iProgram card & 208r rev2?
flabby
Post by flabby »
Doing a bit of searching and I can't seem to see a straightforward answer. Most say no, some say yes without problems. So, does the iProgram card work with the 208r rev.2? If not, what mods are needed?
papz
Post by papz »
The iProgram card needs +5V on the 3rd rear contact of the edge connector.
It's not on the 208r rev2's card slot but can be added by a simple wire connecting this contact to the +5V rail :
Please don't ask, thanks.
flabby
Post by flabby »
Great stuff! Thanks Papz
papz
Post by papz »
Cheers
There are other connections to unused contacts of the 208r rev2 but I think are specific to the BEMI Easel.
flabby
Post by flabby »
'Hi/lo' switch I imagine is one.
ritchiedrums
Post by ritchiedrums »
:party: :party:
papz
Post by papz »
Flabby, or someone else, can you please confirm the iProgram card works with this +5V extra connection ?
I don't have an iProgram card, neither acces to one, but from memory when I tested years ago, it was ok.
Thanks !
flabby
Post by flabby »
papz wrote:Flabby, or someone else, can you please confirm the iProgram card works with this +5V extra connection ?
Thanks !
Papz, unfortunately I can't. I don't have a rev2. I think I was asking this when I was looking at getting either a rev 2 or BEMI. I ended up with a BEMI 208.
papz
Post by papz »
Thanks for the quick reply.
Hopefully someone else will can help on this.
papz
Post by papz »
Thanks to a wiggler who kindly offered to lend me his iProgram card, I could do deeper tests on a friend's BEMI easel.
The aforementioned +5V connection to pin 3 rear is not enough, pins 2 and 4 of both rows on the edge connector should be interconnected.
papz
Post by papz »
The clock connection is on rear pin 5 of the card edge connector and on pin 8 of the power connector.
The data connection is on rear pin 6 of the card edge connector and on pin 9 of the power connector.
flabby
Post by flabby »
Thanks Papz for taking the time to do this and sharing!
taijmanman
Post by taijmanman »
I use iprogram card to sequence in 5 steps, it will be "Both mode-loc sw" and will stop.
There are no problems with 2,3,4 steps.
ArguZ
Post by ArguZ »
Isn't seq 5 step supposed to be cut to prevent this ?
check the manual for the V60 upgrade please and see if you have the wire and the trace cut , and the correct FW installed
https://buchla.com/firmwarefiles/iProgr ... update.zip
taijmanman
I am using 208r. Is it only cut?
taijmanman
it moved with cut. Thank you
Electrostatic
Post by Electrostatic »
papz wrote:Thanks to a wiggler who kindly offered to lend me his iProgram card, I could do deeper tests on a friend's BEMI easel.
Hi Papz, or anyone whos' done this... So with the adjustments on the three pins (as above) the iProgram card works as it should in the 208r V2?
Just checking before I get one and commit to surgery. :deadbanana:
Cheers.
ArguZ
Post by ArguZ »
Yes, works absolutely fine if your wireless can take it.
That is the bigger problem
Electrostatic
Excellent. Thanks ArguZ.
Fingers crossed for everything else.
Cheers. :guinness:
