DIY CS-80 imminent...(Deckard's Dream)
drip.feed
Roll it off at 30 Hz
Post by drip.feed »
You guys have seen this, right? :woah:
Roman Fillipov is working on a rackmount DIY CS-80.
More news here:
https://www.facebook.com/rfilippov?hc_r ... ED&fref=nf
:guinness:
Dripfeed
djs
Post by djs »
I can't see it on his fb page.. any sound samples?
I'll never be able to afford it I'm sure, but the fact that it exists is good enough for me :)
@neutronstar604
JAO
Post by JAO »
parallel discussion over here:
viewtopic.php?t=177657&highlight=
drip.feed
Post by drip.feed »
Thanks JAO. "Deckard's Dream" in the thread title didn't leap out at me when I searched. :doh:
Mods, please lock this thread.
Dripfeed
Isaiah
Post by Isaiah »
Surely this is best in the DIY forum, no?
Roman stated it would be DIY.
JAO
Post by JAO »
i can see the value of having it in both sub forums, seeing as it is of both general interest and DIY interest.
+1 for leaving the thread open.
lasesentaysiete
Post by lasesentaysiete »
can't think of a better time to come out of the closet and declare myself a huge Boss fan. I'll be building one of these mostly because of this:
snufkin
Post by snufkin »
hmm will it respond to poly AT? thats the question, not sure it's really the same without it.
sduck
experimental use of gravity
Post by sduck »
Hmmm, lock it or leave it open? Normally I'd lock this, leave the older thread open, but if it's really DIY, maybe I'll leave this open. Lets try to restrict comments to this tread to the DIY aspects of this project maybe? Like that last post should be over in the other thread.
biftek
Post by biftek »
To keep this thread DIY:
He mentioned there are no rare parts on twitter which is really nice, and based on the photos he posted of the PCB's it looks like the voice cards are modular like on the Ambika.
So hopefully you can build a couple voice cards and start using it immediately and add more as time goes on.
Curious to see a BOM, I'm not familiar with the internals of the CS80, except that there are pounds of wires.
drip.feed
Post by drip.feed »
Sorry, wrong thread.
Dripfeed
tobb
Post by tobb »
:yay: :guinness: :goo: :sb: :banana: :nana: :bananaguitar: :tu: :miley: :guinness: :eek:
malnatim
Post by malnatim »
snufkin wrote:hmm will it respond to poly AT? thats the question, not sure it's really the same without it.
midi can carry it and i imagine the firmware on this will handle it.
for me the question is how to generate it. i only know of very expensive controllers with poly at and qunexus, which isn'd really a proper keyboard. is there anything else in-between?
re. diy… i assume all smt will be already populated. so this will be expensive, but you'll be able to assemble and have cs80 in no-time.
pulse_divider
Post by pulse_divider »
I hope it supports MPE! This would be so amazing with a Roli/Haken/Linnstrument
latigid on
Post by latigid on »
Heh, awesome! Hope it's not too many thousands of bucks.
LSuveg1
Post by LSuveg1 »
pulse_divider wrote:I hope it supports MPE! This would be so amazing with a Roli/Haken/Linnstrument
It would be amazing! However, in response to an Instagram comment/question about this, Roman replied "what is MPE?" So... unfortunately I don't think it will be supported :-/
Jaytee
Post by Jaytee »
for me the question is how to generate it. i only know of very expensive controllers with poly at and qunexus, which isn'd really a proper keyboard. is there anything else in between?
A bunch of old Ensoniq keyboards support it. Some of them are known to get (fixable) issues as they age, so you can pick them up extra cheap.
In any case, following this thread with interest. CS-80 is another one of my Harrison-Ford-sci-fi-movie-synth-connection-holy-grails, along with the 2600 (which I hope to be building a clone of over the next few months).
oldcrow
Post by oldcrow »
I would need to see the schematics to determine how he resolved certain design criteria, but the boards he has shown on instagram look pretty good.
If Roman used my osc, filter or waveshaper equivalent circuits it should have the right tone palette.
The greater part of what makes the CS-80 one of the best ever made is however the performance controls. If he has enough MIDI CC routed to do things like operate polyAT and operation of the ringmod slider controls, as well as a good pitchbend profile (it should go to 0 Hz) it should be enough of the real deal to get me to build one.
Crow
Huba-Swift
Post by Huba-Swift »
Very, very interested in this. I just really want to know the specifics in what the DIY kit comes with. It just mentions 12 pcbs, MCU and 72 dacs. Does it come with the case, display, sliders... If all the smt parts are pre-soldered, that would make this a much more plausible build. I'm really looking forward to this though. I've been wanting some more polyphonic DIY with more than 4 voices, and this answered my prayers. :hail:
oldcrow
Post by oldcrow »
Hm, now that I look closer at the panel, no ring modulator. Oddly enough this is not a problem for me, because I've played with the prototype of a little box called appropriately enough the Spinner, which is a CS ring modulator with the correct control layout as well as MIDI and gate control that does two audio channels. Suit and Tie Guy had it at NAMM. :sb:
Huba-Swift
One has to wonder if adding a ring modulator is part of the plan for the expander plug on the back. Unlikely, but that would be nice.
tobb
Post by tobb »
via Roman:
"ringmod, delay, chorus and spring reverb are coming in a separate 1U rack also DIY" and pre-built. Also, according to Roman, the price for any of this is not currently set at this point.
ashleym
Post by ashleym »
I think the ouch part will be the 70 odd sliders. I understand a lot of this will be processor controlled but there will still be a lot of components per voice, the frame looking construction might help with the price of entry allowing one voice at a time to be purchased?
At least there is a fan slot on the back, giving it a nod to the original.
Exciting.
mOBiTh
Post by mOBiTh »
DROOL :omg:
tron23
Post by tron23 »
tobb wrote:via Roman:
that's insane. :party:
