But a pic anyway for the weekend:
First attempt getting some laser-cut cheek designs done - designed on Inkscape (lots still to learn) and then cut out of 12mm birch ply. They don't cost very much! (this pair was £12 inc VAT). I've got some boot-ish 5Frames coming because I personally really want that sort of setup.
Once I'm happy with the files I'll share them (free) for people to DIY at their local laser shop. I think it'll be easier that way - then I don't have to stock a whole range and figure the often slightly awkward shipping - and it keeps the costs down for everyone.
Not 100% sold on the laser cut look, but it is cheapish and easy - I was also wondering about acrylic.
*********FILES**************
SVG Files (from Inkscape) in Zip File - see attached file.
My inkscape skills are MINIMAL! These designs are pretty rough & ready!
But free for people to make use of with Bug Frames (holes are placed for frame design standard from at least 2013 onwards)
Measurements given are on each listing below are just quick rough checks.
2Frame Bomber - Oct18 -about 24cm/9.5" wide:
3Frame Bomber - Nov18 - about 34cm/13.4" wide:
3Frame Boot - Nov18 - about 27cm/10.6" wide, 38cm/14.9" tall :
*** I personally now don't like the angle between the rows! It needs to be spaced out more -- the bomber design would be nicer***
3Frame Curvy - Feb20: 4Frame Bomber - Feb20: 2x2Frame Travel Jig - May19
Holds two 2Frame desktops - I used this for traveling - see: viewtopic.php?f=29&t=218936
5Frame Boot - Oct18 - about 37.5cm/14.8" wide, 60cm/23.6" tall
(the 3 top frames might be a little too tight):
