Doepfer 157 could have been my dream trigger sequencer, simple & funky, but there is no development. Which is a big shame. :(
Imagine 4 sequences of 32 steps with 4 different grooves...
But it's not possible
Is there any sequencer like this?
Looking for a trigger/gate sequencer clocked by a Pamela New Workout.Hi5 wrote:Are you looking for gates or variable voltage?
TipTop Z8000 has multiple clocks for each seq in it. Trigger Riot doesn't have multiple clock inputs but the division options and probability function gets a similar effect.
I'm not interested in a sequencer that can multiply or divide 1 clock.VZvision wrote:Another approach to this may be to look at sequencers with multiple CV and gate outputs where each step of each sequence can be programmed to have a different duration or note length (not to be confused with variable gate-length)...i.e. one sequence doing 4 quarter notes/bar, another doing eighth note triplets, another with a combination of both, etc.
Hope that helps.
Yes I had an ER 101. Really powerful sequencer! It could do the trick even if it can't be clocked by multiple clocks. (well I never had ER 102 though, so maybe it works). But the way ER 101 deals with steps etc...yeah it could work, but I want something simpler. That's why I sold it... :(VZvision wrote: Modcan touch sequencer, ER-101, Five12's upcoming vector sequencer and NerdSeq's tracker sequencer come to mind...all have very different operation though so best check the workflows...
Ah yes! I forgot about this feature on the FLXS1!Hovercraft wrote:FLXS1 will be able to accept clocks for each of its four channels. However, the firmware is still in beta, and that feature has yet to be added. Tenkai is making good progress though--and following through on the list of planned features--no reason to think this won't happen. The module already has four gate inputs. It was a big reason I got the FLXS1.
Yeah. Or even better, 1 sequencer with 4 clock inputsflashheart wrote:Does sound like a job for 4 simpler sequencers...
Just to confirm that this is pure awesomeness! Thank you for your efforts - very much appreciated here!!freqout wrote:I recently added a feature to the Monome Ansible firmware to allow each track in Kria to be clocked manually from Teletype. You could send 4 independent triggers to Teletype and each one could clock a Kria track.
yeah why not, the MFB SEQ-01 PRO is cheap.kay_k wrote:that !flashheart wrote:Does sound like a job for 4 simpler sequencers...
Armstrb wrote:Each channel of the ER101 can run off different multiplications and divisions of the same clock.
For example if you have a clock going in you can set channel 1 to be 3/2 and channel 2 to be 1/1, or 34/73 - whatever you like. It’s insanely flexible.
AND the working model is not per step, you can make any step any duration of whatever of the clock is. So Step 1 can be a duration of 4 and step 5 - duration of 7. Assuming channel 1 above is used then step 1 would 4 x 3/2 of whatever clock you are feeding it.
Make sense?
The ER101 is by far the most flexible sequencer, through FLXS1 is also super powerful.
Ah yes. Why not!MvK wrote:4xladik s-180
Beat me to it. I have 2 Division6 Dual Mini sequencers, four 16-step sequencers total and it could easily do what the OP wanted. They are cheap if you make them yourselves too. You could easily make four of them for the price of the Doepfer sequencer, they only cost $90 in kit form for a dual sequencer. That would be EIGHT 16-step sequencers.flashheart wrote:Does sound like a job for 4 simpler sequencers...
Thanks a lot!!!!ersatzplanet wrote:Beat me to it. I have 2 Division6 Dual Mini sequencers, four 16-step sequencers total and it could easily do what the OP wanted. They are cheap if you make them yourselves too. You could easily make four of them for the price of the Doepfer sequencer, they only cost $90 in kit form for a dual sequencer. That would be EIGHT 16-step sequencers.flashheart wrote:Does sound like a job for 4 simpler sequencers...
Each sequencer also has a accent track that can be programmed separately from the main step sequence, with programmable rest on both, so each Dual Mini can give you four programmable gate streams (two synch'd pairs) each.
They remember setting over a power cycle too.
Yes, The XP in is setup to do the reset. The XP out produces a trigger on the exiting of the last step and can be used to chain sequencer together by patching XP out to XP in of another sequencer and that sequencers XP out back to the first. This can be done with more than one sequencer set to if you want really long sequences.Jaypee wrote: edit: I don't see reset input...but I assume the XP IN '(Expansion input; Starts sequencer back at step 1. Use for daisy-chaining multiple units)' is the same as a standard 'reset input' ?
I haven’t used either, but yeah it looks like clocks go to X and Y. There’s also 4 inputs for directions and jumps.Jaypee wrote:Thanks James!
But, the 2 clock inputs work like René, one for the X one for the Y...?22tape wrote:NLC’s 8-bit Cipher is stupid fun with 4 clock inputs. Their Bindubba looks great too with 2 clock inputs.
