Boosting Low Output Level Modules?
- cheapmachines
I use the Epoch Modular Benjolin module but would like to be able to boost the levels coming from the filter outputs as they always seem rather low.
My VCA's all max out at unity, what are the clean level boost options in Euroland? Nothing outrageous, just to bump the signal up so it's comparable to other modules.
Any low hp clean level boosters out there? Not looking for overdrive / distortion modules.
I use streams for this but there is probably a cheaper option. I think blinds can do this as well.
https://soundcloud.com/mark-harpum
https://www.instagram.com/harpum1/?hl=en
https://www.modulargrid.net/e/racks/view/456680
FS/T loquelic v1, korgasmatron 2 w/ expander, zdsp w/ 4 cards, seq 1, control forge, rt60, English tear(faulty),
WTB anything WMD and Noise Engineering.
- cheapmachines
It's at modular level alright, what I meant is the level from the module is low and my VCA's don't make it any louder. Some VCA's will boost but not all. Nothing wrong with the Benjolin, just how they are.
There are a few threads on Muffs already covering this and the advice seems to be the 4hp ADDAC Amplifiers, Circuit Abbey Gozinta or Doepfer A-183-3 for raising levels. Just wondered if there's anything else or if these three are still a good bet?
I'm also having similar problems, probably something like A-183-3 is made for that purpose?
http://www.doepfer.de/a1833.htm
Regarding modules with low output, one example would be j3rk dual bandpass filter I'm using.
busy soldering...
so for me two solutions for my Benjolin :
clean : Benjolin -> Gozinta
overdrived : benjolin -> TipTop Fold
Last Releases available here : https://editionsmego.bandcamp.com
https://fragmentfactory.bandcamp.com
Pico input might be a good option. 2 channels, 3hp and not too expensive.
There is a chance you might like this: https://soundcloud.com/steeboo
- cheapmachines
Thanks for the suggestions, very helpful
I have a 1u row and am thinking this might do the job if 26db max seems like it would be enough for most purposes?
http://pulplogic.com/product/gain/
How do you have the jumpers set on the Gozinta to give a good clean boost for the Benjolin? Are you on 12, 24, or 36dB?abdul6 wrote:clean : Benjolin -> Gozinta
I use this http://www.schneidersladen.de/de/erogen ... evit8.html
or this
http://www.doepfer.de/A133.htm
the latter if I need voltage control.
I also have the Vermona TwinVCamp which can boost a signal x4, but it distorts (in a good way) which is not always wanted.
or this
- pricklyrobot
- Ultra Wiggler
- cheapmachines
- pricklyrobot
- Ultra Wiggler
- cheapmachines
Yeah I understood what you meant originallycheapmachines wrote:It's at modular level alright, what I meant is the level from the module is low and my VCA's don't make it any louder. Some VCA's will boost but not all. Nothing wrong with the Benjolin, just how they are.
It is not working at a normal modular level though, Eurorack's nominal operating level is very high, (professional line level is +4dBu and euro's easily operate 6 more dBu than that) so if it was operating in this range it should be as loud as you could ever want (unless your main out or speaker were the problem, which they obviously aren't)
The reason I asked what Vca you were using is because most vca's should provide a decent amount of gain. They are voltage controlled amplifiers after all
The amount of gain in dB's each vca provides can almost always be found in in the description or documentation for the module.
I have a Folktek Matter which also has a very low output and I can turn its volume down by more than 50% till its very quiet, then run it through a channel of my Zlob vnlcursal vca and just by turning up the vca I can get it too loud for comfort.
Also for a temporary fix, if you are able to get some gain out of your current vca, you can run you its out directly into another vca (repeat if needed) till the levels are good.
Hope that's helpful..
- cheapmachines
Yeah, know what you mean - mine (Ladik and 2hp) run from zero signal passed with the gain fully anti-clockwise to unity fully clockwise as far as I can tell i.e. the same as the original input level. Some VCA's like the Intellijel uVCA for instance can boost beyond the original signal level but mine don't do that.dubstephead wrote:The reason I asked what Vca you were using is because most vca's should provide a decent amount of gain. They are voltage controlled amplifiers after all
Chaining VCA's together is a good temporary fix, thanks.
- strangegravity
- A Big Knob
- Paranormal Patroler
I went for Ladik for this usage. He has two 4HP options (maybe more?) which can bring line to modular level. One is with attenuation, one is without but has four inputs/four outputs which I think is really nice. You can attenuate post the drive.
EDIT
Here's the link to the Ladik A-520: http://ladik.ladik.eu/?page_id=1143
EDIT
I always considered the ADDAC202 to amp my 302 to +10V but I never got one. They are on sale thoughcheapmachines wrote:There are a few threads on Muffs already covering this and the advice seems to be the 4hp ADDAC Amplifiers, Circuit Abbey Gozinta or Doepfer A-183-3 for raising levels. Just wondered if there's anything else or if these three are still a good bet?
for Gozinta jumper :
24db is fine for Benjolin, always works
