Question about fatar maxtrix
Kevin Mitchell
Post by Kevin Mitchell » Fri Sep 06, 2019 9:17 am
I'm working on a scanner/controller circuit for fatar keybeds. I'm hoping someone can confirm my suspicion about the TP/9S 44 keybed. I can't find the matrix sheet so I drew one up. Knowing the 44 key version will need 20 pins I figured they set it up similar to their 88 type keybeds and just moved the MK & BR tabs on to the bottom instead of using a larger or additional micromatch. Economically it makes sense.
If it is indeed correct that means I can use the same micromatch connector for 3 different keybeds, the 25, 37 and 44.
Click here for full image
Hope someone can help!
-KM
JanneI
Re: Question about fatar maxtrix
Post by JanneI » Sat Sep 07, 2019 12:52 am
44 ? 4-octave is 49. Do they make 3,5 octave model too?
weasel79
Post by weasel79 » Sat Sep 07, 2019 12:05 pm
fwiw midibox.org has fatar support you can probably find all the info there somewhere, open source
Kevin Mitchell
Post by Kevin Mitchell » Sat Sep 07, 2019 2:02 pm
JanneI wrote:44 ? 4-octave is 49. Do they make 3,5 octave model too?
Umm Model D?
They make 25, 37, 44, 49, 61, 76 and 88. The connectors for the 1st two are the same - 20 pin micromatch. I’m hoping the 44 is just as I’ve drawn out - similar to their 88 key one.
weasel79 wrote:fwiw midibox.org has fatar support you can probably find all the info there somewhere, open source
That was a waste of time :confused:
-KM
weasel79
Post by weasel79 » Sat Sep 07, 2019 3:36 pm
I dont know, might still be worth looking into. I recently received a new 49 with a so far unknown micromatch matrix layout
JanneI
Post by JanneI » Sat Sep 07, 2019 4:41 pm
Umm Model D?
-KM
I haven't seen 44 key versions for sale anywhere. Maybe a custom job for Moog?
25&37 have 1x 20pin and 49&61 have 2x 16pin. 88 2x 20pin. No idea what 44 is. Some repro Minimoog owner should look inside and share pics.
http://www.doepfer.de/DIY/Matrix_88.gif
http://www.doepfer.de/DIY/Matrix_61.gif
http://www.doepfer.de/DIY/Matrix_49.gif
http://www.doepfer.de/DIY/Matrix_37.gif
http://www.doepfer.de/DIY/Matrix_25.gif
weasel79
Post by weasel79 » Mon Sep 09, 2019 4:49 pm
TP9/S and TP/7 is available in 44 keys, starting on a low F iirc
http://www.fatar.com/Pages/TP_9S.htm
Kevin Mitchell
Post by Kevin Mitchell » Tue Sep 10, 2019 8:29 am
Just asking for the matrix sheet so I can be sure I have the micromatch pins correct. May have to wait until I have one in hand to test out :confused:
-KM
