video signals....but the LZX module is 'digital' Logic, right?
The picture quality is good enough for most tasks.
The same as Doepfer A-152, or Blacet Hex Zone sequential switches.
There seems to be a slight softening (loss of resolution).
When using with oscillators you wouldn't even notice.
With external footage there is a difference, but it's fairly negligible.
That's cool that the new version of the VBM has Max outs.
You should revise the description on your website and Analogue Haven.
I don't think the write up got updated along with the module.
There are also Analog Logic and Peak & Trough PCBs available from Ken Stone (CGS).
It's hard to DIY for cheaper than used Doepfer though (especially if you factor in time & effort).
It's a pretty fun way to combine images.
I've been fucking around with the ADDAC 601 Fixed Filter Bank for about 3 hours now, using the envelope outs of each of the frequency bands (some fed into a Macro Machines Dynamic Destiny for switching) to modulate parameters on the MVIP. I suspected the Fixed Filter Bank would be a great module for video applications, and I was not disappointed. Can't wait to try the RxMx/Fixed Filter combo with it.
- drumasaurusrex
- drumasaurusrex
Mutable Instruments Edges... recalibrated
I have tried recalibrating the Mutable Instruments Edges to get higher frequencies and try to push into video rate (vertical lines). The control of the frequency is weird after calibration, but allows the module to generate frequencies above the audible range... but just barely... like I get to nearly the maximum frequency range before it becomes inaudible.
It is not ideal for video synthesis. However, it is a fun (for a minute) adaptation of an audio module. You get 4 separate oscillators with separate outputs or a mixed output... with some cross-mod options. Mostly pulse wave (except for osc4), but can add/substitute for some extra modulation if you've got one.
Cheers.
Cheers.
- Dirty_Bill
- Ultra Wiggler
Playing around with the Ciat-Lonbarde Denum and Swoop. These "Bounds/Bounce" oscillators like to fly all over the frequencies, but feeding them line and frame sync signals to their bounds makes them sync at some frequencies. This is triangle outs into the Cortex from the Denum and then Swoop (with a VWG sine colorizer over the top).
Just shot with the phone, excuse the pixels and scan lines. More experimentation is needed. Definitely not worth a video yet
- Cat-A-Tonic
I've had some good results with audio filters and wave-folders processing video.
Wave folders look similar to filters, but with more ripples or bands instead of washes/smears.
Pulse based wave folders act kinda like keyers.
- drumasaurusrex
Pittsburgh DNA Symbiotic Waves
I have really been enjoying the 3TrinsRgB+1c for adapting my audio modules to the video world.
The link below is 3 waveform outputs from the Pittsburgh Modular DNA Symbiotic Waves module sent to the R,G, and B CV jacks on the 3Trins. With the fine tuning knob, you can get some -fairly- stable waveforms. It doesn't show well in the video, but at low frequencies, you can see some cool digital edges in the different waveforms.
cheers!
cheers!
- bananeurysm
- Veteran Wiggler
- Cat-A-Tonic
You need some sort of Color Video Encoder and Sync Generator.bananeurysm wrote:Is it at all possible to generate composite video with color with standard eurorack modules? color info comes from a related modulator of some sort right?
LZX has a few options.
Alternatively, you could use:
Dave Jones MVIP
or
3TrinsRGB+1c
