https://www.thonk.co.uk/shop/tubeohm-sm ... i-vcf-kit/
http://www.tubeohm.com/page9.html
And the price?!
This is hella tempting.
I'd love to hear some additional samples. Anyone got one yet/already?
Same filter ins Shruthi? Can you give background please?TechForze wrote:Nice, same filter in my Shruthi.
Looks like a fun build.
Ordered PCB + lovely panel.
https://www.modulargrid.net/e/other-unk ... smr4-multi
Also, please do a review when you've made it! I'm hovering over the 'buy' button, but can't convince myself ;p
ahem yes, but would be good to hear it in a not so "dry" fashion with less square/triangle wavy stuff.. cheap though..windspirit wrote:The sounds on the website are pretty bland in a "this is exactly what the filter sounds like in this precise mode with various settings" but it gives you a good idea that it is a solid filter. Definitely has my attention. Great job on your first(?) Eurorack module tubeohm!
Only other module I have seen with this feature is the River filter by dendrites:R.U.Nuts wrote:Voltage adressed switching of filter modes... That's a pretty unique feature, right?
There is three boards, components are through hole, the filter board is really tightly crowded. You have to pay attention to solder the led matrix with the panel attached to have everything aligned but if you follow the detailed build guide there is nothing scary. It's def not kit for a first build, maybe nor a second, but might be ok third if you have the patience enough.Gregor Dys wrote:How seriouse should I be taking this?Recommended for Experienced Builders
Yeah it resonate in every filter modes ,̶ ̶b̶u̶t̶ ̶e̶a̶c̶h̶ ̶m̶o̶d̶e̶ ̶h̶a̶v̶e̶ ̶a̶ ̶d̶i̶f̶f̶e̶r̶e̶n̶t̶ ̶c̶u̶r̶v̶e̶ ̶s̶o̶m̶e̶ ̶o̶f̶ ̶t̶h̶e̶m̶ ̶a̶r̶e̶ ̶i̶n̶d̶e̶e̶d̶ ̶s̶i̶n̶e̶-̶i̶s̶h̶,̶ ̶b̶u̶t̶ ̶n̶o̶t̶ ̶c̶l̶e̶a̶n̶ (I'm going to take some screenshots and samples)MrTurboparrot wrote: Does it resonate? with a nice clean sine?
uuav wrote:Yeah it resonate in every filter modes ,̶ ̶b̶u̶t̶ ̶e̶a̶c̶h̶ ̶m̶o̶d̶e̶ ̶h̶a̶v̶e̶ ̶a̶ ̶d̶i̶f̶f̶e̶r̶e̶n̶t̶ ̶c̶u̶r̶v̶e̶ ̶s̶o̶m̶e̶ ̶o̶f̶ ̶t̶h̶e̶m̶ ̶a̶r̶e̶ ̶i̶n̶d̶e̶e̶d̶ ̶s̶i̶n̶e̶-̶i̶s̶h̶,̶ ̶b̶u̶t̶ ̶n̶o̶t̶ ̶c̶l̶e̶a̶n̶ (I'm going to take some screenshots and samples)MrTurboparrot wrote: Does it resonate? with a nice clean sine?
Filter is warm, full of low end but a (little) bit noisy. I always had regrets when I had to sold my shruti, that little beast was always on point for generating warm basses and pads. I'd say the Tubeohm sounds a bit like the Jove. Perfect when you put it right after digital oscillators, and it can goes from chamomile to acid.
I had ton of fun generating rhythmic patterns with feeding noise in, ADSRs on cutoff and res, and a sequencer driving the filter selection.
edit:Fm pot was not fully off which resulted into different waveforms for each filter modes and dirty sine, the sine is fairly clean (LP 6,12,18,24) as you can see.
I read in this post from jan 29 (second from the top): https://forum.mutable-instruments.net/t ... er/13360/2merchant wrote:Anyone else get clicking when changing the filter mode with CV?
