Chirper!
- BananaPlug
^ Nice! I still need to try that earlier idea you showed about Chirper driving the DDSR.
Meanwhile, here's a slightly augmented Chirper.
LISTEN Shrill sounds from 1:35 to 2:00, watch your level.
This is one Chirper with DD1, SYN2B, PRC1, VERB
Chirper out and the sine get ring modded and fed to the DD1's LPG which gets triggered by a cap from Chirper's OSC1.
You get the idea. A little retuning takes it into other realms. Lots of fun interactions and surprising finds.
- T. Jervell
Wow!! Sounds greatBananaPlug wrote:^ Nice! I still need to try that earlier idea you showed about Chirper driving the DDSR.
- T. Jervell
Hah! This was fun! Got a Landscape HC-TT the other day. Tried it with some of my bugs today. So much fun!!
Chirper to HC-TT input, HC-TT output to COFilter. The tape is an audiobook. HC-TT is outputing CV and gate signals based both on what’s on the tape and what’s coming into the input (Chirper). The CV was initially sent to the DDSR data in (and the recycled), and the Gate out to the clock in on the DDSR.
- BananaPlug
I always wondered about those hand cranked cassette devices. Show us more when you get a chance.
What's the CV/Gate stuff? Is there an envelope follower or something? Is it just amplified tape audio?HC-TT is outputing CV and gate signals based both on what’s on the tape and what’s coming into the input (Chirper).
nice!! is that the newer version? i didn't realize it sent out cv/gate signals
- T. Jervell
Shred: yes it is the new one.
BananaPlug: I guess the CV out is a sort of envelope follower. But I guess not the most «precice» + seems to be a pretty steep decay. Gates are provided when the audio reaches a given threshold (I guess), which fires a gate/square signal. The two outputs seems to be related, so as far as I know when the gate is activated the follower is also «triggered». It is possible to do some rudimentary tweaks to the response via the «tone» control.
Anyway, tons of fun, and it is very nice to use it as a sort of sequencer/controller
- BananaPlug
Just a quick Saturday morning live improvisation. Mostly Chirper.
LISTEN
Watch your levels, the feedback got away from me.
LISTEN
- T. Jervell
- T. Jervell
Been messing with a passive ringmod I’d forgotten I had. Found it a couple of days ago. Quite fun to take the direct outs from the two Chirper osc’s through the ringmod then to the LPG->Spring Tanker. Also osc 1 into osc2’s sync. Then two channels of the DDSR into X and Y axis on the Joy/Touch, outs to osc 1 and 2. Also the main out of the Chirper is run through dual VCA-> COF. Manual gates from Joy/T drives DDSR, LPF and envelopes. Also pressure out from the joystick is modulating the COF.
A lot of fun to be had, but it’s hard to hold the camera and operate the Joystick......
- BananaPlug
- T. Jervell
Thanks! Yeah manually clocking the DDSR is nice! I often do this with my other sequencers as well. Gives a nice «human» touch...haha
Also ring mods, I’m currently very much into investigating the world of ring modulators. I’m hoping we’ll see a blue one in the not too distant future, but anyone here got any favorites?
To get audio into the filter, would the Dual Preamp module with a single wired connection (+ resistor) from Preamp's output banana terminal be the way to go? That would be very nice to have, alongside the Env-Amp.
I really enjoy using the DRM2 in this way... would be cool to have it in Chirper form w/ the x-mod and different filter control.
BTW is the filter design similar between the two (Chirper / DRM2)? Other than how it switches between HP/LP.
- DickMarker
- Veteran Wiggler
You can use filters as rudimentary VCAs in some circumstances - it might not work ideally in your situation but I've used the Chirper's filter in LP setting with a suitable cv to the filter's ext in to essentially gate the audio passing through. It's a bit of a kludgey method though, not perfect by any means.PLNB wrote:Can someone point me to a good method to VCA/gate the output of the chirper to where I can play notes/CV from the OP-Z (with op lab module) with silence on key release? I need to break up the output to play a more traditional patch in addition to letting it groan, chirp, squeal. Thx!
Ps Love the idea of a Chirper-specific env/amp Tom.
Yes, there's a spot for an input resistor for filter input - it expects a signal +/-5V ie to match the oscillator amplitudes so, yes, the Dual Pre would be ideal for amping external signals up to this./\/\/\/ wrote:To get audio into the filter, would the Dual Preamp module with a single wired connection (+ resistor) from Preamp's output banana terminal be the way to go? That would be very nice to have, alongside the Env-Amp.
Yes the filters are all pretty similar on most of my devices to be honest!
All this talk has me looking at putting together a 1FW Chirper Expander again... potentially dumb question, as I have not had any coffee yet, but what's the difference between:
• FXCV – Filter modulation input.
• O1CV – Osc 1 modulation input.
• O1CV1 (should read O2CV) – Osc 2 modulation input.
And the respective modulation inputs (with attenuators) on the front panel? I'm sure I'm overlooking something blindingly obvious but - again - no coffee...
- BananaPlug
- chrisdermo
Yeah they are unattenuated V/Oct inputs
On the expander I built I left those out and just took the raw oscillator outs and made a filter audio input.
Current Bugs frame:
Current Bugs frame:
