tetrax > plumbutter?
home of post-70s electronics
Moderators: Kent, bartlebooth
odditymedium
Post by odditymedium » Fri Mar 08, 2019 7:21 am
i wanna use the tetrax to trigger hits on plumbutter's gongs and avdogs
for this i tried hooking up the orange outs from the tetrax to the green pulse ins of the gongs and avdogs
but it is erratic... not consistent. it only seems to make sounds when i REMOVE the cables
is something wrong with my tetrax, or my thinking, or my cables?!
ClausF
Post by ClausF » Fri Mar 08, 2019 7:33 am
did you connect the grounds?
odditymedium
Post by odditymedium » Fri Mar 08, 2019 8:05 am
yeah
nada
odditymedium
Post by odditymedium » Fri Mar 08, 2019 1:32 pm
if i connect the tetrax press gesture to the gong fm input, i do hear modulation
but if i connect press gesture or release gesture to gong pulse input, then it doesnt trigger it
why is this?
how do i hit a barre on the tetrax, and have a gong sound at the same time?
k_bntzn
Post by k_bntzn » Fri Mar 08, 2019 4:26 pm
How about the red out?
odditymedium
Post by odditymedium » Sat Mar 09, 2019 4:25 am
nah
thats a triangle out
its more like an audio out
isnt it?
k_bntzn
Post by k_bntzn » Sat Mar 09, 2019 5:48 am
Well, in ciat world anything can go anywhere.
odditymedium
Post by odditymedium » Sat Mar 09, 2019 6:38 am
has anyone used a tetrax as a controller for the plumbutter? please tell me how
aethersprite
Wiggling with Expedience
Post by aethersprite » Sat Mar 09, 2019 3:25 pm
The pressure and release outputs of the organi have offset voltages built into their curves, you may have to process their signals with an attenuverter or comparator even to get the desired result of triggering something outside the 'ax
Return to “Ciat-Lonbarde”
