So I'm on a little WhatsApp group that shoots the shit about synth related stuff, and was extolling the virtues of my Bugbrand frames, when I had an 'aha' moment talking about the DDSR in relation to S&H and random(ish) pitch modulation.
It occurred to me (and this may have already occurred to you - in fact, I've since noticed that Tom actually mentions using noise as a data source for the DDSR in the manual) to patch up the left hand part of the Dual Amplifier to generate white noise - ie the wavefolder patched back on itself and cranked - and then feed that into the Data input on the DDSR.
Lo and behold, you do get far more randomised output pitch from the D/A outputs, much like a S&H type effect, even when set to recirculate.
Can be a little sticky - I imagine this is due to the logic side of the module - occasionally you'll get a little train of the same pitch, although that doesn't last too long.
Kinda obvious but had never occurred to me - have you got any good aha moments/tricks with Bugbrand that you'd care to share? Love this stuff.
AHA moments
- DickMarker
- Veteran Wiggler
Re: AHA moments
video examples please : )
- DickMarker
- Veteran Wiggler
- freakynorth
- Withered Gardener
Re: AHA moments
Do a viddddddddd
