Pulse/Trigger samples to run the modular with a sampler/daw?
Anyone have wav files of this type to share or know where to find such a thing?
Brooks
Brooks
Here's the one I use: http://www.crudbump.com/pulse-2db.WAV
- doctorvague
- ole fuckity fuck
I created some wav files at different levels.
They're in a zipped folder here:
http://idisk.mac.com/doctorvague/Public ... AWSync.zip
They're all 5ms long.
- VortexRanger
- reticulating splines
Some audio input modules will create a trigger for you too... like the Q118, which is what I use. It also creates a gate and an envelope, and you can set the threshold at which it creates these things... much fun.
http://www.synthesizers.com/q118.html
- Automageddon
I put mine into Simpler and make clips with various rates, eg one every 16th, 8th etc all the way to every 8 bars for things like resets. Route a couple of those simpler tracks to individual outs and use them for clocks and resets etc.Automageddon wrote:Can I just load this pulse in Live and use it to for example, reset a LFO or sync a sequencer?
These tracks with all those clips are great to have in the Live library.
- Automageddon
I managed to make this work last night without any problem.
Strangely enough my MFB dual Lfo would not reset from the -10Db, so I had to use the -6Db and put the simpler output to -0 (it's usually on -12Db by default).
Apart from that, all worked like a charm.
I had the midi out to the modular on one midi channel and simpler on another, but both were receiving midi from the same in.
I use two outs from my MPC1000 sending these triggers - One to clock a sequence, another to trigger envelopes. LOVE it. I've been trying to find a sample I can use as a gate for my adsrs, but had no real luck - any ideas??
Johnisfaster wrote:Its obvious that this is an FBI cover up. Ive no doubt YONI is already dead.
YOU SAW NOTHING!
