Last bits: Le Seq in black
Moderators: Kent, BugBrand
batchas
Post by batchas »
I have 2 x Le Seq black panels which will allow me to build 2 x Le Seq rev 2.2 with the last boards I have. The panels are not perfect and have some marks, but better than nothing. I'm not ordering new blue panels and I thought I'd mention here in case someone is interested in getting one of these.
You can let me know via PM
batchas
Re: Last bits: Le Seq in black
Post by batchas »
Update: both modules are on hold.
freakynorth
Withered Gardener
Post by freakynorth »
Fingers crossed for some Le Seq Expanders one day???
deltaphoenix
Post by deltaphoenix »
freakynorth wrote: Sun Jun 06, 2021 12:26 pm Fingers crossed for some Le Seq Expanders one day???
I would be onboard for one too
Kazremark
Post by Kazremark »
Me too, for an expander 🤞
northerntao
Post by northerntao »
I was lucky enough to pick up one of these last Le Seq. I had picked up Robert’s blue Frac OA and Radio Music as well, but initially passed on this little gem and its expander. Its very handy to have a straightforward sequencer in my Bug rack, but also a stable clock source - don’t have to sacrifice an LFO or envelope to clock within the rack!
It almost ended up a disaster - I unpacked the Le Seq and set it atop a pile of books, still in its bag and packing. But my cat was running around in the night and knocked it loose. It fell about 4 feet and I heard a snap. Turns out it landed on the power connector - the little white tab on the MTA connector broke off. It still powers on and works fine, but the connector is wobbly without the tab. An easy fix though - even I should be able to solder on a new one.
soup
Post by soup »
Post a pic. The plastic part on the mta connector is held on only by friction and can be removed by gently tugging with some pliers. You can can then push an unbroken one over the pins without desoldering anything.
batchas
Post by batchas »
northerntao wrote: Sun Aug 01, 2021 6:48 pm the connector is wobbly without the tab. An easy fix though
Like soup said. It's possible to remove the white plastic and replace only this part.
I can take it off of a MTA and send it to you of course if you need.
Better IMO than having to replace the all part.
northerntao
soup wrote: Sun Aug 01, 2021 8:01 pm Post a pic. The plastic part on the mta connector is held on only by friction and can be removed by gently tugging with some pliers. You can can then push an unbroken one over the pins without desoldering anything.
batchas wrote: Mon Aug 02, 2021 12:38 am
Thanks guys - I think I still have the plastic tab in bag somewhere. I assumed it had broken off, but I’ll pull the module out this week and see if I can snap it on if its not broken. I was just gonna pick up a new MTA connector at some point but this sounds like an easier (potential) fix. Glad I posted about it.
northerntao
Looks like a part of it broke clean off. Its working for now so I think I’m good. I occasionally do an order from Mouser, so I can just pick up a replacement or two then. Or maybe the next time I order something from you - or Tom :D , you could toss one in.
BugBrand
Knowledge of Bugs
Post by BugBrand »
Sure - just remind me when ordering.
Use a small flathead screwdriver to prise up the remaining white plastic bit - obviously being careful of nearby traces. Once it is a little loosened, you should be able to remove it with pliers, then just put the replacement plastic bit on in place & push it right down.
northerntao
BugBrand wrote: Mon Aug 02, 2021 1:39 pm Sure - just remind me when ordering.
Thanks Tom! And soup and Robert.
Return to “BugBrand Devices”
