NR as Rnd Sequencer, very High CVs
Hi there!
This forum has been really helpful for discovering sweet tricks and hints concerning the NR, but one thing is getting heavily on my nerves:
With practically every use of my NR as a sort of rnd sequencer (running output 1 or 2 into an OSC), I get a couple of nice harmonic CV signals, which could be used as a little riff, but then a large numbers of unchanging, extremly high CV pitches rattle my ears and my OCS ...
Is there any way of this rattling, high pitches Dolphin talk?!?
Boom Baam bububum MEEEEEEP MEEEEEEP MEEEEEEEP MEEEEEEP
That's what it sounds like to my ears ....
All the best,
pbanken
All the best,
pbanken
"Son of a bitch, I'm sick of these dolphins."
- selfoscillate
it can all be done with some patching.
simple attenuation shoud work most of the time,
but if it doesn't, there are other ways.
for example, you can use an inverter and a vca.
feed the normal nr output into the signal input of the vca
and an inverted nr output to the cv input of the vca.
now dial in some initial gain on the vca and attenuate the
inverted nr output to taste. this way the higher notes get
more attenuation than the lower notes.
or you can feed the nr output to a max/min module,
together with a fixed voltage which determines the
highest allowed pitch. then use the min output.
the higher notes will not exceed the fixed voltage,
while the lower notes get through unchanged.
- CursedFrogurt
- Square Enthusiast
Oh neat, that's some cool patch programming ideas. I don't have a NR but I'll certainly put that in my brain for later use; it's techniques like those that make me enjoy modularity. Bring on the math.selfoscillate wrote:it can all be done with some patching.
- Veqtor
Yes, but attenuation gets the steps into microsteps, what's sad is that bit1 is tuned to be a semitone, so if you attenuate the sequence you don't get these lovely sequences anymore.
Buchla solved this with the N-knob... I hope there will be an expander with an N-knob... Otherwise I'll sell mine too...
What the N-knob does is that it cuts out the higher bits, leaving simple, funky melodies in a limited range of notes (you can set it to 1,2,3,4 etc bits)
I quite recently got a Frac Noisering and haven't completely gelled with it yet - think I've come across somewhat similar on the outputs. I put on a data-invert switch which may help things? I can't now remember which way is 'normal' for the switch and may actually change it over to a SPDT C/O type to see if that helps.
This is a good Wiard info thread: http://muffwiggler.com/forum/viewtopic.php?t=5306
I changed the invert switch over to SPDT C/O now and have been using an oscilloscope to view the two outputs -- very interesting. Using an o'scope is actually very good to figure a bit what is going on - I have found the controls to be very sensitive - just a turn and you get out of very nice fluctuations and into something that bangs too often into the top (+10v) or bottom (gnd).
But, yes, both outputs are fluctuating over a full 10v range -- if you're using that to FM a VCO then that'd give 10 octaves!
- selfoscillate
you can use a quantizer after the attenuator to bring itVeqtor wrote:Yes, but attenuation gets the steps into microsteps, what's sad is that bit1 is tuned to be a semitone, so if you attenuate the sequence you don't get these lovely sequences anymore.
back to semitones. i know it will not be the same output,
but it should work at least for a couple of settings.
but i fully agree that buchla's approach is great and well-thought.
- suboptimal
- A Towering Mediocrity
I use MATHS for that
My youtube modular music movies:
http://www.youtube.com/results?search_q ... type=&aq=f
