Q155 Curver from Dotcom.
- Synth Con Meo
- Flareless
Re: Q155 Curver from Dotcom.
I ordered one! Looks kinda cool.
- Jari Jokinen
- Sensible Wiggler
- sduck
- experimental use of gravity
I was wondering about that also. It would be super easy to run a line from the positive voltage (perhaps with resistor in it) to the switching lug on the jack, provided that's not already in use. Then it would always be an inverter, unless you plugged something in.Jari Jokinen wrote:The inverter inverts only when control voltage is applied. Could be more convenient the other way round. Perhaps with a jumper.
Is that correct? Watch right around 6:00 when he moves the saw wave signal from the curver section to the inverter section. The 'up' saw becomes a 'down' saw as soon as it is patched into the inverter, before any CV is connected.Jari Jokinen wrote:The inverter inverts only when control voltage is applied. Could be more convenient the other way round. Perhaps with a jumper.
from the datasheet 'LED indicates Inversion" ..Dave Peck wrote:Is that correct? Watch right around 6:00 when he moves the saw wave signal from the curver section to the inverter section. The 'up' saw becomes a 'down' saw as soon as it is patched into the inverter, before any CV is connected.Jari Jokinen wrote:The inverter inverts only when control voltage is applied. Could be more convenient the other way round. Perhaps with a jumper.
no sign of any jumpers.
ranix
Wiggler Flareless built me a CGS Slope Detector awhile back. One of the coolest things I did with it was splitting the pitch CV of my keyboard through a slew limiter and sending the result to the Slope Detector. The output of the Slope Detector is a signal that tells whether the note I'm playing now is higher or lower in pitch than the previous note. I can use it to alter modulation such that if I'm playing an ascending melody a certain modulation is applied, but if I'm playing a descending melody a different modulation is applied. It's fun.
- Bob Borries
- Ultra Wiggler
- Jari Jokinen
- Sensible Wiggler
You are right. That seems a good feature to me. Apparently the led indicates inversion only when control voltage is used.Dave Peck wrote:Is that correct? Watch right around 6:00 when he moves the saw wave signal from the curver section to the inverter section. The 'up' saw becomes a 'down' saw as soon as it is patched into the inverter, before any CV is connected.Jari Jokinen wrote:The inverter inverts only when control voltage is applied. Could be more convenient the other way round. Perhaps with a jumper.
- Jari Jokinen
- Sensible Wiggler
- Flareless
I think it works in only one direction though. The CGS62 Slope Detector is more flexible in that respect.Jari Jokinen wrote:I could use the Curver as a tracking generator for keyboard voltages...
I got mine for the Curver and of course, the extra VCA (I hear you can never have too many). The other two utility features are just gravy.
- TimeRaveler
- dslocum
- darwin's nemesis
I LOVE this. Why the F**K didn't I do this!???? Brilliant! (Damn it)
Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
www.steamsynth.com
- Voltage_Controller
- Jari Jokinen
- Sensible Wiggler
Oberheim Matrix synths have so called Tracking generators: "The tracking generator provides a mapping from a control source (e.g. key range on the keyboard, or volume pedal, or mod wheel) to a modified output, based on the user-defined settings of the generator."TimeRaveler wrote:What do you mean by "tracking generator"? Haven't heard of that.
Nothing special in case of the Curver. Just a quick way to trim a control voltage. For example, if you would want unlinear keyboard control over filter frequency.
- kindredlost
- 5U skiff friendly
- diophantine
An interesting module from Roger - some neat things in there!
I haven't actually looked closely at the "curver" part, but it looks pretty interesting, particularly for use on CVs, though the wavetable example above is also intriguing...
An extra VCA is, of course, always welcome!
Kinda wish that the functionality of the inverter & slope detector had been switched. In my Synthasystem I have a 'Selective Inverter' which is basically a CV processor/mixer + gate-able inversion. I rarely use it for the gate-able inversion. But having a slope detector with the rise/steady/fall outputs like the CGS would have been really awesome!
It also doesn't feel as compressed as some of his other recent offerings... just feels like a CV toolbox, which is a good thing.
- Synth Con Meo
- TimeRaveler
Im with you.. why in the video did he not link any of the sections to show off the whole module.?. also.. while i'm here.. these pics of waves.. I dont really care.. I need to hear stuff.. not see it..TimeRaveler wrote:Hmmm...right on the fence about this one - anyone have any more innovative ideas for how to use the curver or slope detector especially? I WANT TO BELIEVE.
I like seeing the wavforms!.... It helps me understand what is going on with the signal processing. Even if you don't find it helpful, why would you discourage providing us MORE information?josaka wrote: .. these pics of waves.. I dont really care.. I need to hear stuff.. not see it..
However, I do find the slow updating LCD scopes frustrating. I prefer seeing waves on my CRT scope in realtime. I'd like to find an inexpensive solid state scope that has a good realtime response.
