"ЧАТЕЛЬ-6" - 6-channel bidirectional signal router.
PARATEK - aesthetics of the Soviet cyberpunk!
Dedal
Post by Dedal »
• Adjustable number of channels from 1 to 6 + tremolo mode.
• Two-way operation, high switching speed limit.
• 6 algorithms for channels changing via trigger/gate, including random.
• Manual and CV* control also available.
• Unit save the last settings when powering off.
• And of course, the lovely tube indication of the active channel :)
• 6 hp skiff friendly (40mm deep)
*There may be rare minor layering of adjacent channels, this is a technical drawback of the Arduino ADC, we`ll try to completely eliminate it programmatically in future firmware, but for now this bug can occur at very slow and some borderline voltage values.
Module specs: 6 hp, skiff friendly, black or aluminium panels
ModularGrid: https://www.modulargrid.net/e/paratek-% ... -aluminium
Insta: http://www.instagram.com/paratekorg/
parsec foley
Re: "ЧАТЕЛЬ-6" - 6-channel bidirectional signal router.
Post by parsec foley »
from "only" beautiful to very useful, too! I was wondering if the output (or input) pair at the bottom were identical (and buffered?) and what's the purpose of the second input from top, on the left: is it for CV changing the direction/algorithms instead of manual changes via the button?
Dedal
Post by Dedal »
parsec foley wrote: Thu Aug 27, 2020 8:18 am from "only" beautiful to very useful, too! I was wondering if the output (or input) pair at the bottom were identical (and buffered?) and what's the purpose of the second input from top, on the left: is it for CV changing the direction/algorithms instead of manual changes via the button?
Upper cv input for control Chanel’s instead of gate input, when is 0v - Chanel 1 when 5v higher Chanel (6 max)
Bottom outputs/inputs is normalled without buffer, but right got an optional Easter egg in last revision - gate control of algorithms :)
parsec foley
Dedal wrote: Thu Aug 27, 2020 4:36 pm
(sorry for the delay) Thanks! guess I'm gonna need one... do you sell only via Reverb?
Dedal
Post by Dedal »
No , of course not, you can order directlyfrom me here or via email : djoxyjam@mail.ru
Return to “PAratek”
