Why no Eurorack piano module?
williamjturkel
Post by williamjturkel »
Given the availability of modules like Rings and Plonk, I’m wondering why there isn’t something like a CV-controllable Pianoteq. I can think of a few possible reasons: lack of processing power, lack of perceived interest, etc. Interested to hear opinions on this.
Jefro
Post by Jefro »
My personal opinion, and I realize that maybe not everyone shares it, is that I don't want anything that sounds like a traditional instrument in my modular. The single exception is sample playback and manipulation.
mazzyboy
Post by mazzyboy »
I think expert sleepers general cv has a couple of piano settings
DruidTek
Post by DruidTek »
You'd get a better result with samples imo
Richie Jape
Post by Richie Jape »
manipulation of specific acoustic instruments like a piano works best in my experience if i sample for the piece i am working on and then use the morphagene to incorporate it into the piece ...
recently, not having access to a real piano i've been getting some very good results from using spectrasonics keyscape for this purpose ... sampling to tape and using the files from there ...
like someone mentioned above i see my modular as something different and new and non-traditional
diffrent strokes and all tho :tu:
geremyf
Post by geremyf »
The Orthogonal Devices ER-301 has a very nice Piano custom unit. It was developed by Kel, and is called Piano16. Here is a link to some information:
https://forum.orthogonaldevices.com/t/p ... m-unit/375
cptnal
Post by cptnal »
That's what pianos are for.
(Joking - don't have an opinion one way or another.)
Is it finished?
Latest Tune:
Racks: Big Case, Funboat, Tinicase
Richie Jape
geremyf wrote:The Orthogonal Devices ER-301 has a very nice Piano custom unit. It was developed by Kel, and is called Piano16. Here is a link to some information:
that is super cool !
subdo
Post by subdo »
For one thing polyphony is not really modular's strong point and a monophonic piano is kinda :despair:
Azarius
Post by Azarius »
Emulating a piano sound would be better via a dedicated keyboard or sample library imo since the sample size needed to store authentic sounding 88 notes with varying articulation / velocity layers would be problematic in a module. For example, Synthogy Ivory is about 49 gigs with 20 velocity layers per key and sounds amazing. This may be overkill for many use cases, but for $189 I’m sure it would be way cheaper than any comparable Eurorack module.
_____________________________
Latest Track:
https://soundcloud.com/user-211362451/obliteration
Jefro
Post by Jefro »
Maybe you could put a sample library such as the one mentioned above on an SD card for a Radio Music module. They're pretty cheap. You would need multiple Radio Musics for polyphony though.
boramx
lepidopteran orgasm
Post by boramx »
a192 or a192-2 and Disklavier.
swap the sheet music for sampled white noise, swap the punching machine for the a192 and swap the cigarette holder for a krazy straw going down into some Sujeong Qwa and I'm good.
D_Robot
Post by D_Robot »
When I started modular I spent many hours trying to emulate real world instruments patching with the modules I had. Not to make them sound real but to use the principle to make interesting sounds that reflect a little of the essence of these instruments.
I view modules like Rings and Plonk as single modules, of what I was trying to achieve with many modules, and used more as ways of abusing physical modelling synthesis rather than necessarily trying to accurately emulate real world instruments. As others have said to best replicate instruments it is probably better done with a real instrument or a sampler. I think that was the general conclusion of the Sound on Sound Synth Secrets series for most instruments including piano:Synthesizing Piano
Therefore, with piano I prefer to play directly into the modular and sample rather than try to emulate. The two main reasons are the performance aspect of tinkling the ivories but also polyphony.
Knights Who Say Neve
Post by Knights Who Say Neve »
Agree that a proper sampled piano in Euro is impractical.
But, the Korg Z1 had some nice physical models of electric pianos. Not ultra-realistic, but very responsive and tweak-able. I'd love to see something like those in a modular.
Space and time contain a manifold of pure a priori intuition, but at the same time are conditions of the receptivity of our mind- conditions under which alone it can receive representations of other objects, and which therefore must also always affect the concept of these objects. But if this manifold is to be known, the spontaneity of our thought requires that it be gone thorough in a certain way, taken up and connected. This act I name synthesis. -Kant
pzoot
Post by pzoot »
If there was a semi-decent one, I’d be surprised if they sold a dozen. That’s probably the simplest answer for why there isn’t one. You could always try a CV to MIDI module and modulate pianoreq parameters if it interests you
Funky40
Post by Funky40 »
pzoot wrote:If there was a semi-decent one, I’d be surprised if they sold a dozen. That’s probably the simplest answer for why there isn’t one.
THIS
pzoot wrote: You could always try a CV to MIDI module and modulate pianoreq parameters if it interests you
and this !
myself a Pianoteq player and fan. (expecting you meant Pianoteq )
I disagree on the " a one voice Piano would not be interesting" !
Pianoteq seems to work on those mini PC platforms.
A 4 voice moduel or so seems doable in regards to CPU questions.
just whoever wants to manufacture a module needs to calculate in some numbers............
I´d do some CV2midi
( i had sometimes my Digitakt sequenze my pianoteq by accident .....in monophonic. works ! can sound really cool )
For sale:
pzoot
Post by pzoot »
Yes!! Pianoteq! :hihi:
I too am a user and fan, and I too have used it monophonically (eg with Numerology). Electric piano and clav works well too. I also have Chromophone - Plonk is perhaps a good example of what a Pianoteq like module could theoretically be like vs a software version
I actually don’t have a CV2Midi device to try that suggestion out :) but the OP (if actually interested in this as a technique and not just curious about module production) could also try in-DAW LFO and sequenced modulators on Pianoteq depending on the DAW (eg Max4Live or Bitwig devices, or Numerology, or Reaktor Blocks) to get a sense for what it would be like.
strangegravity
A Big Knob
Post by strangegravity »
pzoot
Post by pzoot »
Nice!! A 5-key velocity sensitive keyboard. You just don’t see enough of those around :yay:
Paranormal Patroler
Post by Paranormal Patroler »
Funny you should mention it. I'm preparing a dedicated piano 6u case, after experimenting with the premise for years. Got a record in mind I've meaning to make; have a few etudes already but I'm not there yet.
I would buy a physical modeling piano module in a heart beat. I make do with CV to Midi (a-192-2, ADDAC 222) and physical modeling sounds which I work on my own. Lots of ground to experiment.
D_Robot
Post by D_Robot »
Just looked at Pianoteq, having not used it before, and now I'm thinking that in module form it could be quite interesting. Forget polyphony, with CV over a range of parameters it would be more like live tweaking a prepared piano...I might be one of the twelve.
thebrotherspus
Post by thebrotherspus »
D_Robot wrote:...I might be one of the twelve.
I'd be one too!!
I make lo-fi music for drinking tea at 1am.
bandcamp
youtube
starthief
Post by starthief »
strangegravity wrote:Image
Honestly, that looks like the start of a great trigger-with-velocity module. 8-)
pzoot
Post by pzoot »
Ok you guys got me :)
How about an alternate firmware for Plonk!!!
2disbetter
Post by 2disbetter »
I would like something like this, which is precisely why I went with a er-301 and more specifically a SSP.
There is no shortage of ways to accomplish a module like this with what is already available, and a really good sampled piano is about as good as it gets outside of playing a real one.
I am a big fan of my eurorack being able to make any sound.
2d
