ES-8 firmware announcement thread
os
Post by os »
This thread is where new firmware for the ES-8 will be announced.
Please post comments, requests etc. as new threads.
os
Post by os »
30/1/2017 - version 1.1.0 is released.
- added standalone mode.
http://expert-sleepers.co.uk/es8userman ... wareupdate
trummerschlunk
1-Post Wiggler
Post by trummerschlunk »
mine seems to have 1.20
at least in the osx system profiler it says so.
Which one is the latest?
Thanks - great tool!
os
Post by os »
1.2.0 is the latest.
Moon Indigo
Post by Moon Indigo »
os wrote:1.2.0 is the latest.
OS - can I please have a link to the 1.2 ES8 firmware for OSX? I can only find 1.1 on your website.
os
Post by os »
Nobody needs to install 1.2.0. It was only necessitated for an internal hardware revision. Hardware that needs 1.2.0 ships with it on.
nniftymusic
Re: ES-8 firmware announcement thread
Post by nniftymusic »
Hi when I look at the system information on my ES-8 it shows that it is on 1.0.1. Based on the information here and on the website 1.1.0 is the latest however when I go to use the update utility it shows that there are no suitable devices connected. How can I update to the latest firmware?
os
Post by os »
Which macOS are you using?
nniftymusic
I'm on Mojave 10.14.6
os
Post by os »
Same as me. I just downloaded from
https://expert-sleepers.co.uk/es8userma ... wareupdate
and it works.
Can you post screenshots?
nniftymusic
It shows up in system information but this is what it shows in the updater app.
os
Post by os »
Is the ES-8 connected directly or via a hub?
nniftymusic
I've connected it both directly and through a hub and the results are the same.
os
Post by os »
Could you do Cmd+I on the updater tool and send me a screenshot?
matkins85
Post by matkins85 »
Hey Os,
I've just been trying to run the 1.1 firmware updater linked to above but it crashes on launch.
I have tried it on two different macbooks, on two different versions of macOS, with the same result.
I've got no idea if the fix will be on my end or yours but either way your help would be greatly appreciated.
Here's a crash report:
Process:               ES-8 Firmware Update [2446]
Path:                  /private/var/folders/*/ES-8 Firmware Update.app/Contents/MacOS/ES-8 Firmware Update
Identifier:            com.expertsleepers.ES-8-Firmware-Update
Version:               1.1.0 (1)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           ES-8 Firmware Update [2446]
User ID:               501
Date/Time:             2021-03-04 21:41:05.852 +0000
OS Version:            macOS 11.2.2 (20D80)
Report Version:        12
Anonymous UUID:        85B798C5-DED5-6C22-88DC-B901C7F762A4
Time Awake Since Boot: 1700 seconds
System Integrity Protection: enabled
Notes:                 Translocated Process
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  dyld: Using shared cache: 77B63435-1866-32DD-98A1-47090B666EFA
Library not loaded: /usr/local/lib/libusb-1.0.0.dylib
  Referenced from: /private/var/folders/*/ES-8 Firmware Update.app/Contents/MacOS/ES-8 Firmware Update
  Reason: image not found
Binary Images:
       0x10e8fd000 -        0x10e902fff +com.expertsleepers.ES-8-Firmware-Update (1.1.0 - 1) <B79ADEFB-D2E5-3740-9243-1D78DEDC59AB> /var/folders/*/ES-8 Firmware Update.app/Contents/MacOS/ES-8 Firmware Update
       0x114491000 -        0x11452cfff  dyld (832.7.3) <0D4EA85F-7E30-338B-9215-314A5A5539B6> /usr/lib/dyld
Model: MacBookPro11,3, BootROM 430.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2.5 GHz, 16 GB, SMC 2.19f12
Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin
Graphics: kHW_NVidiaGeForceGTX750MItem, NVIDIA GeForce GT 750M, spdisplays_pcie_device, 2 GB
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1675.1)
Bluetooth: Version 8.0.3d9, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
os
Post by os »
Do you actually need to run it? There hasn't been an ES-8 produced with 1.0.0 firmware for 4 years now.
matkins85
Post by matkins85 »
Yes, I believe so. In system information it reads "Version: 1.01"
os
Post by os »
The quickest solution would probably be for you to install libusb.
https://formulae.brew.sh/formula/libusb
matkins85
Post by matkins85 »
Worked perfectly! Thanks Os!
phutureboy
Post by phutureboy »
Version 1.10 is the same as the one in the es8.1.1.0.zip right ?
It appears I cannot open the ES-8 Firmware Update.app under Catalina... it says it cannot open because of "a problem"
FS: EMS AKS | WTB : ESX-8GT MKI
os
Post by os »
Probably the same issue, with the same solution - install libusb.
phutureboy
ok, and what about my first question ?
os
Post by os »
Yes.
phutureboy
Thanks.
Wavtekt
Post by Wavtekt »
I would like to update the firmware of my ES-8 (currently 1.01, want to update to 1.1.0). However, I am using PC, what should I do?
Please let me know. Thanks!
Return to “Expert Sleepers”
