I thought I'd start a new topic dedicated to FFT Effect modules, since there doesn't seem to be one and we are entering a new frontier in terms of FFT capabilities in Eurorack. I got inspired after watching the recent interview with Paul Schreiber of Synthesis Technology discussing the E520
Initial list (newest to oldest):
E520 Hyperion Processor [Synthesis Technology]
Panharmonium [Rossum Electro-Music]
Clouds (Spectral Madness mode) [Mutable Instruments]
ADM15 Spectre [Audio Damage]
These two I'm not sure about, but I'm guessing they should be included?
Odessa [Xaoc]
Super Signal Processor (SSP) [Percussa]
FFT Effect Modules
- circuitburst
- Veteran Wiggler
FFT Effect Modules
"make the events occur that you want to occur" - the black dog
https://soundcloud.com/circuitburst
https://www.modulargrid.net/e/racks/view/295055
World Map of Eurorack Module Manufacturers: https://www.google.com/maps/d/u/0/viewe ... 9IMDP34-ao
World Map of Eurorack Module Physical Shops: https://www.google.com/maps/d/u/0/viewe ... gfSeJ6wVIG
- circuitburst
- Veteran Wiggler
Also just for reference, this is where we were 4 years ago...
viewtopic.php?p=1982167&highlight=#1982167
Regarding Clouds' spectral mode: it was what the module was designed to do originally (it wasn't even called Clouds), but I ditched it because of the latency. You can't have low latency with (FFT-based) spectral processing.
- circuitburst
- Veteran Wiggler
For those curious about the FFT details in the upcoming E520...
https://synthtech.com/eurorack/E520/
Audio demos of these can be found here (scroll down half way down the page):
https://synthtech.com/eurorack/E520_DEMO/
Also here's the E520 thread:
viewtopic.php?t=221337
Currently, there are 5 Spectral algorithms: Spectral Crusher, Spectral Time Machine, Spectral Delay + Pitch Shifter, Spectral Delay, and Variable-Band Spectral VocoderSpectral effects are processed in the frequency domain using the Fast Fourier Transform. All spectral effects in the E520 use a 1024 point complex FFT to provide two 512 point real transforms at a rate of 2.7ms which provides a good compromise between time and frequency resolution, while allowing full stereo processing for most effects. Frequency resolution is 512 bins of 48Hz each.
