3x Stereo Mixer is a high quality 3 channel stereo mixer with manual volume controls. Total mix Left and Right outputs available on separate jacks, plus L&R stereo jack can be used to route the mix via single stereo cable or drive the headphones. Channels 1 and 2 can be muted with the relative switches. Left and Right led indicators available for all three channels.
Several 3x Stereo Mixer modules can be chained together via connections on the back side. This connection is possible with other Happy Nerding stereo modules too. At the moment PanMix Jr and 3x Stereo Mixer can be connected in both ways. Also their stereo outputs can be internally send to the Isolator module. Or stereo signal can be received from OUT and latest revision of PanMix.
AC coupled inputs.
Right channels inputs are normalled to the corresponding Left channel inputs for easier mono patching.
There is unity gain. Though can do a custom version with some more gain.
L&R output has the same level as ordinary L and R outs. It can drive most of the headphones, but without a dedicated phones level knob it is a tricky task. Because different headphones models have drastically different sensitivity. So this L&R output is just a bonus, which can not be suited for all the possible cans.
