Digisound in eurorack
Modulart_JP
Post by Modulart_JP » Sun Mar 04, 2018 3:53 am
I have been reissuing some Digisound modules in eurorack.
Last year I made the VCDO and VCO/LFO.
http://www.pharmasonic.jp/vcdo_e.htm
http://www.pharmasonic.jp/vcolfo_e.htm
2 more modules will be released this month.
And more should follow...
Eagle and FPE files are available for download.
All modules are under CC BY-NC-SA license.
Jarno
Post by Jarno » Sun Mar 04, 2018 5:04 am
They look fantastic, nice work!
Modulart_JP
Post by Modulart_JP » Sun Mar 04, 2018 8:12 pm
Thanks a lot !
Since it seems some people have trouble to find the links to the files, here they are.
80-21_euro.fpd
VCDO front panel
(3.38 KiB) Downloaded 37 times
80-2_euro.fpd
VCO/LFO front panel
(3.42 KiB) Downloaded 36 times
Jarno
Post by Jarno » Mon Mar 05, 2018 4:16 am
Did you find the EPROM content somewhere, or did you find a way around this (ie. program content yourself)?
Modulart_JP
Post by Modulart_JP » Mon Mar 05, 2018 7:48 pm
Jarno wrote:Did you find the EPROM content somewhere, or did you find a way around this (ie. program content yourself)?
I did build several VCDO modules in the past.
And I still have the original EPROM file.
here it is:
http://www.pharmasonic.jp/download/vcdorom.bin
I do not recommend to use 2716 EPROM chips because it draws too much current from the 5V rail.
28C16 EEPROM will work the same and your power supply will thank you.
c1t1zen
Post by c1t1zen » Mon Mar 05, 2018 10:20 pm
Going to try my hand at a few of these. Now that the CEM chips are back in production it would be neat to recreate a few of the old kit modulars.
I planned to do the Digisound 80 and Aries after that. Thanks for the share!
Modulart_JP
Post by Modulart_JP » Tue Mar 06, 2018 12:03 am
Modulart_JP
Post by Modulart_JP » Tue May 08, 2018 8:59 pm
Some news...
I have been quite busy adapting other Digisound modules to eurorack.
Now the following modules are available:
- 80-21 VCDO
- 80-2/3 VCO/LFO
- 80-6A VCF (LP, HP, BP, PS)
- 80-9A Dual VCA
- 80-4A VC Mixer
- 80-12 Noise/S&H
- 80-11A Dual Ring Mod
- 80-5 Processor
More info here:
https://pharmasonic.jp/digisound.htm
The 80-18 Dual ADSR should be available soon.
For the experienced DIYers, here is my github with all the files needed to build the modules:
https://github.com/Pharmasonic/Digisound-euro
For those who are interested in PCBs, full kits or built modules, please have a look at the order topic.
Modulart_JP
Post by Modulart_JP » Wed May 09, 2018 1:50 am
Modulart_JP
Post by Modulart_JP » Thu May 10, 2018 3:55 am
Some more info...
The modules are intended to be built with the THONKICONN jack sockets:
https://www.thonk.co.uk/shop/3-5mm-jacks/
And the Alpha 9mm vertical pots from Thonk:
https://www.thonk.co.uk/product-category/potentiometer/
I recommend the D-shaft pots to be used with the D-shaft 1900 clone knobs.
9mm vertical pots cannot be used for:
- the rate of the Noise/S&H module
- the Lag time of the Processor module
And the PCBs are designed accordingly.
For the S&H rate, I used this:
https://www.mouser.jp/ProductDetail/313-2441F-5M
For the Lag time, you need to find a 16mm 2M log pot.
tron23
Post by tron23 » Mon May 14, 2018 5:53 pm
Very interested in this project. Thank you for making it a reality. :guinness:
mrtweed
Post by mrtweed » Mon May 14, 2018 6:47 pm
awesome. thanks for your work!
Modulart_JP
Post by Modulart_JP » Wed May 16, 2018 3:28 am
You're welcome, guys !
ndkent
Post by ndkent » Tue Nov 19, 2019 2:24 am
Sadly no longer available (after I bought some chips)
backfromearth
Post by backfromearth » Tue Nov 19, 2019 11:30 am
Please Ori, could you explain what's going on ? Do you intend to restock some / all your digi modules or is it definitively over ? :confused:
Please inform us (in this forum and via your newsletter) before you stop the system 100 & 700 pcb/panels
Markat
Post by Markat » Thu Nov 21, 2019 4:20 pm
Did anyone manage to save these before they were taken down?
filterstein
Post by filterstein » Thu Nov 21, 2019 4:47 pm
I asked Ori about this and the answer i got is:
I sold Digisound PCB's until stocks lasted.
There is not enough orders to make me put money in another batch of PCB's.
All the digisound files are still available, but have have moved to:
https://www.pharmasonic.jp/shop/index.p ... er=product
acinonyx
Post by acinonyx » Thu Nov 21, 2019 6:26 pm
Markat wrote:Did anyone manage to save these before they were taken down?
If you mean the schematics just google "Digisound Project 80"!
First result that comes up is:
http://www.digisound80.co.uk/digisound/ ... odules.htm
Everything is there so you can roll your own PCBs and panels. You have to convert them in eurorack format though if that is your desire.
Author says that are not tested so you need some experience in order to make these.
If you mean the gerber files never went public. I can't find something.
or follow the link that filterstein posted above. The panels (FPE/Schaeffer) have already been made in eurorack format by Modulart_JP. Nice!
"Eureka, Archimedes of Syracuse"
Markat
Post by Markat » Fri Nov 22, 2019 2:35 am
filterstein wrote:I asked Ori about this and the answer i got is:
I was mostly interested in the eagle files which don't seem to be on that page.
whalemoth
Post by whalemoth » Fri Nov 22, 2019 6:23 am
Does anybody know where these PCBs are currently for sale?
julian
i like synthesisers...
Post by julian » Thu Nov 28, 2019 8:12 pm
I wouldnt post on someone else's thread, but Modulart_JP has made it clear that he is "out" -
whoop_john may (or may not - i dont know) still have his octoginta 3340 vco clone boards?
I did panels for them - there will be a photo about somewhere, but i dont have the link to hand at present.
I know that John had to spend time getting the vco all correct for 12v, so, certainly for some of the digisound units, its not a simple case of cloning the board part for part, although i suspect some would work just fine like that.
_________
For stocked euro / buchla / midibox see - http://thebeast.co.uk/?post_type=product
For custom cnc engraved panels see - http://thebeast.co.uk/?page_id=21
nobody
Re: Digisound in eurorack
Post by nobody » Sun Feb 23, 2020 4:02 pm
I have 20 octogintas I am finishing up, and I need front panels for them. Do you have the CAD / art for them?
I will be willing to trade once they are done. I dont think Im going to need all 20 ;)
ndkent
Post by ndkent » Thu Apr 02, 2020 9:35 pm
n.d
Post by n.d » Sun May 24, 2020 1:50 am
So, to be clear, nobody downloaded (or forked) those eagle files from github?
You know, that line that goes: "i want things that go Whooa and diuungg", like that nice man said to Bob Moog. That´s what I want too.
ndkent
Post by ndkent » Fri Jan 01, 2021 11:09 pm
Well I snagged a bunch and they got stuck in transit for months but finally showed up. I see currently front panels are only available as of today, no pcbs.
Filters:
The BOMs for the filter and PCB markings are kind of confusing, just a heads up. I think the caps match on the original Digisound article while the pharmasonic bom looks confusing . on the pcb the HP caps are marked with a number and "H" on the pcb and unpopulated on the other builds.
Resistors are an extra level of tricky since the original runs on +15 so the values don't match. I think I populated the version only ones from the pharmasonic BOM, marked all the spots the other builds use to not populate, put in the common ones.
Ring Mod:
funny mistake, the pcb will still fit nicely turned 180 degrees and I wondered why it didn't work
Processor:
the invert does something Buchla-ish and ignores negative signals, though that makes it more unique, there is a build with omitted parts that does a more expected invert
