Alternative Reverb Tanks for BEMI Easel?
Buchla, Serge, Studio.h, Northern Light Modular, Keen Assoc., 1979, Vedic Scapes, etc - Banana systems!
nickbaba
Location: Symbolically Authentic Non-Euclidean Adventures
Post by nickbaba »
One thing with my Easel, I've never loved the onboard reverb sound. I know a lot of people here do love it. Maybe I have an issue with my tank, I've never opened it up to look, but it always sounds like an old tin can to me and not in a good way. And I'm a fan of spring 'verbs.
I've read here that the Accutronics 1BC2E is a suitable replacement for the BEMI Easel reverb tank (at least that's the tank often used in Easel clones).
But are there other spring tanks that would fit the spec e.g. correct impedance, right size, that could be tried for a different flavor of 'verb?
Has anyone here customized their Easel reverb with something different, maybe bigger?
TMortigan
Post by TMortigan »
Have you ever had your Reverb cut out the overall sound when you reach about half way on the knob setting but then return at nearly full effect? One has done that since day one.s puzzling to me.
I want your MARF, 216, 266, 277 and 227!!! CLONES WELCOMED :)
nickbaba
Post by nickbaba »
mm no my reverb functions as it should - I was just curious about trying a different tank.
I've been told the BEMI Easel uses the 8BC2E, which is the 3 spring version (1BC2E has 2 springs). Also that changing the tank probably won't make a difference to the sound, which is more down to the circuit BEMI use.
I think I'll try running it through an external spring tank instead of looking to swap out the internal tank.
nickbaba
Post by nickbaba »
I have never needed to set my Easel reverb at more than the 10 o'clock position - at that point my sound is like 75% wet... halfway on the dial and my sound would disappear into the background... but maybe that's not normal?
CliffordMilk
Post by CliffordMilk »
Mine is the same but whether it's normal or not, I don't know.
I gave up and bought a Strymon Bluesky.
noisejockey
Post by noisejockey »
Mine's that way, too. Only ever use it from off to maybe noon, unless I want to start or end a piece in total murk. Small amounts go a huge way with that thing.
But for extra flavors I too have external reverb pedals.
