Can anyone definitively report that the ES-8 works on linux?
Given that it's 'class compliant' it should do, but I'd be encouraged to hear a real world confirmation before shelling out for one.
Ta!
ES-8 on linux
I've been using it more thoroughly for a few months now and it works fine on linux.
I explained the technical side in a bit more detial on KVR audio :
https://www.kvraudio.com/forum/viewtopic.php?p=7093995
I'm currently using the ES-8 together with a behringer ADDA adat convertor. So for AC coupled audio signals I use the behringer in/outs and for DC coupled CV stuff I use the in/outs on the ES-8.
I'm using it stable with 128 byte frames without problems.
I use mostly bitwig studio, but I've used puredata (or purr-data) to build an experimental CV sequencer and that works just fine too.
Concerning the question to combine 2 audio devices in 1 jack configuration : This is theoretically not possible with jack as it only works with 1 alsa input device.
However it is possible on an alsa level to create a combined device, but I fear the overhead of this might kill your latency... Although I haven't gotten to test it yet.
The ES-8 has ADAT in/out which gives you the possibility to add 8 in/outs which for me is more than enough.
To come back to my earlier statement, you can combine multiple adapters in linux by using alsa_out/alsa_in executables
The additional audio adapters will become available as a jack client and you can define routings to them.
I'm planning on finding a way to add my old RME pci card to my setup to have move adat ports available.... The problem is I don't have any legacy usb ports.
Anyone has experience with USB-3 PCI legacy adapters?
Thanks for testing this, inspired me to bring up vcvrack on linux with es-8. Man vcvrack works really well on linux, and the es-8 connection was perfect. I had to cycle things a couple of times to get it not to hickup on the output of vcvrack but that has cleared up (I think it works best in the 48khz sample rate). Now I'm able to be at the 128 sample rate on vcv rack to es-8 without any issues!maaaks wrote:To answer my own question: yes, it works out of the box, no problems
Re: ES-8 on linux
Does anyone have this working with pipewire?
My system seems to recognize the ES-8 inputs but not the outputs. I cannot select them in the System Settings (see screenshots).
A couple of pertinent entries from the user.log:
I'm spinning in circles searching different forums trying to fix this.
Code: Select all
2023-08-26T10:47:11.648346-04:00 atreides wireplumber[1675]: <WpSiAudioAdapter:0x562897e0e070> Object activation aborted: proxy destroyed
2023-08-26T10:47:11.648876-04:00 atreides wireplumber[1675]: <WpSiAudioAdapter:0x562897e0e070> failed to activate item: Object activation aborted: proxy destroyed
2023-08-26T11:30:41.792467-04:00 atreides cinnamon-screen[11322]: Couldn't match the portless stream (with card) - 'ES-8 Multichannel' is it an input ? -> 0, streams card id -> 804
2023-08-27T07:18:16.600867-04:00 atreides pipewire[1512]: spa.alsa: surround71:1: snd_pcm_status error: No such device
2023-08-27T07:18:16.601368-04:00 atreides pipewire[1512]: spa.alsa: surround71:1: snd_pcm_recover error: No such deviceRe: ES-8 on linux
hiheretogo wrote: ↑Sun Aug 27, 2023 6:42 am Does anyone have this working with pipewire?
I'm spinning in circles searching different forums trying to fix this.Code: Select all
2023-08-26T10:47:11.648346-04:00 atreides wireplumber[1675]: <WpSiAudioAdapter:0x562897e0e070> Object activation aborted: proxy destroyed 2023-08-26T10:47:11.648876-04:00 atreides wireplumber[1675]: <WpSiAudioAdapter:0x562897e0e070> failed to activate item: Object activation aborted: proxy destroyed 2023-08-26T11:30:41.792467-04:00 atreides cinnamon-screen[11322]: Couldn't match the portless stream (with card) - 'ES-8 Multichannel' is it an input ? -> 0, streams card id -> 804 2023-08-27T07:18:16.600867-04:00 atreides pipewire[1512]: spa.alsa: surround71:1: snd_pcm_status error: No such device 2023-08-27T07:18:16.601368-04:00 atreides pipewire[1512]: spa.alsa: surround71:1: snd_pcm_recover error: No such device
did you finally get it working with pipewire ?
thanks and regards
